Member: 1188409
Sonork: 100.1616589 Thanks Meter: 270 | 3110c Nokia Logo Hang 3110c Nokia Logo Hang
Try To Flash 7.30
With Hwk And Mx-box
Results Same
Nokia Logo Hang Restart Then White Disply
Try Also BB5 SW Downgrade Fix Method No Result
Help Me
Here Is Log Quote:
Bus Check MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C085F607
Using device: HTI, FW ver: 00.50, SN: 0000CB5F
Connection status: EHCI:HUB:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2A90010AF3087F564AB3C05D2FE88304CD8043FF
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Original Imei: 35420603714445
Original Product code: 0550542
Bluetooth ID: 0025CF53FBA8
SIMLOCK PA identifier:
[0] PA_SL
After Flash
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
CMT PAPUBKEYS is blank/erased.
Processing MCU file: rm237__07.30.mcusw
[BB5,BB5 ALGORITHM] size: 14.49 MB
Supported Ids: 0103192101001101, 010C192101001101
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00020000-0007FFFF]
CMT FLASH,NOR area [00080000-000DFFFF]
CMT FLASH,NOR area [00100000-001FFFFF]
CMT FLASH,NOR area [00200000-0031FFFF]
CMT FLASH,NOR area [00320000-0105FFFF]
CMT FLASH,NOR area [01060000-01067FFF]
CMT FLASH,NOR area [01068000-0107FFFF]
erased in 0.165 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
NOR: OK
Programming completed in 1 min 17.314 s
Processing PPM file: rm237__07.30.ppm_b
[BB5,BB5 ALGORITHM] size: 3.20 MB
Erase size: 4.62 MB
CMT FLASH,NOR area [01080000-0151FFFF]
erased in 24.026 s
NOR: OK
NOR: OK
Programming completed in 13.423 s
Processing CNT file: rm237__07.30.image_b_era_pl2
[BB5,BB5 ALGORITHM] page size: 64 K size: 4.76 MB
Erase size: 10.75 MB
CMT FLASH,NOR area [01520000-01FDFFFF]
erased in 56.764 s
NOR: OK
NOR: OK
Programming completed in 19.913 s
Total time for flashing process(boot+erase+write) was 3 min 19.734 s | |
