11-15-2012, 18:29 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | 2710c-2 flash prob flash it with same version as product code flash complete with usb but not detect phone customer said i pwr phone off after cant pwr it again Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 840762FC05E5597CD739D7CDFD8B47BEAE814E75 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2AF5741A FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35829403358340_CE RT.rpl). CMT PAPUBKEYS HASH: 84CDC75F79F52BBAE46EA3A70C9240861412C480 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 31.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-01FFFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 84CDC75F [RAP Certificate 195 v.1] sent CMT UPDAPP block sent CMT MCUSW block sent CMT GENIO_INIT block sent Programming completed in 16.640 s Processing PPM file: rm586__09.69.ppm_c [BB5,XSR 1.6] size: 5.22 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 6.50 MB CMT FLASH,MuxOneNAND area [02000000-0267FFFF] Flash programming ... Programming completed in 3.719 s Processing CNT file: rm586__09.69.image_c_it_black [BB5,XSR 1.6] size: 11.48 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 77.31 MB CMT FLASH,MuxOneNAND area [02800000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 8.031 s Total time for flashing process(boot+erase+write) was 1 min 20.734 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2AF5741A Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2AF5741A |
11-15-2012, 19:49 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | It's Hardware Issue Remove Camera Check Combo Rap....... BR. Arsalan gsm2000. |
The Following 2 Users Say Thank You to .::MASTER ALONE::. For This Useful Post: |
11-16-2012, 20:55 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Check or Clean LCD & it's Connector for Waterlogs, Flash it again, If not solve then apply Erase from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ Post Reply. BR, ZUBER |
