09-19-2010, 05:52 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: ODISHA Age: 38
Member: 843479 Status: Offline Thanks Meter: 48 | 3110c security test failed when i go to pmm auth its shown this error Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35320303060873-4 Product Code: 0581523 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353203030608734 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 175.40.173.85 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 175.40.173.85 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... now what to do i cant understand |
09-19-2010, 07:56 | #3 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Lahore Age: 38
Member: 1016490 Status: Offline Thanks Meter: 290 | Quote:
just write pm with sx4.....problem will solve | |
09-19-2010, 11:55 | #4 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Nashik
Member: 578632 Status: Offline Thanks Meter: 229 | just do this producer ur problem solve 1. press service button 2. press pm section 3. press super sd autho(after super sd autho sucessful) 4. write pm section 1 and 309 field ur problem solve |
09-19-2010, 12:19 | #5 (permalink) | |
Member: 843479 Status: Offline Thanks Meter: 48 | Quote:
thanks for suggetion sir but also same error shown when i do super sd auth what problem with me sir im using reliance net connect for internet is its problem | |
09-19-2010, 15:01 | #8 (permalink) | |
Junior Member Join Date: Aug 2010
Member: 1374054 Status: Offline Thanks Meter: 14 | Quote:
probably SUPERDONGLE_KEY corrupted ! so u first do sd repiar then go to pmm auth | |
09-20-2010, 08:25 | #11 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: siliguri,india Age: 31
Member: 1183572 Status: Offline Thanks Meter: 203 | Quote:
1st go in imei tab and recover crt data 2nd now scan ur phone if still secquirty test fail. than go in pm tab do ppm author and write pm from server(make tick mark on lode from server) now post all logo here, | |
09-22-2010, 09:16 | #12 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 912556 Status: Offline Thanks Meter: 25 | 1 st do rpl back up {in imei security (rebuilt imei)} then go to quick fix select bb5 doungrade software fix do selected job then scan {in flash option} do as usually then do recover certificate (in pm options select) rfbb from server write after that do pm auth then select pm file write 1000% solution |
Security Code | dESiRE! | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 05-13-2011 22:17 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
SECURITY CODE | AWLABA | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 02-22-2000 23:38 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
