10-18-2012, 11:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | 2760 after flash imeI ( 01179600052043-7) PLZ HELP ME MT 2760 AFTER FLASHING IMEI 01179600052043-7 AND NOT NETWORCK WORCK HOW TO REPAIR IT? Code: Phone type: RM-258 (Nokia 2760) SW version: V 07.60 10-04-09 RM-258 (c) Nokia Imei plain: 01179600052043-7 Imei OTP: 01179600052043 Product code: 0550624 Cellular system: GSM ASIC ID: 0x3168, type: 11 Ppm Id: IA Language Pack:English,Arabic,Farsi,French,Urdu Master code: 3667701363 Camera config: GR0103D101260C206C02, ver: XXX.XXX warning: DCC corrupted ! Imei net: 01179600052043 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
10-18-2012, 19:16 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
Your phone IMEI is normal search network manual see option no network it's hardware if show network then write pm That's All. BR. Arsalan gsm2000. | |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
10-19-2012, 09:04 | #4 (permalink) |
Freak Poster Join Date: Apr 2012 Location: dubai ++ kerala ++ thalassery
Member: 1745727 Status: Offline Sonork: 100.1617904 Thanks Meter: 66 | br you will poseted atf section your problam then i will give you solution ther ok levit just lesan this your phone need first pm ok then no newor pls chek atf section i will posted ther one image pls doo that then post your resalt mxkey section i have now no mxkey the teem not helping me pls chek yourprobilam ok br thanks |
