02-11-2010, 02:52 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Venezuela
Member: 594580 Status: Offline Thanks Meter: 157 | 2630 SIMLOCK_DATA corrupted! Library version: 1.0.0.11985, Date: 03-02-2010 Processing file: rm298__05.62.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 10.67 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000EFF14:3B8ADA60 Area [01000000-02FFFFFF] erased in 2 min 21.781 s Flash programming ... Programming completed in 7 min 18.422 s File Processed in 9 min 49.266 s Processing file: rm298__05.62.image_ub_movve_blk_v1 as CNT [DCT4,DCT4 ALGORITHM] page size: 128 K size: 4.00 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000EFF14:C5A4DA78 Area [02000000-02DBFFFF] erased in 1 min 1.781 s Area [02DC0000-02F9FFFF] erased in 8.610 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 2 min 45.734 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.078 s File Processed in 4 min 17.656 s Processing file: rm298__05.62.ppm_ub as PPM [DCT4,DCT4 ALGORITHM] size: 2.67 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000EFF14:2984DA60 Area [01C40000-01FFFFFF] erased in 17.578 s Flash programming ... Programming completed in 1 min 49.734 s File Processed in 2 min 14.610 s Flashing completed in 16 min 21.656 s After Flash Processing ... Updating Product Code OK. Phone Type: RM-298 (Nokia 2630) SW Version: V 05.62 02-07-08 RM-298 (c) Nokia Imei plain: 01140000458110-3 Imei OTP: 01140000458110 Product Code: 0556067 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: UB Language Pack: - not available. Imei net: 01140000458110 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! Total time to process is 16 min 40.906 s How to fix please.. |
02-11-2010, 02:54 | #2 (permalink) | |
Insane Poster Join Date: Aug 2007 Location: MX-KEY Service Center
Member: 571241 Status: Offline Thanks Meter: 13 | Quote:
02-11-2010, 05:49 | #6 (permalink) | |
Freak Poster Join Date: Apr 2007 Location: in ur heart
Member: 481933 Status: Offline Sonork: 100.1582701 Thanks Meter: 107 | Quote:
remeber flash the handset with the supportive unlock ver wbr vicky nazar2008 | |
02-11-2010, 07:12 | #9 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | UI setting means full factory.user data.leave factory. service center.software upgrade.production tuning.reset user code. select these all and press reset all. |
The Following User Says Thank You to Ramzan khan For This Useful Post: |
how repair SIMLOCK_DATA corrupted! | kumar_pvj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 17 | 05-17-2010 17:41 |
SIMLOCK_DATA corrupted! | R@ZIB-BD | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 07-30-2009 21:43 |
N85 SIMLOCK_DATA corrupted | godlfc | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-26-2009 09:45 |
6681 SIMLOCK_DATA corrupted!?? | mdmosheur | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 07-05-2009 07:25 |
n95 SIMLOCK_DATA corrupted!?? | SAN INFOTECH | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 07-03-2009 05:51 |
