Old 04-18-2012, 07:09   #1 (permalink)
andy-r's Avatar
Member: 568295
Thanks Meter: 162
5530c RM-504 Dead revived by MXKEY using USB
Tools;
MXKEY Dongle or HTI
Micro USB Cable
Procedure;
1. Select Nokia USB ROM
2. Click Connect
3. Select BB5 tab
4. Select Firmware
5. Click Flash Button
6. Follow the on screen instruction from software
7. Done.
Thanks...
Old 04-18-2012, 07:36   #2 (permalink)
Member: 1540810
Sonork: 100.1627394
Thanks Meter: 161
Tahnks for report our tools is rocking
Old 04-18-2012, 10:23   #3 (permalink)
manule's Avatar
Member: 786607
Thanks Meter: 66
what for is ppm2?
if ppm 1 allready in
Old 04-19-2012, 20:12   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Originally Posted by manule View Post
what for is ppm2?
You should always use Market drop down to load flash files, you will never ask about this
Old 03-04-2013, 04:17   #5 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
Phone start up failed contact retailer
Phone type: RM-504 (Nokia 5530 XpressMusic)
SW version: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia
ApeCoreSw: V 40.0.003
Imei plain: 35830703764496-7
Product code: 0578168
Battery voltage: 4779 mV, current: 191 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
Old 03-04-2013, 06:32   #6 (permalink)
Member: 852547
Sonork: 100.1621506
Thanks Meter: 40
Ur rpl is damaged, if u have back-up, plz write it otherwise get rpl
Old 03-04-2013, 07:11   #7 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Language Pack:
- not available.
SIMLOCK invalid!
Bro.
You have Backup RPL or Simlock ?
If not, then have to buy Factory RPL.
BR,
ZUBER
nokia nse-spv8 by zulea rothmanns Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-12-2000 07:52
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? telefonman Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-13-2000 20:06
have nokia lock 2 solution by cable oskarcore Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-29-1999 22:49
how can we use *.scr files to unlock shadow77 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-27-1999 03:13
Page generated in 0.18535 seconds with 9 queries
