Old 12-13-2010, 15:55   #1 (permalink)
Member: 926856
Sonork: sandeepmvandematrm
Thanks Meter: 19
3110c flashing problam
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
Processing MCU file: rm237__07.30.mcusw
[BB5,BB5 ALGORITHM] size: 14.49 MB
Supported Ids: 0103192101001101, 010C192101001101
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1470011402267E561F1A83C10444BBAC7D98F3C1
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.781 s
CMT NOR area [000006C0-0001FFFF] erased in 0.157 s
CMT NOR area [00020000-0007FFFF] erased in 0.187 s
CMT NOR area [00080000-000DFFFF] erased in 0.188 s
CMT NOR area [00100000-001FFFFF] erased in 0.328 s
CMT NOR area [00200000-0031FFFF] erased in 0.360 s
CMT NOR area [00320000-0105FFFF] erased in 3.140 s
CMT NOR area [01060000-01067FFF] erased in 0.156 s
CMT NOR area [01068000-0107FFFF] erased in 0.156 s
Flash programming ...
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00020300, Result: 0010
Flashing terminated with error(s) in 48.797 s
RX Buffer: C7012D0103CD000010000000F172
The Following User Says Thank You to Pankaj JOSHI For This Useful Post:
Old 12-13-2010, 16:05   #2 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
use usb flshing
br
deepak
Old 12-13-2010, 16:06   #3 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
use usb flshing
br
deepak
Old 12-13-2010, 16:17   #4 (permalink)
Member: 926856
Thanks Meter: 19
with usb same problam
Old 12-13-2010, 16:41   #5 (permalink)
Member: 926856
Thanks Meter: 19
still same problam sir plz help
Old 12-13-2010, 17:17   #6 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Tick SKIP ERASE
Tick FAST FLASH
Most probably yours will be OK i think.
Old 12-13-2010, 18:01   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hello,
seems you're using bad cable. please check.
Old 12-13-2010, 18:54   #8 (permalink)
Member: 1467129
use usb flshing........................................... ........................
Old 12-13-2010, 19:34   #9 (permalink)
Member: 727810
Sonork: 100.1627301
Thanks Meter: 167
u have ufs then do this its working many tumes 4 me sometimes its not a cable problem bcoz with this cable u flash many handset but sometime this error comes so here is u r solution
just tick on fast flash & skip erase & flash just mcu file then uncheck on skip erase & flash ppm & cnt u r handset will be 100% working 4 me or other solution is flash with mt or jaf
Old 12-13-2010, 19:51   #10 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Thanks Meter: 766
check your cable brother
try to use any of the below mentioned cables and flash ur phone if your still face problem then reply back
3109C (RM274)
3110C (RM237)
3500C (RM272)
6300 (RM217)
6300I (RM337)
6301 (RM322)
Old 12-14-2010, 06:11   #11 (permalink)
manzoor300's Avatar
Member: 817733
Sonork: 100.1605504
Thanks Meter: 491
Thumbs up 311oc flashg problam
ufsbox fbs.cable flash olny mcu .skip erase complet.tham flash ppm.cnt .skip erase ...set 100000...okkk
Old 12-14-2010, 06:11   #12 (permalink)
manzoor300's Avatar
Member: 817733
Sonork: 100.1605504
Thanks Meter: 491
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Old 12-14-2010, 13:46   #13 (permalink)
Member: 395389
Sonork: no idi
Thanks Meter: 193
good job very hard work many thanks
Old 12-14-2010, 15:54   #14 (permalink)
Member: 926856
Thanks Meter: 19
sir my cable is OK becouse other 3110 flashing properly
Old 12-14-2010, 18:47   #15 (permalink)
sunny box's Avatar
Member: 1456392
Sonork: 100.1606104
Thanks Meter: 115
try to dead usb flashing bro...
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Nokia Flash Content. Phantom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-01-2000 23:28
Page generated in 0.34911 seconds with 9 queries
