Old 05-15-2010, 06:43   #1 (permalink)
Member: 731314
Sonork: 100.1591813
Thanks Meter: 81
3110c Phone restricted Help........
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1CC000064DC47C56B749F69AA87A2EAAFCE8D880
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Original Imei: 35683302567049
Original Product code: 0550542
Bluetooth ID: 0022FDF38C08
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35683302567049-2
Product Code: 0550691
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356833025670492
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
The Following User Says Thank You to golam_maula For This Useful Post:
Old 05-15-2010, 06:58   #2 (permalink)
GsmVeer's Avatar
Member: 1140401
Sonork: 100.1586294
Thanks Meter: 374
repair superdongle
and unlock
The Following User Says Thank You to GsmVeer For This Useful Post:
Old 05-15-2010, 07:13   #3 (permalink)
Member: 1301933
Sonork: wynn
Thanks Meter: 28
repair superdongle
and unlock
Old 05-15-2010, 07:24   #4 (permalink)
.::VENUGOPAL::.'s Avatar
Member: 1230663
Sonork: 100.1593487
Thanks Meter: 174
4shared.com - online file sharing and storage - download 3110c sd sucessfull.rar
The Following User Says Thank You to .::VENUGOPAL::. For This Useful Post:
Old 05-15-2010, 07:33   #5 (permalink)
Member: 731314
Sonork: 100.1591813
Thanks Meter: 81
repair superdongle
and unlock
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
ERROR: Missing SD BLOCK or PM corrupted !
Old 05-15-2010, 07:39   #6 (permalink)
N93i's Avatar
Member: 760175
Thanks Meter: 41
Unlock directly or repair sl........
Old 05-15-2010, 07:43   #7 (permalink)
Javed ajmeri's Avatar
Member: 424082
Thanks Meter: 128
Arrow 3110 phone restricted
Sd repair then unlock
if not work direct press "superdongle repair "
Old 05-15-2010, 10:26   #8 (permalink)
Member: 731314
Sonork: 100.1591813
Thanks Meter: 81
now my phone open, but after 3 min it go auto off.
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 05-15-2010, 10:32   #9 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
reppiar sd..then unlock simlock. then writ rpl pm..and reset.............
Old 05-15-2010, 10:33   #10 (permalink)
Member: 1230663
Sonork: 100.1593487
Thanks Meter: 174
try this video
Old 05-15-2010, 10:55   #11 (permalink)
Member: 731314
Sonork: 100.1591813
Thanks Meter: 81
I can't do SUPER SD Auth
saw that's
Using cached productData[1CC000064DC47C56B749F69AA87A2EAAFCE8D880] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.0
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 202.56.7.141
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Old 05-15-2010, 11:05   #12 (permalink)
Member: 1295285
pl help get code for nokia 3110 c for restriction code
fcc ID: PPIRM-237
IC:66U-RM-237
353183/03/31056/3
Old 05-15-2010, 11:05   #13 (permalink)
Member: 1086393
Thanks Meter: 771
saw that's
First
UpDate SpLock>Repair SD> Super SD> Write PM 1 & 309 value.
All Should be fine
Old 05-15-2010, 11:11   #14 (permalink)
Member: 731314
Sonork: 100.1591813
Thanks Meter: 81
Originally Posted by Riteshgpt60 View Post
First
All Should be fine
yes, I do Repair SD many time, but no result.
just I lose my credit.
Old 05-15-2010, 11:20   #15 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
repair by make simlock rpl.open attached pm file do super sd auth and write this pm.
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.28677 seconds with 11 queries
