12-31-2009, 06:50 | #6 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35685202867413-7 Product Code: 0550691 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2008-11-12T12:08:09Z SW Version: 07.21 Variant Version: 006 ProductProfile: RM237_0550691_07.21_006.spr Simlock: 0550691_simlock.bin Imei net: 356852028674137 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF this procedure all so i do it but did after same condition cs what to do next bro br. | |
12-31-2009, 07:42 | #7 (permalink) | |
Temporary banned !! Join Date: Jan 2007 Location: RAJASTHAN
Member: 438204 Status: Offline Sonork: 100.1602320 Thanks Meter: 269 | Quote:
Just Write modify pm with SX4 | |
The Following User Says Thank You to moyalaslam For This Useful Post: |
12-31-2009, 12:05 | #11 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | this is pm problem not a other write pm with sx4 problem is solv i tested maney time |
The Following User Says Thank You to ranagaurav For This Useful Post: |
12-31-2009, 12:10 | #12 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | brother you see this link very useful here http://forum.gsmhosting.com/vbb/showthread.php?t=886756 |
01-02-2010, 05:40 | #13 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | hello bro thanks for goods commands but after write sxs4 pm set is contact service .what is this problems i did solve so many sets but it is not solve this procedure what can i do know? i totally confused to requer this problems |
01-02-2010, 06:01 | #14 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | Quote:
if not solved then do these method unlock and update your sim lock then sx4 and pm i solved many with this method POST REPLY IF YOU TRY THIS METHOD | |
The Following User Says Thank You to rakesh15 For This Useful Post: |
3110c contact service how to ? | gsmsikar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 23 | 03-05-2010 11:24 |
3110c - CONTACT SERVICE due to HWC empty | sonu_to88 | Nokia Base Band 5 ( BB-5 ) | 0 | 02-23-2010 18:33 |
3110c contact service how to ?[OLD POST] | gsmsikar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 21 | 02-08-2010 17:29 |
3110c contact service how can solved by hardwer | jabed_net | Nokia Hardware & Hardware Repair | 0 | 12-27-2008 20:26 |
7210 contact service HOW TO FIX?????? | essojay | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 05-14-2006 17:09 |
