Old 03-12-2010, 06:17   #1 (permalink)
Member: 524163
Sonork: 1589680
Thanks Meter: 33
3110c Security test Failed..
Scan -
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35683302734086-2
Product Code: 0544306
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356833027340862
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Bus Check -
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 0FC00115EDA87C560B7EF68C5121C9C42899BCEF
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Original Imei: 35683302734086
Original Product code: 0550573
Bluetooth ID: 0022FDF61885
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
After this I've Erase, Full Flash worte back RPL.
BB5 Certificate Validation -
Product Code: 0550573
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Reading RAP NPC (0x168 bytes)
Original Product Code: 0550573
Reading RAP VARIANT (0x0 bytes)
Reading RAP CCC (0x160 bytes)
CCC seems to be valid
Reading RAP HWC (0xD4 bytes)
HWC seems to be valid
SIMLOCK_TEST passed
After That I've Done Repair SD and Wrote PM (Feild 1 & 309) with Super SD Auth.
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
But then also it Shows Security Test Failed.
Please Help
Old 03-12-2010, 06:23   #2 (permalink)
Member: 823633
Thanks Meter: 1,705
bro write good pm file with sx4 server
The Following User Says Thank You to vaghubha_sodha For This Useful Post:
Old 03-12-2010, 06:26   #3 (permalink)
Member: 524163
Sonork: 1589680
Thanks Meter: 33
I've done it, Handset shows security test passed but after 1 minute it again shows Security test failed.
Old 03-12-2010, 06:59   #4 (permalink)
Member: 823633
Thanks Meter: 1,705
Old 03-12-2010, 07:08   #5 (permalink)
bhuvanele's Avatar
Member: 237210
Thanks Meter: 90
In most cases HWC data will be missing,check that in tests-various-BB5 cert validation.
If it says hwc empty then write only hwc data from RPL. Its posted in sticky thread
Old 03-12-2010, 07:09   #6 (permalink)
pinkyelectronic's Avatar
Member: 1173492
Thanks Meter: 27
1.Service > Imei & Security > Imei Rebuild > Repair SD
2.Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
3.Service > PM >load.PM.super SD auth is done, write PM imediately.
br
parwez
Old 03-12-2010, 07:44   #7 (permalink)
sheraz_mobiles's Avatar
Member: 724090
Sonork: 100.1601663
Thanks Meter: 88
very easy with the usb cable
Old 03-12-2010, 07:47   #8 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
br
parwez
totally agree with you 100% solution........
Old 03-12-2010, 07:51   #9 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
Click here --> http://forum.gsmhosting.com/vbb/f550...l-here-945700/
The Following User Says Thank You to hasnain For This Useful Post:
Successfully Repaired 3110c Security Test failed after SD Repair romeoluv56 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 05-14-2012 12:37
3110c - Security Test Failed ## (ANSWERED) jesuraja MXKEY Nokia Flasher and Unlocker (by Alim Hape) 29 10-31-2011 15:00
3110c - Security Test Failed. Help! [Shadab_M] MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 05-30-2010 09:43
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 11:19
mx key team 3110c security test failed sanjayvikas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-31-2010 23:42
Page generated in 0.22134 seconds with 11 queries
