Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 02-27-2010, 13:58   #1 (permalink)
ZubairArain's Avatar
Member: 751908
3110c flash problem !!!!
Using device: J.A.F, FW ver: 01.B2
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Processing file: rm237__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2C800101CF517E560D062CEBFD189BFDAE2FE70E
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Storing certificate ...OK
Total erase size: 16.37 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00020000-0007FFFF]
CMT NOR area [00080000-000DFFFF]
CMT NOR area [00100000-001FFFFF]
CMT NOR area [00200000-0031FFFF]
CMT NOR area [00320000-0105FFFF]
CMT NOR area [01060000-01067FFF]
CMT NOR area [01068000-0107FFFF]
erased in 10.547 s
Flash programming ...
CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
Error chk C7012D0103CD
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x002B0400, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 44.484 s
RX Buffer: C7012D0103CD00
using GPG 7 pin Fbus cable. HELP
Old 02-27-2010, 13:59   #2 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
JUST CLICK ON FASTFLASH AND AGAIN TRY TO FLASH
WBR
sahil2000ind
Old 02-27-2010, 14:03   #3 (permalink)
jakkarzoya_2511's Avatar
Member: 613242
Sonork: 100.1626311
Talking hi bro
try to flash with usb 100% work post reply
Old 02-27-2010, 14:05   #4 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
only way like other tools ..cyclone r best this movment..................
Old 02-27-2010, 14:07   #5 (permalink)
Member: 751908
WBR
sahil2000ind
Same with FAST FLASH mode.
Old 02-27-2010, 14:18   #6 (permalink)
Member: 751908
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3
RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
RAP EM0 ID: 00000232
RAP EM1 ID: 00000353
RAP PUBLIC ID: 2C800101CF517E560D062CEBFD189BFDAE2FE70E
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
RAP ROM ID: 191EC665DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes
[ADL]
Timeout, no usb device found.
Flashing terminated with error(s) in 34.750 s
Old 02-27-2010, 16:12   #7 (permalink)
Member: 751908
First flash with v5.50 than again with 7.21. OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
erased in 1 min 20.875 s
Programming completed in 2 min 55.594 s
Processing file: rm237__07.21.ppm_mea4 as PPM
[BB5,BB5 ALGORITHM] size: 2.77 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Total erase size: 4.62 MB
CMT NOR area [01080000-0151FFFF]
erased in 19.750 s
Programming completed in 41.719 s
Processing file: rm237__07.21.image_mea4 as CNT
[BB5,BB5 ALGORITHM] page size: 64 K size: 3.25 MB
NOR page size in the phone is 128 K.
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Total erase size: 10.75 MB
CMT NOR area [01520000-01FDFFFF]
erased in 40.390 s
Converting UCP blocks to 128 K.
Programming completed in 32.500 s
Flashing completed in 7 min 3.734 s
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35196303058072-8
Product Code: 0550573
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351963030580728
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 7 min 22.437 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 5.812 s
Old 02-27-2010, 16:48   #8 (permalink)
metals's Avatar
Member: 811779
Chaudhary sab ya Mian sab kya baat hay app ki
nice information
3110c flashing problem tattoum Nokia Base Band 5 ( BB-5 ) 13 10-31-2010 11:15
3110c flashing problem reynant J.A.F. By Jafsupport.com 5 11-26-2007 00:39
3110c flashing problem with UFS hristo5 Nokia Base Band 5 ( BB-5 ) 3 11-15-2007 11:50
Page generated in 0.74206 seconds with 11 queries
