Old 01-01-2011, 08:55   #1 (permalink)
Member: 1354740
Thanks Meter: 91
2710c security code (ANSWERED)
cant remove even after flash
help
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA is empty.
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35829403028726_PM .rpl"
Processing MCU file: rm586__09.67.mcusw
[BB5,XSR 1.6] size: 24.65 MB
Supported Ids: 2200050920030000, 22000509200C0000
Battery voltage: 4166 mV
Phone type: RM-586
Product code: 0590006
SW version: V 09.67 09-08-10 RM-586 (c) Nokia
LanguagePkg version: V 09.67 09-08-10 RM-586 (c) Nokia MS
Version from phone: 09.67
Version from file: 09.67
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 109FF531
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 820786060D110D53604ADCEC2EDBC0092FB920B3
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
Secondary boot loaded.
FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT
Loading CMT update server data
Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E
Update server code loaded.
Pooling for ADL device OK.
Verifying communication to device OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.4\data\backup\BB5_35829403028726_CE RT.rpl).
CMT PAPUBKEYS HASH: 84CDC75F79F52BBAE46EA3A70C9240861412C480
Storing certificate [NPC, CCC, HWC, RND, R&D] ...
Partitioning....
Partitioning complete
Erase size: 31.88 MB
Flash programming ...
CMT PAPUBKEYS: 84CDC75F79F52BBAE46EA3A70C9240861412C480 (RAP Certificate 195 v.1) written.
Programming completed in 5.516 s
Processing PPM file: rm586__09.67.ppm_ms
[BB5,XSR 1.6] size: 5.09 MB
Erase size: 6.50 MB
Programming completed in 1.125 s
Processing CNT file: rm586__09.67.image_ms_black
[BB5,XSR 1.6] size: 11.35 MB
Erase size: 77.31 MB
Programming completed in 2.672 s
Total time for flashing process(boot+erase+write) was 39.500 s
Device found: nmwcdc\Nokia 2710 Navigation Edition USB Generic, ID: 12576D5A
Flashing completed in 58.141 s
After Flash Processing ...
Reseting Factory Values OK.
Phone Type: RM-586 (Nokia 2710c-2)
SW Version: V 09.67 09-08-10 RM-586 (c) Nokia
Imei plain: 35829403028726-9
Product Code: 0590006
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358294030287269
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 8000000000000002
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Nokia USB ROM detached.
Old 01-01-2011, 10:24   #2 (permalink)
Haider Ali's Avatar
Member: 756333
Thanks Meter: 152
Wait for 10 or 20 minutes,
Your problem will solve.
Old 01-01-2011, 10:29   #3 (permalink)
Cheater -Don't Deal with him-
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,174
..::Brother I think you flash via USB and via usb flashing not support remove security code so you use F-Bus cable or UFC your problem solved by reset user code::..
RIZWANJAT
Old 01-01-2011, 10:38   #4 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
Mate! Try to SCAN your phone "Format File System" and Check on Erase Password then click Format System button. Your problem solve.
Old 01-01-2011, 11:05   #5 (permalink)
syed jewel's Avatar
Member: 1067276
Sonork: 100.1591989
Thanks Meter: 654
bro just reset all factury seting your problem solve 100%
Old 01-02-2011, 03:54   #6 (permalink)
Member: 1354740
Thanks Meter: 91
all post not solved even this
im trying to search success reset pass for this phone NONE.
Old 01-02-2011, 04:32   #7 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
Read Security Code in Imei & Security Section...
you can see the existing security code in this phone!!!
Old 01-02-2011, 06:08   #8 (permalink)
Member: 1354740
Thanks Meter: 91
did u read my post phone cant read code
Old 01-24-2011, 09:16   #9 (permalink)
Member: 15156
Thanks Meter: 73
wer can we find 2710 fbus cable?tanx
Old 02-09-2011, 10:26   #10 (permalink)
ozanah's Avatar
Member: 752357
Sonork: miker cellular centre
Thanks Meter: 22
u can buy it they are sale it already
Old 02-09-2011, 10:31   #11 (permalink)
Member: 15156
Thanks Meter: 73
wer do they sell it everywer only sell usb cable
Old 02-09-2011, 14:19   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
no worry although you only got usb cable.
mxkey support this phone fully by only using usb cable.
stupid coder at next door called this fbus2usb nonses
it's the phone platform that has usb full support, not their own loader, very stupid.
Old 08-05-2011, 13:52   #13 (permalink)
mmcr's Avatar
Member: 281082
Thanks Meter: 5
just tried to connect a phone now, no options for factory resets like when connecting via rj45 cable... only flashing option
Old 08-05-2011, 14:21   #14 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 1,501
RIZWANJAT
thankxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
PIN1/PIN2 CODE Jon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-26-2012 04:40
5110 Security Code Help! cahrisma Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 07-05-2010 09:04
Orange IL, Nokia 5110 GSM codes... rosso11 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-05-1999 21:38
Page generated in 0.25446 seconds with 9 queries
