03-02-2010, 11:53 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 812422 Status: Offline Thanks Meter: 18 | 3110 switch off after 3 min Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35602903777647-2 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356029037776472 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to rpssana For This Useful Post: |
03-02-2010, 11:58 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | this is your problem SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. repair SD then write good pm |
The Following User Says Thank You to rea1One For This Useful Post: |
03-02-2010, 12:00 | #3 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 59
Member: 185776 Status: Offline Thanks Meter: 73 | Repair sd,sx4,write rpl pm set will ok http://forum.gsmhosting.com/vbb/showthread.php?t=920409 |
03-02-2010, 12:02 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Quote:
03-03-2010, 05:58 | #9 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1195068 Status: Offline Thanks Meter: 8 | hello bro i have samsung x460 battery not save problem any one have solution post me [email protected] |
03-03-2010, 05:58 | #10 (permalink) | |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | bro must b check Quote:
here is ur all prob solutions \SD Repair\Security Repair\SimLock Invalid\All Solution By MX-KEY http://forum.gsmhosting.com/vbb/show...35#post5383535 check & post Result Regard: GSM_3GN | |
Nokia 5800 switch off after 3 min. | Nirmal_571 | Universalbox | 4 | 01-16-2010 19:55 |
Nokia 5800 switch off after 3 mins. | Nirmal_571 | Nokia Hardware & Hardware Repair | 4 | 01-16-2010 18:30 |
5310 Problem Switch off after 15 mins | xahin | Nokia Base Band 5 ( BB-5 ) | 4 | 11-18-2009 07:38 |
5310 Problem Switch off after 15 mins | xahin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 11-16-2009 13:15 |
N80 Switches off after 20 mins and not charge | peetsy | Nokia Base Band 5 ( BB-5 ) | 0 | 06-28-2009 22:52 |
