02-04-2010, 00:11 | #1 (permalink) |
Insane Poster Join Date: May 2008
Member: 775334 Status: Offline Thanks Meter: 36 | i cant restore imei 7210c i try write another cert but same i taked rpl backup and made erase after that i restore my backup but cant restore imei please help Imei: 35196203485258 Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0BF000023AA97C56A0EADF6EF90900F766B42BFF ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...failed, Result: 06A0000000317200 Updating PRODUCTCODE (0566806)... OK Updating PSN (DTC186745)... OK Updating HWID (1000)... OK Updating SIMLOCK...Trying to update SUPERDONGLE_KEY ...error 0x0 Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 12345610654321-? Product Code: 0566806 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! |
02-04-2010, 01:31 | #3 (permalink) |
Freak Poster Join Date: Oct 2008 Location: philippines Age: 55
Member: 883572 Status: Offline Thanks Meter: 63 | Open the rpl u created as back up with notepad. Delete everything except the npc part n writ rpl back. Try clock restore imei n point it to the rpl back up |
02-04-2010, 01:59 | #5 (permalink) |
Freak Poster Join Date: May 2007
Member: 507861 Status: Offline Thanks Meter: 69 | AFTER FULL ERASE YOUR PHONE... FULL FLASH remove all rpl back up in mxkey folder put only one rpl back up. the first back up rpl you made then restore imei..after restoring imei restore simlock..procedure same as rpl . now your phone back to sd invalid...tick sd repair after finish sd repair. sx4 auth..write pm..bus check again check the logs if ok.. Last edited by ELOY1024; 02-04-2010 at 02:00. Reason: a |
02-04-2010, 17:59 | #6 (permalink) |
Member: 775334 Status: Offline Thanks Meter: 36 | stiil same i need more help thats my rpl backup [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0566806 PSN=DTC186745 HWID=1000 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303536363930324300000000 NPC_DATA_2=000000000000000000000000250802988495A04 97F710000646F7242000000000BF000023AA97C56 NPC_DATA_3=A0EADF6EF90900F766B42BFFF1DCA5EA5203CD3 0A64D4D95ABCD621F4AB2302604C86BB3A373856E NPC_DATA_4=6BC926A9C623108415C6D2EA000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3315690243585288FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=9726B27C2400000000000000000000000000000 0000000000000000000000000083E71FE9308D9DF NPC_DATA_7=01CF0957E42AC2A73B39CFF0689FCA1C906960A 87811E5AFF0A6EA056C2BADD6A3759F8CD5C3F89A NPC_DATA_8=05AEE5EE36BEEA26085F6D7EB77DB83DFA58186 1F4F8F501C84A05CA33FBD740F4B0E5941B59F804 NPC_DATA_9=4654EF23C2059FF0C0462B47F65FD4E5CE85043 D832C7E65C0DC8B2DF01579F3C6B999D6C97CFE78 HWC_DATA_1=43485743050041500100000025080298B939F84 8FD7C1B00646F7242000000000000000000000000 HWC_DATA_2=000000000000000015F00015B37D57501BEA3C5 91CB233E077BEF147303536363830374300000000 HWC_DATA_3=000000003E06191D444F1AA7F85E49EB346C400 A849CD1CADA475DD83C6C825D9AEE9D62A2CB971A HWC_DATA_4=2DB3225589A987E901E7E82DD218FB20A0EA738 05F5DA074A7AF92B1834BF4014FD2B39882CB54F1 HWC_DATA_5=3D07E604BB8B320B8979B4D0B91D5263DCAA6DB ECC3B48444B55F93FBE04F228C10CF1BCB1149FC2 HWC_DATA_6=1A479678F890D413459871F0FFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF HWC_DATA_7=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CCC_DATA_1=4343434302004150010000009138E094E936204 8C9FB1400399B9800000060010000000000000000 CCC_DATA_2=000000000000000000000000000000000000000 00000000000000000000000003035363638303743 CCC_DATA_3=6080C8470000000000000000010000000E00000 00000000000000000000000000000000000000000 CCC_DATA_4=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_5=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_6=000000000000000000000000000000000000000 0000000008764B7A235FC1DAC433D2BB3F23CA81E CCC_DATA_7=8EC684A6CC253FDF13156F0BFB26E42BA06E656 875B73AEEC888E72E948585BDDA8C8638DDF9E395 CCC_DATA_8=A5D54BB7A0DA551E9E5488EBC7ACE184D01C214 47DE67BF06D34E19DBE0878062D7D81B81DA32550 CCC_DATA_9=234F24C61BB44C44E5A84BD2F4C5F55C82D71EF AFAEB18B0CAF229463F13A77EFFFFFFFFFFFFFFFF CCC_DATA_10=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CCC_DATA_11=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CCC_DATA_12=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CCC_DATA_13=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_1=8D15652AF81FAD349B84440CEAAD97D8DD1 7601F0000000000000000244070000000000000180700 SIMLOCK_DATA_2=000000000050000005FFFFFF00B4000005F FFFFF0118000005FFFFFF017C000005FFFFFF01E00000 SIMLOCK_DATA_3=05FFFFFF0244000005FFFFFF02A8000005F FFFFF000000007FFF6F07FFFFFFFFF800030C03000503 SIMLOCK_DATA_4=000000007FFF6F3EFFFFFFFFC000030F020 00103000000007FFF6F3FFFFFFFFFC000031102000103 SIMLOCK_DATA_5=000000007FFF6F07FFFFFFFF07FE0313080 00503000000007FFF6F07FFFFFFFF07FE031B08000503 SIMLOCK_DATA_6=000000007FFF6F07FFFFFFFFF8000323030 00503000000007FFF6F3EFFFFFFFFC000032602000103 SIMLOCK_DATA_7=000000007FFF6F3FFFFFFFFFC0000328020 00103000000007FFF6F07FFFFFFFF07FE032A08000503 SIMLOCK_DATA_8=000000007FFF6F07FFFFFFFF07FE0332080 00503000000007FFF6F07FFFFFFFFF800033A03000503 SIMLOCK_DATA_9=000000007FFF6F3EFFFFFFFFC000033D020 00103000000007FFF6F3FFFFFFFFFC000033F02000103 SIMLOCK_DATA_10=000000007FFF6F07FFFFFFFF07FE034108 000503000000007FFF6F07FFFFFFFF07FE034908000503 SIMLOCK_DATA_11=000000007FFF6F07FFFFFFFFF800035103 000503000000007FFF6F3EFFFFFFFFC000035402000103 SIMLOCK_DATA_12=000000007FFF6F3FFFFFFFFFC000035602 000103000000007FFF6F07FFFFFFFF07FE035808000503 SIMLOCK_DATA_13=000000007FFF6F07FFFFFFFF07FE036008 000503000000003F007F206F07FFFFF800036803000503 SIMLOCK_DATA_14=000000003F007F206F3EFFFFC000036B02 000103000000003F007F206F3FFFFFC000036D02000103 SIMLOCK_DATA_15=000000003F007F206F07FFFF07FE036F08 000503000000003F007F206F07FFFF07FE037708000503 SIMLOCK_DATA_16=000000003F007F206F07FFFFF800037F03 000503000000003F007F206F3EFFFFC000038202000103 SIMLOCK_DATA_17=000000003F007F206F3FFFFFC000038402 000103000000003F007F206F07FFFF07FE038608000503 SIMLOCK_DATA_18=000000003F007F206F07FFFF07FE038E08 000503000000003F007F206F07FFFFF800039603000503 SIMLOCK_DATA_19=000000003F007F206F3EFFFFC000039902 000103000000003F007F206F3FFFFFC000039B02000103 SIMLOCK_DATA_20=000000003F007F206F07FFFF07FE039D08 000503000000003F007F206F07FFFF07FE03A508000503 SIMLOCK_DATA_21=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_22=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_23=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_25=FFFFFFFF SIMLOCK_KEY_DATA_1=26F00FC9D09EBD091E8AF2ECB8274DF 3C46CC2493E336B383A4691DD1949D145C0068C01F42E4D61 SIMLOCK_KEY_DATA_2=112BB85E6BEC23DD89BD32110E98075 AE8B667C10796B4D5875615F4134D5AC84FF7A304FD7E25C1 SIMLOCK_KEY_DATA_3=1760D632317F07F2F380A8D85F64409 331F92F77 WMDRM_PD_DATA_1=3E1100003C004400450056004300450052 0054002000760065007200730069006F006E003D002200 WMDRM_PD_DATA_2=31002E00300022003E003C004300450052 0054004900460049004300410054004500200074007900 WMDRM_PD_DATA_3=700065003D002200440045005600490043 00450022003E003C0044004100540041003E003C005500 WMDRM_PD_DATA_4=4E00490051005500450049004400200070 007200690076006100740065003D002200310022003E00 WMDRM_PD_DATA_5=4700610041004300430033003100750056 00310042006400710031004F006900680079002B003300 WMDRM_PD_DATA_6=4D003900450042004D002F0055003D003C 002F0055004E004900510055004500490044003E003C00 WMDRM_PD_DATA_7=5000550042004C00490043004B00450059 00200070007200690076006100740065003D0022003100 WMDRM_PD_DATA_8=22003E0051006700630070006F00680064 0063007A00440078004F00380050004B00690079005400 WMDRM_PD_DATA_9=790054007400440032007A005800520077 004F004E002F00370033006D0059006A00310061007900 WMDRM_PD_DATA_10=4E0051005800530032004900540067006 10077002F0036004A007800660067003D003D003C002F00 WMDRM_PD_DATA_11=5000550042004C00490043004B0045005 9003E003C004B004500590044004100540041003E007A00 WMDRM_PD_DATA_12=53002F003300710043002B006F0032005 50036004C00320054004D00470055003200340049003500 WMDRM_PD_DATA_13=5900710031003200340067003D003C002 F004B004500590044004100540041003E003C002F004400 WMDRM_PD_DATA_14=4100540041003E003C004D00530044005 2004D005F005300490047004E0041005400550052004500 WMDRM_PD_DATA_15=5F00560041004C00550045003E0055002 B0053007400560068005500370052007600330031004F00 WMDRM_PD_DATA_16=760062005600320056004100740074003 3004C00660055006B005700780033004D00300079004800 WMDRM_PD_DATA_17=74002B004F006E004C004A0063006F005 A0039007800700048006100770033006C0070006B004300 WMDRM_PD_DATA_18=67003D003D003C002F004D00530044005 2004D005F005300490047004E0041005400550052004500 WMDRM_PD_DATA_19=5F00560041004C00550045003E003C005 30059004D005300490047004E0041005400550052004500 WMDRM_PD_DATA_20=3E0045003100470046003000380058005 A0071002F00300065006800680043003800590051006F00 WMDRM_PD_DATA_21=41007A0059005A006F005700670063003 D003C002F00530059004D005300490047004E0041005400 WMDRM_PD_DATA_22=5500520045003E003C002F00430045005 200540049004600490043004100540045003E003C004600 WMDRM_PD_DATA_23=41004C004C004200410043004B003E003 C0053004500430055005200490054005900560045005200 WMDRM_PD_DATA_24=530049004F004E003E0032002E0034002 E003100310031002E003200310039003C002F0053004500 WMDRM_PD_DATA_25=430055005200490054005900560045005 200530049004F004E003E003C0043004500520054004900 WMDRM_PD_DATA_26=460049004300410054004500200070007 200690076006100740065003D002200310022003E005100 WMDRM_PD_DATA_27=6700630070006F006800640063007A004 40078004F00380050004B00690079005400790054007400 WMDRM_PD_DATA_28=440032007A005800520077004F004E002 F00370033006D0059006A003100610079004E0051005800 WMDRM_PD_DATA_29=53003200490054006700610077002F003 6004A00780066006700490045006200390076002B006F00 WMDRM_PD_DATA_30=790071003100340036004D00300079006 B0042004700370034007300300036007600750044006C00 WMDRM_PD_DATA_31=65004D006300580052004400390078004 D004F0076002B006C0076004B004900390071007A003500 WMDRM_PD_DATA_32=3100460058004900300030007A0071006 7006C0039003C002F004300450052005400490046004900 WMDRM_PD_DATA_33=43004100540045003E003C002F0046004 1004C004C004200410043004B003E003C00430045005200 WMDRM_PD_DATA_34=540049004600490043004100540045002 00074007900700065003D002200470052004F0055005000 WMDRM_PD_DATA_35=22003E003C0044004100540041003E003 C004E0041004D0045003E00370032003100300063002000 WMDRM_PD_DATA_36=530075007000650072006E006F0076006 1003C002F004E0041004D0045003E0020000D000A002000 WMDRM_PD_DATA_37=20003C004D0041004E005500460041004 300540055005200450052003E004E006F006B0069006100 WMDRM_PD_DATA_38=3C002F004D0041004E005500460041004 300540055005200450052003E0020000D000A0020002000 WMDRM_PD_DATA_39=3C004D0041004B0045003E004E006F006 B00690061003C002F004D0041004B0045003E0020000D00 WMDRM_PD_DATA_40=0A00200020003C0044004900530054005 20049004200550054004F0052003E004E006F006B006900 WMDRM_PD_DATA_41=61003C002F00440049005300540052004 9004200550054004F0052003E0020000D000A0020002000 WMDRM_PD_DATA_42=3C004D004F00440045004C003E0052004 D002D003400330036003C002F004D004F00440045004C00 WMDRM_PD_DATA_43=3E0020000D000A00200020003C0053004 5004300550052004900540059004C004500560045004C00 WMDRM_PD_DATA_44=3E0032003000300030003C002F0053004 5004300550052004900540059004C004500560045004C00 WMDRM_PD_DATA_45=3E0020000D000A00200020003C0048004 1005200440057004100520045005F005600450052005F00 WMDRM_PD_DATA_46=4D0041004A004F0052003E0031003C002 F00480041005200440057004100520045005F0056004500 WMDRM_PD_DATA_47=52005F004D0041004A004F0052003E002 0000D000A00200020003C00480041005200440057004100 WMDRM_PD_DATA_48=520045005F005600450052005F004D004 9004E004F0052003E0030003C002F004800410052004400 WMDRM_PD_DATA_49=57004100520045005F005600450052005 F004D0049004E004F0052003E0020000D000A0020002000 WMDRM_PD_DATA_50=3C004600490052004D005700410052004 5005F005600450052005F004D0041004A004F0052003E00 WMDRM_PD_DATA_51=31003C002F004600490052004D0057004 100520045005F005600450052005F004D0041004A004F00 WMDRM_PD_DATA_52=52003E0020000D000A00200020003C004 600490052004D0057004100520045005F00560045005200 WMDRM_PD_DATA_53=5F004D0049004E004F0052003E0030003 C002F004600490052004D0057004100520045005F005600 WMDRM_PD_DATA_54=450052005F004D0049004E004F0052003 E0020000D000A002D0020003C0046004500410054005500 WMDRM_PD_DATA_55=5200450053003E000D000A00200020003 C0043004C004F0043004B003E0031003C002F0043004C00 WMDRM_PD_DATA_56=4F0043004B003E000D000A00200020003 C004D00450054004500520049004E0047003E0031003C00 WMDRM_PD_DATA_57=2F004D00450054004500520049004E004 7003E0020000D000A00200020003C004C00490043004500 WMDRM_PD_DATA_58=4E00530045005F004100430051003E003 1003C002F004C004900430045004E00530045005F004100 WMDRM_PD_DATA_59=430051003E0020000D000A00200020003 C004C004900430045004E00530045005F00530059004E00 WMDRM_PD_DATA_60=43003E0031003C002F004C00490043004 5004E00530045005F00530059004E0043003E0020000D00 WMDRM_PD_DATA_61=0A00200020003C0045004E00430052005 9005000540049004F004E003E0030003C002F0045004E00 WMDRM_PD_DATA_62=4300520059005000540049004F004E003 E0020000D000A00200020003C00530059004D004D004500 WMDRM_PD_DATA_63=54005200490043005F004F00500054003 E0031003C002F00530059004D004D004500540052004900 WMDRM_PD_DATA_64=43005F004F00500054003E0020000D000 A00200020003C002F004600450041005400550052004500 WMDRM_PD_DATA_65=53003E000D000A002D0020003C004C004 9004D004900540053003E000D000A00200020003C004D00 WMDRM_PD_DATA_66=4100580043004800410049004E0044004 5005000540048003E0032003C002F004D00410058004300 WMDRM_PD_DATA_67=4800410049004E0044004500500054004 8003E0020000D000A00200020003C004D00410058004C00 WMDRM_PD_DATA_68=4900430045004E0053004500530049005 A0045003E00310030003200340030003C002F004D004100 WMDRM_PD_DATA_69=58004C004900430045004E00530045005 30049005A0045003E0020000D000A00200020003C004D00 WMDRM_PD_DATA_70=410058004800450041004400450052005 30049005A0045003E0035003100320030003C002F004D00 WMDRM_PD_DATA_71=410058004800450041004400450052005 30049005A0045003E0020000D000A00200020003C002F00 WMDRM_PD_DATA_72=4C0049004D004900540053003E003C005 000550042004C00490043004B00450059003E0050006600 WMDRM_PD_DATA_73=5A007600680056007100320067006C005 8006A0034004100360074007A004200540034006F004C00 WMDRM_PD_DATA_74=4E002B004100670038005800560047004 B004E007500310054006A0076005700350045006A004100 WMDRM_PD_DATA_75=4B006E004200640072005700430073007 0006D00480051003D003D003C002F005000550042004C00 WMDRM_PD_DATA_76=490043004B00450059003E003C002F004 4004100540041003E003C004D005300440052004D005F00 WMDRM_PD_DATA_77=5300490047004E0041005400550052004 5005F00560041004C00550045003E00770046007A005400 WMDRM_PD_DATA_78=470041006E00680059007A0048006B003 70038006C0073004E004A004E00490062006D0073003400 WMDRM_PD_DATA_79=6D006C00500037003000590058002B004 8004D00510073006E003100500030003900670061007400 WMDRM_PD_DATA_80=64002B0066006F0075005500650054005 50067003D003D003C002F004D005300440052004D005F00 WMDRM_PD_DATA_81=5300490047004E0041005400550052004 5005F00560041004C00550045003E003C002F0043004500 WMDRM_PD_DATA_82=520054004900460049004300410054004 5003E003C00430045005200540049004600490043004100 WMDRM_PD_DATA_83=54004500200074007900700065003D002 20041005500540048004F00520049005A00410054004900 WMDRM_PD_DATA_84=4F004E0022003E003C004400410054004 1003E003C00530045004300550052004900540059004C00 WMDRM_PD_DATA_85=4500560045004C003E003200300030003 0003C002F00530045004300550052004900540059004C00 WMDRM_PD_DATA_86=4500560045004C003E003C00410055005 40048005F00490044003E0032003800370039003C002F00 WMDRM_PD_DATA_87=41005500540048005F00490044003E003 C005000550042004C00490043004B00450059003E006B00 WMDRM_PD_DATA_88=43004C0030005A002B007800450056005 4002B0056007300710044003700560049004E002F006900 WMDRM_PD_DATA_89=54004D005800540054007800440077004 70077005A0071007A006E0051005700390035006D003500 WMDRM_PD_DATA_90=77004600570066004A006E004A0055007 50046004600560051003D003D003C002F00500055004200 WMDRM_PD_DATA_91=4C00490043004B00450059003E003C002 F0044004100540041003E003C004D005300440052004D00 WMDRM_PD_DATA_92=5F005300490047004E004100540055005 20045005F00560041004C00550045003E0038006E005600 WMDRM_PD_DATA_93=7A0074004F00300044004E00330070004 D006F00740067006F006600310042007A00460068004B00 WMDRM_PD_DATA_94=380050007A00590034006100320064006 D0049003600720054003500680043007700340057002F00 WMDRM_PD_DATA_95=46004D006B006F006C007800660050006 600470067003D003D003C002F004D005300440052004D00 WMDRM_PD_DATA_96=5F005300490047004E004100540055005 20045005F00560041004C00550045003E003C002F004300 WMDRM_PD_DATA_97=450052005400490046004900430041005 40045003E003C0043004500520054004900460049004300 WMDRM_PD_DATA_98=410054004500200074007900700065003 D00220041005500540048004F00520049005A0041005400 WMDRM_PD_DATA_99=49004F004E005F0052004F004F0054002 2003E003C0044004100540041003E003C00410055005400 WMDRM_PD_DATA_100=48005F00490044003E0031003C002F00 41005500540048005F00490044003E003C00500055004200 WMDRM_PD_DATA_101=4C00490043004B00450059003E006100 31007400330068007800720067002100710062004F006700 WMDRM_PD_DATA_102=6B0074006E0062005900610045004500 6900340074006500430073006500210067007A0036005200 WMDRM_PD_DATA_103=7600540050007500430021007A006900 7A004B004A006C0070005500370078006F00640075005300 WMDRM_PD_DATA_104=77003D003D003C002F00500055004200 4C00490043004B00450059003E003C002F00440041005400 WMDRM_PD_DATA_105=41003E003C004D005300440052004D00 5F005300490047004E00410054005500520045005F005600 WMDRM_PD_DATA_106=41004C00550045003E00560070003300 42005900550038004300380057005A00590055002F005600 WMDRM_PD_DATA_107=590076004B0066004200390073004600 330065006A00730032004700450055005500340059005900 WMDRM_PD_DATA_108=73006300750058006900520046004500 43007A007A004B0064005900580074006D00440077003D00 WMDRM_PD_DATA_109=3D003C002F004D005300440052004D00 5F005300490047004E00410054005500520045005F005600 WMDRM_PD_DATA_110=41004C00550045003E003C002F004300 45005200540049004600490043004100540045003E003C00 WMDRM_PD_DATA_111=2F004400450056004300450052005400 3E00 CHECKSUM=-1 [CERT_PROG_DATA_OUT_APE] PRODUCTCODE=0566806 PSN=DTC186745 HWID=1000 CHECKSUM=-1 [MISC_PROG_DATA_OUT] WARRANTY_DATA_1=00020001000001B80000000000000000FF FF000000FFFF0000000000000000000000000000000000 WARRANTY_DATA_2=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_3=0000000000000000000000000000000000 000000000100000000010100000000040000FFFF000000 WARRANTY_DATA_4=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_5=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_6=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_7=00000000000000000C001A001900000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_8=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_9=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_10=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 WARRANTY_DATA_11=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 WARRANTY_DATA_12=0000000000000000 PROD_DATA_1=0004000900010320380000008D000000130100 0026010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_3=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_4=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_5=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_6=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_7=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_8=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_9=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_10=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_11=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_12=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_13=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_14=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_15=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_16=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_17=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_18=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_19=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_20=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF PROD_DATA_21=FFFFFFFFFFFFFFFF0003000A4454433138363 7343500000400083035363638303600000500083035 PROD_DATA_22=3633393531000006000830323033383638000 0090005313030300000120050333535373433303232 PROD_DATA_23=3433383736320055555555555555555555555 5555555555555555555555555555555555555555555 PROD_DATA_24=5555555555555555555555555555555555555 555555555555555555555555500130004D807090100 PROD_DATA_25=1C00020400 BT_DATA_1=00C1000400020008FFFFFFFFFFFFFFFF00030020 FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFF00040020FFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_3=FFFFFFFFFFFFFFFF00090040FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_4=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK_DATA_1=0134000A000000010300012000300000000000 00000E0000000000000019F815E800000000000000 LOCK_DATA_2=00000000000000000000000000000000000000 000020010000C00000000A00000002000000AB0FBD LOCK_DATA_3=96AF2AC271D26264AFDEAD0600D44D9CC64568 F82B1A4F8B0F51BBAB62CD79F50D15C65C819D62DD LOCK_DATA_4=10A30798D5D975EFE2757A4633A5665153DB7C 082DB969D138285614C37066EE741B3A5749380272 LOCK_DATA_5=8543E4C659B32E634C9CA0BE7EA55F0CD868D5 A00D32D266C14707B5923A7F1F07C9E429C3701AAD LOCK_DATA_6=6E3F7FC7A32A2D2A2AC61BD7F1349E4E8A064B 56E6AAE090B2357899BE830F878C2BEF56D8F52EBB LOCK_DATA_7=6D79ACA824FB26F1036C3BB758105E0A0028BF 765D446F8CEC584AF7AE510A29436207C70E3E4415 LOCK_DATA_8=92C988DC7DAD65C1584206BCB6BC3FD0A39D51 7E5F20020000D00000000200000002000000AB0FBD LOCK_DATA_9=96AF2AC271D26264AFDEAD04001A77CED6EE66 56F7774100D6C294B787F8035DA019A8719322B160 LOCK_DATA_10=D3B4C17E6CCC4E559C67F34F661019141CA02 480113B9252223D3AE686AE4ACF8EBB0FF3CE2ADEC2 LOCK_DATA_11=0AEC839D8276E095D5C62AA56B84BA025D46E 78A89A9D87AFA25E7E52030F48484E71A7F71B2789C LOCK_DATA_12=559345F1EC1BF7726E189A20E3D954F9D6C50 9770B466D941D18F683E8E061BBCC7AEDF91E59EA68 LOCK_DATA_13=CF38E2422DDFFCE9C462FBBE0E3473749C2DE 27F6BFF8D04651BEA7B993787F38F4F93CA2A8345B3 LOCK_DATA_14=44065D421A045547D3C608806B3E6D58DB0F1 5814ACE2248F852459934B01298F3C1729A3FFFFFFF LOCK_DATA_15=FF800000000200000002000000AB0FBD96AF2 AC271D26264AFDEAD0300160E55192DCE2FD2DB274E LOCK_DATA_16=9BE08517673ABAEB29279C97EAA148D4110BA 4B7890AFCC0DD73BB125E410105DDE16E83B99F3E45 LOCK_DATA_17=D8DE227DAD63C47B755BA6CE83BF594D4DDA2 61750667069CB3FA72AB72AF07E2EE534A53CA74491 LOCK_DATA_18=1BD1B7C4485010593F03B9F2578D194B9645D 33A54784DE29BCC27D89B954A55D23416A9D1DC4838 LOCK_DATA_19=2B079245E4E545CB0E8BA41DF700000000000 0000000000000000000000000000000000000000000 LOCK_DATA_20=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_21=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_22=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_23=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_24=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_25=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_26=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_27=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_28=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_29=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_30=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_31=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_32=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_33=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_34=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_35=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_36=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_37=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_38=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_39=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_40=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_41=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_42=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_43=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_44=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_45=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_46=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_47=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_48=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_49=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_50=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_51=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_52=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_53=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_54=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_55=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_56=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_57=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_58=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_59=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_60=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_61=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_62=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_63=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_64=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_65=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_66=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_67=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_68=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_69=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_70=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_71=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_72=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_73=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_74=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_75=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_76=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_77=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_78=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_79=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_80=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_81=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_82=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_83=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_84=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_85=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_86=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_87=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_88=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_89=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_90=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_91=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_92=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_93=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_94=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_95=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_96=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_97=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_98=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_99=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_100=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_101=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_102=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_103=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_104=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_105=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_106=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_107=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_108=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_109=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_110=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_111=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_112=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_113=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_114=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_115=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_116=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_117=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_118=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_119=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_120=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_121=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_122=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_123=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_124=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_125=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_126=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_127=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_128=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_129=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_130=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_131=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_132=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_133=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_134=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_135=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_136=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_137=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_138=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_139=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_140=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_141=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_142=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_143=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_144=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_145=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_146=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_147=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_148=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_149=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_150=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_151=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_152=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_153=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_154=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_155=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_156=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_157=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_158=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_159=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_160=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_161=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_162=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_163=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_164=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_165=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_166=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_167=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_168=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_169=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_170=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_171=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_172=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_173=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_174=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_175=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_176=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_177=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_178=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_179=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_180=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_181=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_182=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_183=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_184=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_185=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_186=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_187=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_188=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_189=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_190=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_191=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_192=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_193=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_194=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_195=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_196=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_197=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_198=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_199=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_200=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_201=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_202=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_203=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_204=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_205=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_206=000000000000020001800003000103000400 01070005000A31323334350000000000000600010000 LOCK_DATA_207=070001000008000100000900280000000000 00000000000000000000000000000000000000000000 LOCK_DATA_208=00000000000000000000000000 LOCK120_DATA_1=00780004000003B00000000000000000244 070000000000000180700000000000050000005FFFFFF LOCK120_DATA_2=00B4000005FFFFFF0118000005FFFFFF017 C000005FFFFFF01E0000005FFFFFF0244000005FFFFFF LOCK120_DATA_3=02A8000005FFFFFF000000007FFF6F07FFF FFFFFF800030C03000503000000007FFF6F3EFFFFFFFF LOCK120_DATA_4=C000030F02000103000000007FFF6F3FFFF FFFFFC000031102000103000000007FFF6F07FFFFFFFF LOCK120_DATA_5=07FE031308000503000000007FFF6F07FFF FFFFF07FE031B08000503000000007FFF6F07FFFFFFFF LOCK120_DATA_6=F800032303000503000000007FFF6F3EFFF FFFFFC000032602000103000000007FFF6F3FFFFFFFFF LOCK120_DATA_7=C000032802000103000000007FFF6F07FFF FFFFF07FE032A08000503000000007FFF6F07FFFFFFFF LOCK120_DATA_8=07FE033208000503000000007FFF6F07FFF FFFFFF800033A03000503000000007FFF6F3EFFFFFFFF LOCK120_DATA_9=C000033D02000103000000007FFF6F3FFFF FFFFFC000033F02000103000000007FFF6F07FFFFFFFF LOCK120_DATA_10=07FE034108000503000000007FFF6F07FF FFFFFF07FE034908000503000000007FFF6F07FFFFFFFF LOCK120_DATA_11=F800035103000503000000007FFF6F3EFF FFFFFFC000035402000103000000007FFF6F3FFFFFFFFF LOCK120_DATA_12=C000035602000103000000007FFF6F07FF FFFFFF07FE035808000503000000007FFF6F07FFFFFFFF LOCK120_DATA_13=07FE036008000503000000003F007F206F 07FFFFF800036803000503000000003F007F206F3EFFFF LOCK120_DATA_14=C000036B02000103000000003F007F206F 3FFFFFC000036D02000103000000003F007F206F07FFFF LOCK120_DATA_15=07FE036F08000503000000003F007F206F 07FFFF07FE037708000503000000003F007F206F07FFFF LOCK120_DATA_16=F800037F03000503000000003F007F206F 3EFFFFC000038202000103000000003F007F206F3FFFFF LOCK120_DATA_17=C000038402000103000000003F007F206F 07FFFF07FE038608000503000000003F007F206F07FFFF LOCK120_DATA_18=07FE038E08000503000000003F007F206F 07FFFFF800039603000503000000003F007F206F3EFFFF LOCK120_DATA_19=C000039902000103000000003F007F206F 3FFFFFC000039B02000103000000003F007F206F07FFFF LOCK120_DATA_20=07FE039D08000503000000003F007F206F 07FFFF07FE03A508000503FFFFFFFFFFFFFFFFFFFFFFFF LOCK120_DATA_21=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK120_DATA_22=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK120_DATA_23=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK120_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0001005026F00FC9 LOCK120_DATA_25=D09EBD091E8AF2ECB8274DF3C46CC2493E 336B383A4691DD1949D145C0068C01F42E4D61112BB85E LOCK120_DATA_26=6BEC23DD89BD32110E98075AE8B667C107 96B4D5875615F4134D5AC84FF7A304FD7E25C100020014 LOCK120_DATA_27=1760D632317F07F2F380A8D85F64409331 F92F770003007000000000000000000000000000000000 LOCK120_DATA_28=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 LOCK120_DATA_29=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 LOCK120_DATA_30=00000000000000000000000000000000 |
cant restore the imei | mobileunlockers | Cyclonebox | 25 | 07-25-2009 07:09 |
cyclone destory e51 imei but i cant restore backup | ABI-GSM | Cyclonebox | 2 | 05-04-2009 20:42 |
cant restore IMEI on S220 | llcoolr | Multi-box LITE | 6 | 08-21-2008 10:30 |
N91 Cant Restore IMEI | dannyogolo | Infinity-Box | 5 | 10-19-2007 14:18 |
3310 4.19 cant restore backup | djmattamondo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-15-2001 17:54 |
