12-23-2010, 07:13 | #2 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1475063 Status: Offline Thanks Meter: 0 | yes u can convert but what about imei bro it is sl3 phone and after cressflash it's imei goes to 12345654321? and if u have rpl backup then try to convert but remember 1. make rpl backup 2. make rpl backup again 3. make again rpl backup br |
12-23-2010, 07:37 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 666540 Status: Offline Thanks Meter: 354 | I think it is dct4++ phone not sl3 well here is the log of this phone Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.9(20-11-2010), 1.02(20-11-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C3ED01A3BDA66 ASIC type: 11 UEM Imei: 0117400008xxxx Phone Type: RM-393 (Nokia 2680s-2b) SW Version: V 05.28 05-11-08 RM-393 (c) Nokia Imei plain: 0117400008xxxxx Imei OTP: 0117400008xxxx Product Code: 0570610 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: UB Language Pack: - not available. Imei net: 0117400008xxxx Version: SIMLOCK SERVER Provider: Rogers Wireless , Country: Canada Counter: 0/3, 0/10 CONFIG_DATA: 3027200000000000 PROFILE_BITS: 800000000003000B |
12-23-2010, 09:52 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Location: Pakistan,Peshawar
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | Quote:
GSM007 | |
12-23-2010, 10:11 | #5 (permalink) | |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Quote:
1=flash with rm392 2=write pm 3= remove filters and put jumper and here is pm | |
The Following 2 Users Say Thank You to zeerik For This Useful Post: |
12-27-2010, 09:15 | #7 (permalink) |
Member: 666540 Status: Offline Thanks Meter: 354 | I done successfully it is now rm392 2680s, unlocked & I removed filters & fixed capacitors. network is working fine. here is log after flash & unlock...... Imei net: 011740000xxxxx Version: SIMLOCK SERVER Provider: Rogers Wireless , Country: Canada Counter: 0/3, 0/10 CONFIG_DATA: 3027200000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 302720 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 [CR1]DCT4PLUS remaining credit: 37 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-392_011740000xxxx_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 011740000xxxxxx Version: SIMLOCK SERVER Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C3ED01A3BDA66 ASIC type: 11 UEM Imei: 011740000xxxxxx Phone Type: RM-392 (Nokia 2680s-2) SW Version: V 06.17 10-03-09 RM-392 (c) Nokia Imei plain: 01174000086358-7 Imei OTP: 011740000xxxxx Product Code: 0564326 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: MR Language Pack: - not available. Imei net: 01174000xxxxxx Version: SIMLOCK SERVER Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to rajeshlehal For This Useful Post: |
07-13-2011, 22:47 | #9 (permalink) |
Freak Poster Join Date: May 2008 Location: kingston 111a molynes road
Member: 767332 Status: Offline Sonork: nickardo Thanks Meter: 22 | it work 10000000000000000000000000000000% just flash with easy cable after it will still say RM 393 with the version change that u had flash it will dont worry about that. now just wright pm to phone and then check the RM version now by typing *#0000# now just unlock and remove fillters and bridge. |
The Following User Says Thank You to nickardo For This Useful Post: |
12-19-2012, 11:29 | #12 (permalink) | ||
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Check the Date of Thread Start, Phone problem solved & repaired OK time ago, Now Phone in Grave Yard, may be. BR, ZUBER | ||
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
