03-01-2010, 15:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | 2680 RM-292 Flashing Error Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001A0B99A3BDA66 ASIC type: 11 UEM Imei: 3563900***** Flash Imei: 35639002******* RPL saved to "C:\mobileEx\3.3\data\backup\RPL\3563900******_BAC K.rpl" Processing file: rm392__05.28.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 11.82 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Boot error: 4F 4E 00 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 1 min 43.672 s RX Buffer: 33659300326228F842 |
03-01-2010, 16:41 | #3 (permalink) |
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | With UFS this is the log:- Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Boot error: 03 00 00 72 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Processing file: rm392__04.91.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 11.75 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Boot error: 03 92 31 72 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 1 min 14.406 s |
Need 2660 RM-292 flash file version 3.62 | gsm_unlock2 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-26-2016 16:38 |
Rm-237(3110c) Flashing Error Any Help? | msantar | Nokia Base Band 5 ( BB-5 ) | 14 | 11-07-2009 10:28 |
2680s RM-392 Flashing Error Help. | papoo | Universalbox | 8 | 10-27-2009 13:17 |
RM-36 flashing error | 8051 | Federal One | 0 | 05-14-2007 08:16 |
