Old 10-08-2012, 18:58   #1 (permalink)
Member: 403881
Thanks Meter: 80
2700c can be repaired in this condition?
The log of 2700c is this
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35828303491834-2
Product code: 0579811
Battery voltage: 3917 mV, current: 94 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NIMMIIIIRRFF00000000, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358283034918342
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Set is CONTACT SERVICE can be repaired?
Regards,
Old 10-08-2012, 19:20   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
It's Hardware,
Check Camera & Connector,
Check for Waterlog.
BR,
ZUBER
Old 10-09-2012, 15:20   #3 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Regards,
camera log not fine remove camera and check it solved your problem.
BR.
Arsalan gsm2000.
Page generated in 0.22848 seconds with 7 queries
