Member: 172261
Thanks Meter: 364 | 3110c after BB5 SW downgrade fix the phone after flash to v7.21 when power on after show NOKIA then turn off
try many method but still same...
finally try with bb5 sw downgrade fix Quote:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 12500103681E7A56651529CAC4E1F5EB5DBC236E
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Reading RAP NPC (0x168 bytes)
Imei: 35308102971731
NPC_DATA saved OK
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35308102971731_NPC.RPL"
Erasing CMT NPC ... OK
Applying BB5 SW Downgrade patch ...
ERROR: Phone not responding !
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Updating CMT NPC ...OK
Programming Status: [NAND ERROR: 000508000E000000008B9300008B00
| the phone alive now but why i check the imei with *#06# is 12345610654321?
but if i check with *#92702689# it still 35308102971731 before this [bus check] also 35308102971731 |
