Old 02-22-2012, 15:24   #1 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
3110 flash problem (fbus pins damaged)
i have a 3110 fbus pins damaged
initial problem music player
error flashing
now phone is totally dead
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C085DD7F
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00012FFC
Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.70
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
Processing MCU file: rm237__07.30.mcusw
[BB5,BB5 ALGORITHM] size: 14.49 MB
Supported Ids: 0103192101001101, 010C192101001101
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
CMT EM0 ID: 00000232
CMT EM1 ID: 00000353
CMT PUBLIC ID: 1E20010742B87D56FDF7C14BBE984A36DEAA9C91
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID: 191EC665DFAAF68F
Flashing CMT Update Server Data, ULO: 0x38C0 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 472EEA3
Verifying communication to device...
ERROR: Could not verify communication !
Failed to set phone to flashmode, possible reason: Update Agent not running or PASUBTOC corrupted !
Please recover phone using FBUS.
The Following User Says Thank You to luckymobile jalandhar For This Useful Post:
Old 02-22-2012, 16:01   #2 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 275
change the usb cable otherwise you need a good fbus cable
The Following User Says Thank You to irfan_gsm For This Useful Post:
Old 02-22-2012, 16:08   #3 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
i have more than 10 fbus cables problem is phone's fbus points are damaged
Old 02-22-2012, 17:18   #4 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 275
i already recover two 3110c phones with USB cable totally dead when power cut while flaashing.
Old 02-22-2012, 18:34   #5 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
any special trick ???????
Old 02-23-2012, 04:00   #6 (permalink)
mridulnandy's Avatar
Member: 1134419
Sonork: 100.1621725
Thanks Meter: 452
This is FBUS pinout of 3110c
But better to flash with USB with MXKEY
For USB pinout read this
http://pinouts.ru/CellularPhones-Nok...2_pinout.shtml
or
1 VCC Red VCC
2 D- White DATA -
3 D+ Green DATA+
x n/c n/c or connected to GND (may be via resistor). Used as a cable detection pin.
5 GND Black GND
Old 02-23-2012, 04:30   #7 (permalink)
Asia_Phone's Avatar
Member: 1300241
Sonork: 100.1626973
Thanks Meter: 356
use firmware ver.7.30 for this error.
Old 02-23-2012, 04:33   #8 (permalink)
Member: 1721729
Sonork: 100.1623685
Thanks Meter: 28
jus flash with mxkey using data cable it will be done
Old 02-23-2012, 12:36   #9 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
look my first post carefully i told i am flashing with usb cable
Old 02-23-2012, 12:42   #10 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
above logs are of version 7.30
Old 02-23-2012, 12:53   #11 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. as it was music player problem & if its dead after flashing with this error:Verifying communication to device...
so replace retu ic then it will be flash ok with usb cable. your phone will be on with working music player.
Old 02-23-2012, 13:39   #12 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
phone died while flashing so no chance of hardware
Old 02-23-2012, 13:44   #13 (permalink)
Member: 1504476
Sonork: 100.1601678
Thanks Meter: 12
downgrade it then flash
Old 02-23-2012, 15:15   #14 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
possible to downgrade with usb cable ??????
Old 02-23-2012, 15:26   #15 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. i seen your logs, when phone is having hardware problem it will die in between flash program, remember this & do the job like that. have a good luck..............
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
fbus-mbus ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-05-1999 13:46
Page generated in 0.22088 seconds with 9 queries
