07-14-2011, 13:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: INSIDE OUT
Member: 1015414 Status: Offline Thanks Meter: 155 | 2700 no flashchips found 100% ok (ANSWERED) 1.REHEAT RUP IC 2.FLASH IT IN V9.98 HERE IS THE LOGS MXKEY Serial: [FT SCR2000 0] - C084B950 Using device: HTI BOX, FW ver: 00.17 Driver: uhci:hub:ccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0F90010DCC810156E01F6D969E6DB2FCFBD774E1 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F TransmissionMode: DDR&TX2 Processing MCU file: rm561__09.98.mcusw [BB5,BB5 ALGORITHM] size: 19.41 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 1 min 47.437 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 43.375 s Processing PPM file: rm561__09.98.ppm_qa [BB5,BB5 ALGORITHM] size: 6.55 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 28.296 s Flash programming ... Programming completed in 33.578 s file rm561__09.98.image_qa_blac is empty, skipped. Total time for flashing process(boot+erase+write) was 4 min 41.766 s Phone Type: RM-561 (Nokia 2700 classic) SW Version: V 09.98 06-09-10 RM-561 (c) Nokia Imei plain: 35337604915586-1 Product Code: 0579810 Battery voltage: 4969 mV, current: 57 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353376049155861 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BR, JFERRER01 |
07-18-2011, 09:38 | #6 (permalink) | |
Member: 1015414 Status: Offline Thanks Meter: 155 | Quote:
this is international forun so pls speack engish..by the way if you not like the post ignore it i post base on my own experience and i sosle the problem many times..thank you... br, jferrer01 | |
07-18-2011, 09:54 | #7 (permalink) | |
you know the proper solution? if you know share it...... plss read my post before you coment im not saying thats the proper solution..grrrrrrrrrrrrrrrrrrrrrrrrrrr | |
07-18-2011, 09:59 | #8 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
mostly flash chip bga(leg)make this problem need to reball flash chip ur problem will solved but this is not a 100%solution:d | |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
07-18-2011, 10:07 | #9 (permalink) | |
br | |
11-24-2011, 15:25 | #11 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | |
11-24-2011, 15:50 | #12 (permalink) | |
Insane Poster Join Date: Oct 2011 Location: INDIA
Member: 1665645 Status: Offline Sonork: GOVIND Thanks Meter: 4 | Quote:
solution | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
I have a anwser to change the imei 100% working | Gsmhq | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-14-2000 03:29 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
100% unlock1 for Nokia 6150 v5.17 ------,......... | cIVIc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 02:00 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
