09-14-2009, 16:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | 2680s v56.17 unlocked but i have little probllemm, after unlock phone havent networck signal,i hope it is pm problemm,but i need good pm for v56.17 no another version,becouse from v56.14 readed full pm is 175kb and from anodher version exmp v4.56 readed full pm is 16,7 kb please if you can give me pm for 56.17 i will post results |
09-14-2009, 17:55 | #2 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
this is not a pm problem, mxkey working on it so wait like other user http://forum.gsmhosting.com/vbb/showthread.php?t=820667 | |
The Following User Says Thank You to mbiborna For This Useful Post: |
09-15-2009, 06:32 | #3 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | Imei net: 35420703381617 Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23433F BLOCK 2: 1.LOCKED (MCC+MNC): 23486F PhoneType:RM-392 SwVersion: V 56.17 24-03-09 RM-392 (c) Nokia MCU file: rm392__56.17.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 3 ASIC ID: 0x3168 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0045120E:3B8ADA60 Area [01000000-0101FFFF] erased in 1.094 s Area [01080000-0109FFFF] erased in 1.109 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3168 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0045120E:3B8ADA60 Area [01000000-0101FFFF] erased in 1.109 s Area [01080000-0109FFFF] erased in 1.110 s Programming ... Programming completed. Completed in 39.500 s Reading Simlock info ... Imei net: 35420703381617 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to laduka For This Useful Post: |
2680s v56.17 to v6.17 | andre128 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 44 | 03-13-2010 10:48 |
help me unlock my 2680s v56.17 | Temani | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-16-2009 19:50 |
2680s v56.17 unlock done | yasermalik | MT-BOX | 7 | 10-15-2009 04:41 |
2680s v56.17 unlock patch file needed | AY29!4LYF | Cyclonebox | 2 | 08-19-2009 05:45 |
nokia 2680 v56.17 can be unlocked? | dasawdee | Cyclonebox | 2 | 06-25-2009 11:51 |
