02-20-2010, 17:26 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Pakistan
Member: 775524 Status: Offline Sonork: 100.1608849 Thanks Meter: 125 | 3110c nd 7210c contect service[SOLVED] No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request ) plz give me solution i have 3110c nd 7210c |
02-20-2010, 17:43 | #2 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | Quote:
The Following User Says Thank You to ashraf_bcs For This Useful Post: |
02-20-2010, 18:47 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
Repair Super dongle first than press super SD auth than write full pm | |
The Following User Says Thank You to hasnain For This Useful Post: |
02-21-2010, 10:36 | #5 (permalink) |
Member: 775524 Status: Offline Sonork: 100.1608849 Thanks Meter: 125 | this is my log when i use super sd auth(Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V 07.21 05-11-08 RM-237 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized nd after that when i use pm auth then show this error(No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request) |
02-21-2010, 10:42 | #6 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: IN MY PC
Member: 745721 Status: Offline Sonork: 100.1605292 Thanks Meter: 2,390 | Quote:
02-21-2010, 10:49 | #7 (permalink) |
No Life Poster Join Date: Jul 2008 Location: H.DALAA Age: 48
Member: 820444 Status: Offline Sonork: 100.1680641 Thanks Meter: 466 | hello this is phone info : Code: Version Info: MCU SW version: V 06.60 07-03-08 RM-240 (c) Nokia HW version: 2000 RFIC version: 17141715 DSP version: ICPR71_08w09 LCD version: SHARP PPM version: V 06.60 07-03-08 RM-240 (c) Nokia F Retu version: 15 Tahvo version: 22 Content Pack version: Content: f V 06.60 07-03-08 RM-240 (c) Nokia Product Info: Production serial number: KOG238905 Product code: 0549733 Module code: 0203327 Basic production code: 0543753 Long production SN: 0 Serial Numbers: IMEI plain: 35................... IMEI spare to net: 3A 45 38 07 02 45 07 IMEI SV to net: 33 45 38 07 02 45 07 30 F3 Other Info: Model : Nokia 6500s-1 (Connect Phone) CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA IV/WCDMA IV/WCDMA V BSI: 4.0 KOhm Imei net: 3...................... Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF. phone in contact service . how to solved this problem ? thank's in adv. ----- lahdache |
02-21-2010, 10:56 | #8 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 722271 Status: Offline Thanks Meter: 23 | try this 1. write full pm 2. make repair simlock 3. Sd repair 4. Sd Auth 5. Write Pm 1 - 309. good luck // 4 |
The Following 2 Users Say Thank You to ichals For This Useful Post: |
02-21-2010, 11:34 | #9 (permalink) |
Member: 820444 Status: Offline Sonork: 100.1680641 Thanks Meter: 466 | solved like this : - auth SD - restor SL - write full PM. ----- thank's -------- lahdache |
The Following 2 Users Say Thank You to lahdache For This Useful Post: |
02-21-2010, 12:30 | #10 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Quote:
my dear nabeel khan your 3110c this guide ( bb5>>sevice>>imei&securty>>imei rebuild>>npc back up>>reset npc>>repair sd>>write rpl>> now go to simlock>>repair splock now your fone is ok and your 7210c ((bb5>>sevice>>imei&securty>>imei rebold>>baup rpl all section>> repair sd ) now go to pm section only super sd auth betan clik injoy your fone now | |
02-21-2010, 12:36 | #11 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Sir Same Problem With My Rm-237 Nokia-3110c Contact Service............. Imei net: 356815025380875 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.12027, Date: 06-02-2010 Product: V 07.21 05-11-08 RM-237 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 13.094 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_356815025380875_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 356815025380875 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF After Contact Service Last edited by ...:::::NP™:::::...; 02-21-2010 at 12:43. |
7210c contect service how to solve | Irshad Alam | Nokia Base Band 5 ( BB-5 ) | 11 | 06-27-2010 07:38 |
7210c contect service problem | TUR@N ALAM | J.A.F. By Jafsupport.com | 7 | 01-23-2010 19:09 |
7210c contect service solved | waqas_ali601200 | Universalbox | 2 | 12-27-2009 01:10 |
7210c Contect service help | thethi | HWK | 7 | 07-03-2009 07:40 |
7210c contect service | ranagaurav | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 05-25-2009 05:39 |
