Old 02-27-2010, 11:15   #1 (permalink)
Member: 1086393
Thanks Meter: 768
3110-security test failed!!!
SCAN--
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
PM AUTH--
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID),  hello 117.205.192.176
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Scanning local SX4 Card ...
No SX4 Card found.
No SX4 Card found.
REPAIR S/D
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 54.953 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_356**************_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
Updating SIMLOCK...OK
S/D AUTH & PM--
Restarting phone ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized :)!
Writing PM from Node ...
Section: 1
 - Key: 0, size 114 bytes written.
 - Key: 2, size 98 bytes written.
 - Key: 4, size 110 bytes written.
 - Key: 6, size 98 bytes written.
 - Key: 8, size 110 bytes written.
 - Key: 13, size 98 bytes written.
 - Key: 16, size 86 bytes written.
 - Key: 18, size 86 bytes written.
 - Key: 20, size 86 bytes written.
 - Key: 25, size 4 bytes written.
 - Key: 29, size 6 bytes written.
 - Key: 34, size 80 bytes written.
- 308 skipped
Section: 309
 - Key: 0, size 4 bytes written.
 - Key: 1, size 2 bytes written.
 - Key: 2, size 12 bytes written.
 - Key: 4, size 12 bytes written.
 - Key: 5, size 12 bytes written.
 - Key: 7, size 12 bytes written.
 - Key: 8, size 12 bytes written.
 - Key: 17, size 12 bytes written.
 - Key: 22, size 12 bytes written.
Completed in 3.344 s
SIMLOCK_TEST passed
RECOVER CERT
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 14000215433A7D56FDBA6C6121C5F96BD34CBBEE
ASIC MODE ID: 00
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 9.11.1 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981  - 0000 6A21 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM]  version: 9.17.0 revision: 0.0 size: 0x22E90
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Reading RAP NPC  (0x168 bytes)
Begin Certificate Request ...
Connecting to server ...OK, Login ...
Query done with status: OK
Updating PRODUCTCODE (0566963)... OK
Updating CMLA_KEY...OK
Updating WMDRM_PD...OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Updating CMT  NPC ...OK
Updating CMT  CCC ...OK
Updating CMT  HWC ...OK
Certificate programmed successfully !
SIMLOCK_TEST passed
I DID ERASE EDITING REPLACING HWC,CCC ETCCC
BUT FAILED!!
Old 02-27-2010, 11:35   #2 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
1 rd cert with ufs
2 erase with file erase bb5 with ufs
3 full flash again with ufs
4 write cert only npc with ufs
5 repair sd with mx key
6 S/D AUTH
7 write full pm without 308
8 write rpl without npc by mx key
100% work tested by me
br;
Old 02-27-2010, 11:49   #3 (permalink)
Member: 1086393
Thanks Meter: 768
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
THIS IS WAT I DID--I THINK ITS ENOUGH
Old 02-27-2010, 19:25   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,774
what result in " BB5 secure Validation " ?
some phone have unique security.
try this pm after "Super SD Auth"
RM-237 3110
br,
The Following User Says Thank You to Andra For This Useful Post:
5300 and 3110 security test failed kamal07 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 05-12-2010 09:55
3110 security test failed SAN INFOTECH MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 03-24-2010 15:55
3110 security test failed ? GSMBALOCH MXKEY Nokia Flasher and Unlocker (by Alim Hape) 19 03-13-2010 21:55
3110 security test failed.. help pls appu2009 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-19-2010 11:03
security test failed 3110 c help gopalhot MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-04-2010 14:12
Page generated in 0.28336 seconds with 8 queries
