03-15-2010, 07:11 | #1 (permalink) | |
Freak Poster Join Date: Oct 2005 Location: Khulna Age: 43
Member: 194917 Status: Offline Sonork: na Thanks Meter: 112 | 3110c Org. IMEI OK but Plain N Net Bad and SECURITY_TEST failed Quote:
How can solved this problame thanks | |
03-15-2010, 08:49 | #5 (permalink) |
Registered User Join Date: Dec 2004 Location: largest democratic country
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | firstly try take the back up if it is saving with og imei then flash it with lower version & restore the rpl certificates etc also check wheather is it not the 3110c pcb may be same type other pcb . |
03-15-2010, 09:29 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: JESSORE, BNGLADESH. Age: 39
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | write rpl and super sd athu write pm 1 and 309 your problem will be solved 1000000% |
The Following User Says Thank You to .::MAHABUB::. For This Useful Post: |
03-15-2010, 09:40 | #8 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Brother listen write this attached rpl next use recovery cert option write 1&309 pm via sx4 ur problem 100%solved post result |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
03-15-2010, 10:02 | #10 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | @ MoiNKhulna in ur RPL problem is here NPC_DATA_9=B08AB8E02B420BB70D45448391EE404F820ABB3 B61386DC89D39A96B519604C4A1C548EED8723C0F use jaf cracked by zulea to write this RPL |
The Following User Says Thank You to hasnain For This Useful Post: |
03-15-2010, 14:34 | #11 (permalink) | ||
Member: 194917 Status: Offline Sonork: na Thanks Meter: 112 | Quote:
sorry its not work ........................... | ||
3110c all info ok but Contact Service Solution ## (ANSWERED) | netunlocker | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 10-15-2011 14:54 |
nokia 3110c sd repair ok but no netwark | MR.MAMUN | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 02-14-2010 10:49 |
Lg mg160 repair imei ok but unlock fail nothing | ruchito | HWK | 5 | 05-16-2009 17:52 |
3110c dead-flashing ok-but in it local mode failed-which ic? | zone2 | Nokia Base Band 5 ( BB-5 ) | 4 | 11-18-2008 06:36 |
