08-13-2010, 12:50 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Pakistan
Member: 775524 Status: Offline Sonork: 100.1608849 Thanks Meter: 125 | 3110 SECURITY_TEST failed? SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35606103615094-6 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356061036150946 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF ) |
The Following User Says Thank You to Nabeel khan For This Useful Post: |
08-13-2010, 15:51 | #7 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | br, scurity test fail. only one method that write modify pm 1 & 309. if not solve, no way. no result if use others way. 100 times tested me. each & every method i already aplied more and more time. but no result. i have one 3110c CONTACT SERVICE FOR SCURITY TEST FAILED. thanks |
08-13-2010, 16:51 | #8 (permalink) | |
Freak Poster Join Date: Mar 2007
Member: 470646 Status: Offline Thanks Meter: 58 | Quote:
08-13-2010, 22:58 | #9 (permalink) |
Freak Poster Join Date: May 2008 Location: Bangladesh (Sezan point) Age: 43
Member: 772645 Status: Offline Sonork: 100.1591509 Thanks Meter: 176 | 1. open your backup rpl with notpad 2. COPY HWC ,CCC DATA on working phone and past your backup rpl where HWC,CCC data then write modified rpl 3. update sp data (unlock phone) if no work do sx4 write 1-309 field then scan phone if no work then unlock it will be ok br, dreams_bd |
09-22-2010, 16:33 | #12 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india
Member: 729723 Status: Offline Thanks Meter: 211 | Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 29 (6 bytes) Warning: failed to write 1 - 34 (80 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 1.563 s |
09-22-2010, 17:59 | #13 (permalink) | |
Freak Poster Join Date: May 2006 Location: Munyanja
Member: 279790 Status: Offline Sonork: icq: 648661016 Thanks Meter: 25 | Quote:
SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...) Now all SD repair should work well. Here is general repair procedure. It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....). It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones. 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model 5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here: RapidShare: 1-CLICK Web hosting - Easy Filehosting | |
09-23-2010, 06:02 | #14 (permalink) | |
Freak Poster Join Date: May 2010 Location: realphone_jl_pahlawan_sulsel
Member: 1303694 Status: Offline Thanks Meter: 99 | Quote:
01-20-2011, 10:40 | #15 (permalink) |
Freak Poster Join Date: Feb 2007 Location: GONDAL
Member: 446289 Status: Offline Thanks Meter: 106 | 3110 contec service problem not solve Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1E30010BC2787E56E7BAC42747F3C47C5C7692B0 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Original Imei: 35196303325990 Original Product code: 0581523 Bluetooth ID: 00247D6DA051 Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35196303325990-8 Product Code: 0514950 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 351963033259908 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED than i try to this 353780005379471 352524003412528 First method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Repair SIMlock with MXKey 6 - Repair Superdongle with MXKey 7 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) The second method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Lock the by phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 6 - Repair SIMlock with MXKey 7 - Repair Superdongle with MXKey 8 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) Third method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Erase Eeprom Section: Flashing-> Advance-> GetAddress, Disable Safe Erase. Enable Eeprom Part only, Click Erase. 3 - Locke the phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 4 - Repair SIMlock with MXKey 5 - Repair Superdongle with MXKey 6 - Super SD Auth, and finally write Full PM(without Field 308-120) [B](If required Recover Cert) __________________ but problem is same pls help meeeeeeeeeeeee |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
HOW UNLOCK 3110 ? | igor_m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-19-2000 17:37 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
