02-13-2010, 12:19 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: lahore
Member: 188574 Status: Offline Sonork: 100.1590742 Thanks Meter: 751 | 3110c in Bus check showing Super Dongle ok but in SD auth test showing currepted I got phone with restarting problem. When switch on its blink and off.. I done software. Its showing ok everything..phone when attach with box can switch o. But with battery cannot on. and even not showing charging.. THen i read PM and want to write back with SD Auth.. but showing like this.. PHP Code: [/COLOR] PHP Code: But advice me regarding this.. 1- switch i made short. (As also i was thinking may be its switch problem) 2- Charging not showing 3- But with box its entering in TEST Mode and LOCal Mode and even can on I need your kind suggestion Br Naveed Yousaf |
3110c no network after repair super dongle | dilipnachna | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 04-17-2010 05:34 |
..::error in bus check always unknown id::.. | HUM | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 07:36 |
mx key error in bus check | xkhpkiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-27-2010 11:50 |
3110c dead-flashing ok-but in it local mode failed-which ic? | zone2 | Nokia Base Band 5 ( BB-5 ) | 4 | 11-18-2008 06:36 |
