10-13-2009, 14:07 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: BD Age: 34
Member: 909185 Status: Offline Sonork: na Thanks Meter: 338 | 2680s unlock???????? RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35420703376743_BA CK.rpl" Processing file: rm392__56.17.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 11.81 MB Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0056090E:3B8ADA60 Area [01000000-0101FFFF] erased in 1.172 s Area [01020000-01CFFFFF] erased in 2 min 2.157 s Flash programming ... Programming completed in 1 min 10.235 s File Processed in 3 min 26.469 s NOR page size in the phone is 128 K. Formating FS: FILE2 ... Processing file: rm392__56.17.image_ae_uk as CNT [DCT4,DCT4 ALGORITHM] page size: 128 K size: 3.88 MB Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0056090E:3B8ADA60 Area [02180000-02E7FFFF] erased in 4 min 2.704 s Area [02E80000-02FBFFFF] erased in 23.515 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 24.031 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.046 s File Processed in 5 min 16.266 s Processing file: rm392__56.17.ppm_ae as PPM [DCT4,DCT4 ALGORITHM] size: 2.32 MB Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0056090E:3B8ADA60 Area [01D00000-0217FFFF] erased in 57.094 s Flash programming ... Programming completed in 14.750 s File Processed in 1 min 24.796 s Flashing completed in 10 min 25.656 s After Flash Processing ... Reseting Factory Values OK. PhoneType:RM-392 SwVersion: V 56.17 24-03-09 RM-392 (c) Nokia MCU file: rm392__56.17.mcusw Trying to find patch position ...Sorry, no routine found or not supported model ! Phone Type: RM-392 (Nokia 2680s-2) SW Version: V 56.17 24-03-09 RM-392 (c) Nokia Imei plain: 35420703376743-8 Imei OTP: 35420703376743 Product Code: 0582721 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: AE Language Pack: - not available. Imei net: 35420703376743 Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23433F BLOCK 2: 1.LOCKED (MCC+MNC): 23486F Total time to process is 10 min 44.141 s unlock failed why????????? |
2680 unlock | david69 | HWK | 10 | 03-05-2009 05:00 |
rm-392 2680s unlock problem.... | shami | J.A.F. By Jafsupport.com | 5 | 01-15-2009 13:20 |
