Old 10-20-2010, 17:00   #1 (permalink)
Member: 1015645
Thanks Meter: 114
3110c contect service plz help me mxkey team
here is mxkey logs plz help me
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35318303332647-8
Product Code: 0544343
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353183033326478
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following User Says Thank You to zeedan For This Useful Post:
Old 10-20-2010, 17:04   #2 (permalink)
Member: 901335
Sonork: 100.1652281
Thanks Meter: 151
pm auth and write good pm . problem will solve .
Old 10-20-2010, 17:10   #3 (permalink)
Member: 1422879
sx4 >>> write pm 1-309 or use load RFBB from server.....
Old 10-20-2010, 19:06   #4 (permalink)
Member: 950629
Thanks Meter: 105
1. flash higher version
2. downgrade the phone
if not solved
3. pm auth and write good pm
Old 10-20-2010, 19:29   #5 (permalink)
nomi_42us's Avatar
Member: 500844
Sonork: 100.1680109
Thanks Meter: 285
just write good pm using sx4....
Old 10-21-2010, 05:52   #6 (permalink)
Member: 1144271
Sonork: kuldeep_sharma2k7
Thanks Meter: 62
bro try all selution then erase pm and write 1&308pm area with sd auth
Old 10-21-2010, 06:00   #7 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
if not solved
so what
just try to write 1,309 pm via sx4 auth
no need to erase,flashing anything first time
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 10-21-2010, 06:05   #8 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
if these all option not work then backup ur phone inclouding pm and erase ur phone then flash write pm 1-309 or use load RFBB from server..... post reselut
Old 10-21-2010, 06:38   #9 (permalink)
jasperali's Avatar
Member: 756719
Thanks Meter: 80
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
tick rf/bb from server and do super sd auth and press write aftrer pm authunication.....thats it..post result
Old 10-21-2010, 06:55   #10 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
read it.........
http://forum.gsmhosting.com/vbb/f550...rvice-1054998/
Old 10-21-2010, 07:11   #11 (permalink)
bipugunjan's Avatar
Member: 526223
Sonork: 100.1605395
Thanks Meter: 106
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
Using cached productData[0D40001190987C5638F49CC67B5852FBDA22A6DC] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Elapsed: 11.297 s (session timeout out after 3 second)
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...Connection timed out
Retrying ...
mr.manole.............................???????????? ??????
Old 10-21-2010, 07:42   #12 (permalink)
bipugunjan's Avatar
Member: 526223
Sonork: 100.1605395
Thanks Meter: 106
no response..................................???
Old 10-21-2010, 07:57   #13 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 97,265
Change to host 2 or 3 or 4.
Old 10-21-2010, 08:12   #14 (permalink)
bipugunjan's Avatar
Member: 526223
Sonork: 100.1605395
Thanks Meter: 106
SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.3
Retrying ...
Retrying ...
Authenticating using [MX] security server ...
same result every host............now?
Old 10-21-2010, 08:51   #15 (permalink)
bipugunjan's Avatar
Member: 526223
Sonork: 100.1605395
Thanks Meter: 106
i lost my customer...............
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 1.50468 seconds with 9 queries
