05-04-2011, 18:56 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bharat
Member: 1087883 Status: Offline Sonork: 100.1651719 Thanks Meter: 38 | 3110C Security Test Failed (Manole n Mx members pls need guidence)) n one more thing when i m goes for pmm auth its says SX4 not found n have 35 credits left n i try make full erase n write heigher version 7.30 but problem still same ......Don't get angry on me i m check some security test failed solution posts but problem still same for me i m waiting for ur valuable guidance Thanks to all........... |
The Following User Says Thank You to asmanju08 For This Useful Post: |
05-05-2011, 04:32 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - do not load any pm - mark load rfbb from server - do pmm auth, click write after auth successful. if not done: recover certificate if not done: attach here your rpl. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
05-05-2011, 07:34 | #3 (permalink) |
Member: 1087883 Status: Offline Sonork: 100.1651719 Thanks Meter: 38 | Thank u for ur quick support i follow all steps told by u sir but problem still same here complete log & RPL 1st load Pm from RfBB n write Log here MXKEY Serial: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1A20020854DE7E56081112F14017AE571F8520CB ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Original Imei: 35322503514546 Original Product code: 0581437 Bluetooth ID: 002547ADB301 Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35322503514546-1 Product Code: 0544306 Battery voltage: 4773 mV, current: 62 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353225035145461 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Updating RFBB data ... Writing section 1... Error 0 Writing section 309... Error 0 Done. Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 122.179.86.214 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Retrying ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...MXKEY SX4CARD - ID, hello 122.179.86.214 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request 2nd recover cert log here CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1A20020854DE7E56081112F14017AE571F8520CB ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Begin Certificate Request ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Updating PRODUCTCODE (0581437)... OK CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1A20020854DE7E56081112F14017AE571F8520CB ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Updating RFBB data ... Writing section 1... Error 0 Writing section 309... Error 0 Done. RPL [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0514950 PSN=7F0821634 HWID=2000 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303538313433374300000000 NPC_DATA_2=0000000000000000000000004007029876F2024 A906A0300646F7242000000001A20020854DE7E56 NPC_DATA_3=081112F14017AE571F8520CBC0E691EA16A7593 A9BB28832D7312A39F7ED668DF05B2FD1DFB842DC NPC_DATA_4=0F47F9728DB3E59E34B90CE8000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3335220553414516FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=01B3AD472500000000000000000000000000000 0000000000000000000000000B5B0752BC61D586D NPC_DATA_7=68A4FC1247056A02082DB5AC5AFDB3F8611B27D E4E40A32343BEACF1BBE29BD86782D3CC303C5E8C NPC_DATA_8=77550509DFBF4A2B3540F76777C7A92447B4AE7 C8DC505E580E5A246814FB8DFBB8BCD8B719ACE29 NPC_DATA_9=E82FEEEAF2EE72B432EBA5D0AF2A7B6E5125ADD 6CF1FCA70100A99F7C68565C981D4FB5552922062 CCC_DATA_1=4343434302004150010000009138E0942182024 675792D00EF3E9C00000060010000000000000000 CCC_DATA_2=000000000000000000000000000000000000000 00000000000000000000000003035343433323143 CCC_DATA_3=090699450000000000000000010000000E00000 00000000000000000000000000000000000000000 CCC_DATA_4=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_5=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_6=000000000000000000000000000000000000000 00000000019A7FFE66095ADA9642936E87EA755B9 CCC_DATA_7=3DE48139152F82D7AB3B18F94D191ED9B50DC3E 96DAB6572437E0B69D8E83BDBED7472EA899F346D CCC_DATA_8=02BB7FB5B98EADF4B79396385DBA17179069AB3 9E3F6386A85834FD1030B2EB988784C9DAE51AF7C CCC_DATA_9=92B294EB303034287446DF9F0D73BAAABD203F0 0F9B7A0A3B9EBEBC039736DA1 HWC_DATA_1=43485743050041500100000093060297234D7E4 955400000646F7242000000000000000000000000 HWC_DATA_2=00000000000000002040010B332B7E56C53D711 E88EF1210ADE1BD34303534343332314300000000 HWC_DATA_3=00000000B941FF7BE3678FF61CA2B68B4EFBFA2 2FE7C537BEE6B89510D9A9E533DF38F497D27F85D HWC_DATA_4=253C7CB714488752FF3B12ADBEFCBB48D6D58D2 98C38A256D783965228BD9B9206111EC652528E4D HWC_DATA_5=C2DB7660B6A2D4A6BCBEF4D160D5588441DE14C 75A392A11E6A4939E52C9BE48D76F2AC472B23BDD HWC_DATA_6=4A551773BCD96C9E7BB3AD02 SUPERDONGLE_KEY_DATA_1=DD274EA81E12043AEFD22C393AA C4549119F5738AD3296EAA7F12C6DABA12EE11F4599200342F E76 SUPERDONGLE_KEY_DATA_2=C8EAF62A726B38844302BAEBEBE 79C18BDD2AF859BBACD4B9F877141B5817134507BB5A67C3C0 612 SUPERDONGLE_KEY_DATA_3=520DA95538961C219759C430443 F0B1C CMLA_KEY_DATA_1=4C090000D8020000308202D1308201B9A0 03020102021440020000026B02B2D01003C3D596AC7416 CMLA_KEY_DATA_2=19F645300D06092A864886F70D01010505 003030310B300906035504060C025553310D300B060355 CMLA_KEY_DATA_3=040A0C04434D4C41311230100603550403 0C09446576696365204341301E170D3039303232353031 CMLA_KEY_DATA_4=323531355A170D32393032323530313235 31355A304F311A3018060355040A0C114E6F6B69612043 CMLA_KEY_DATA_5=6F72706F726174696F6E3131302F060355 04050C2864653966303339323038613232663937313136 CMLA_KEY_DATA_6=6530616265643066383031313533633263 6139663230819F300D06092A864886F70D010101050003 CMLA_KEY_DATA_7=818D0030818902818100A67CB064482E41 557E3A001FD44324ED1059ABE3A0118A15F04748A7CBDE CMLA_KEY_DATA_8=E7C33740E72120AF138E89C5CF2370582D C2A527092F3A0407D1C52485BC933BDDBFFDCD2970BB37 CMLA_KEY_DATA_9=DF60D41DB0167190EB499680C7E9DE6700 E08178C6C35F8C79737267A1AA2BF61D6EE7BC07C36BC6 CMLA_KEY_DATA_10=910AC0C83E9B2100F6A9333F2D598F13C 40D0203010001A3483046300E0603551D0F0101FF040403 CMLA_KEY_DATA_11=0200A0301F0603551D230418301680141 39EEE5CA64DF25CCB66D0959313E460770A7B7A30130603 CMLA_KEY_DATA_12=551D250101FF040930070605672B06010 2300D06092A864886F70D0101050500038201010068DEB3 CMLA_KEY_DATA_13=182409C489FD5591832B116042AC73999 B37B04B9830FC936D0B88B4426BFAA1B34C40E9336D906F CMLA_KEY_DATA_14=6C77E4B40A891828974FC9032EB6C0B63 4C3D746A6DD53ED321AF29C1F07D5B1735AEDACF7DC730E CMLA_KEY_DATA_15=C4CC9622BF7DBBE2E9410C858D303A18E BE5E9350D88DB1FAA5675715D263F7C64726F55C270C186 CMLA_KEY_DATA_16=6CC64019379E12DF81BD0484BC86EE33A 2E5DD6F3761B2869B1DCEB86295F0401FAEC6D3A021B2B4 CMLA_KEY_DATA_17=BBD9073C17EC961B7B6A8FB30D194A675 C02244879B2CE08B8F3302F587692DC64F58717ACD37487 CMLA_KEY_DATA_18=0140106EDDDFAA5F0892C3E9A82D875FD 6016E4FB193D9F495802A6EC6216B471F0809BE5DB6B158 CMLA_KEY_DATA_19=C441C2D2DEB5BF8D68BF4277CF0000004 8030000308203423082022AA0030201020204315EB86C30 CMLA_KEY_DATA_20=0D06092A864886F70D0101050500302E3 10B300906035504060C025553310D300B060355040A0C04 CMLA_KEY_DATA_21=434D4C413110300E06035504030C07526 F6F74204341301E170D3035303432353231353631355A17 CMLA_KEY_DATA_22=0D3334313232353231353631355A30303 10B300906035504060C025553310D300B060355040A0C04 CMLA_KEY_DATA_23=434D4C413112301006035504030C09446 57669636520434130820122300D06092A864886F70D0101 CMLA_KEY_DATA_24=0105000382010F003082010A028201010 0C2D6E78C90B6F572F115CC4425A688BD9A2F9E4055C204 CMLA_KEY_DATA_25=9ECCE99602C3F02F63AE01623D18B625D 4F535EA920D0628FF3F61488EA274D9767279C464457ED9 CMLA_KEY_DATA_26=3DD64893AB5A2239CB5F0F609A0E465C5 78280EE2E1DA8ADC54E98426395E42F006D477D11773CE6 CMLA_KEY_DATA_27=18CA191E89E3196850751F51E23A6DA11 C187F578F38CF6894E216774079B6C5CF853A969E6D5D96 CMLA_KEY_DATA_28=07B851CF900AB286561D09CE796A7B31A 669FB8B70C72E29C5DC316058F40D93B1C343E99905DD35 CMLA_KEY_DATA_29=6BEE29B47A93FA7056612135DE3F1B8E4 4D9ADA0AD25DFC831C76AA4DA5A0F262A18723DB8484859 CMLA_KEY_DATA_30=D09D56EAB3385BCE07C6F264E121CE3FB AAB491383DFC9CEEE3A1114E98F89A2D30203010001A366 CMLA_KEY_DATA_31=3064301D0603551D0E04160414139EEE5 CA64DF25CCB66D0959313E460770A7B7A300E0603551D0F CMLA_KEY_DATA_32=0101FF04040302010630120603551D130 101FF040830060101FF020100301F0603551D2304183016 CMLA_KEY_DATA_33=80141C7474B75285FC7104B0CCBE20F02 285355CFB56300D06092A864886F70D0101050500038201 CMLA_KEY_DATA_34=01003AFFB7ECE5185337CC4940436E4D9 5C1D8C6DF2C283CFAFF3E9E3F56E2EAC85100E474E9D076 CMLA_KEY_DATA_35=EC407BA4BE09F9FFD03CFDEC76A076BB1 5ECFB3FC0D8C564D041039E472804559E3AE78DE53B8C1B CMLA_KEY_DATA_36=A57A6EC9BE9483BCD23F0015D9616F60A E68BBB9CF527290DC37FBA79CAB2D6D6B2D6D229B39ABBA CMLA_KEY_DATA_37=7CD41B39FE559F8F1679344D6EF352D2D A9DD7EEC47EB90809476A7724E10B03A6237366415D1CEF CMLA_KEY_DATA_38=321C66E97DEE87B24F56FEAA020226E48 6EF8B6192553C8293C2CD18998A2B665D4C6171C9AC3BFB CMLA_KEY_DATA_39=AD189886F15FAD3363BB0FEA759CD4581 9EF61498A4C53C15791AA3E2EBF9385CEC2007CD44FA264 CMLA_KEY_DATA_40=ED5889ADB6D4E1281676B1D58960B13CF 8580000200300003082031930820201A003020102020103 CMLA_KEY_DATA_41=300D06092A864886F70D0101050500302 E310B300906035504060C025553310D300B060355040A0C CMLA_KEY_DATA_42=04434D4C413110300E06035504030C075 26F6F74204341301E170D3035303432353030303030305A CMLA_KEY_DATA_43=170D3334313233313233353935395A302 E310B300906035504060C025553310D300B060355040A0C CMLA_KEY_DATA_44=04434D4C413110300E06035504030C075 26F6F7420434130820122300D06092A864886F70D010101 CMLA_KEY_DATA_45=05000382010F003082010A0282010100D 9A219DCB167B3853577958167166766C462592955D36E2B CMLA_KEY_DATA_46=21231B4D6C48B6BAD9595698A8BB03382 CAEB22BE6E53223368BEA13A7D1214A0955FE71800FDE6F CMLA_KEY_DATA_47=54F3F300E0EE00472DC3852D7A388863C 8CC5C70EDEE4808B71E9A4B35751827AE64D7CEE2D16095 CMLA_KEY_DATA_48=14BB8B5652BFDCBE7C2CC39A1A2FC57D8 3672E51532B6ED12CDA16943E402784D09BC61FC7850A3B CMLA_KEY_DATA_49=1776558ECAE8EF9765678BB9BCCB394A9 2BAE00877D431AF7A5FD322DBE2EC0158C43F1B6543FAC7 CMLA_KEY_DATA_50=F5C23E744C256B3D127FAE3BE82C49E0B BD2DE49BC2F9546FF1DC36C88714AF30757DA662C384C88 CMLA_KEY_DATA_51=2862CBDEAA12ED7C040F19D92469B2FB3 DC8D7C55AA76844F7C2355A5E957B230203010001A34230 CMLA_KEY_DATA_52=40301D0603551D0E041604141C7474B75 285FC7104B0CCBE20F02285355CFB56300E0603551D0F01 CMLA_KEY_DATA_53=01FF040403020106300F0603551D13010 1FF040530030101FF300D06092A864886F70D0101050500 CMLA_KEY_DATA_54=0382010100924D9C9A0AD370987D029BC 9B0D8CB17CDA48256ED53BE819D3E992C43B853EAE3FF15 CMLA_KEY_DATA_55=EF840A5DA9A3BE38A459F200EB1F65E43 E01ACD6E7AADBA94CC7E66B90E335A5FC3539CD46881E9B CMLA_KEY_DATA_56=059DFE04D6A0E8064B5410298D7607ACC 8C87EC570A79C4AAB2B1337198D65866F4F7CB6B6946E25 CMLA_KEY_DATA_57=5EA2247AD3E05B6C791AE46AD9E454E6F 9901609D1E0A78DA860BF487C59F1EF51C5D5BA784B4CE6 CMLA_KEY_DATA_58=DAE64771BF455B9CCF855E3E5C7635CFF 02E91AD317ADE2445957641EA9F91A78C993B825E8B1C1D CMLA_KEY_DATA_59=9D4CF40AB80A4AC0027707799495C137E 904E9CC79A08DB726F5BC3D9EE45D3CB9ACD40E274AF9D5 CMLA_KEY_DATA_60=5DB314495E1F937722AC24BCD19143E51 365822AE5000000600200003082025C02010002818100A6 CMLA_KEY_DATA_61=7CB064482E41557E3A001FD44324ED105 9ABE3A0118A15F04748A7CBDEE7C33740E72120AF138E89 CMLA_KEY_DATA_62=C5CF2370582DC2A527092F3A0407D1C52 485BC933BDDBFFDCD2970BB37DF60D41DB0167190EB4996 CMLA_KEY_DATA_63=80C7E9DE6700E08178C6C35F8C7973726 7A1AA2BF61D6EE7BC07C36BC6910AC0C83E9B2100F6A933 CMLA_KEY_DATA_64=3F2D598F13C40D02030100010281807A7 1EA29570CEDF03ACDDD998B3B76C503E96F8A1207D44F1E CMLA_KEY_DATA_65=50CF16D9D22F125C68D7947DBD45DCE76 71C592C1F2E48A1BE7BFAC7E87EF7C0CE83AD957BCA3260 CMLA_KEY_DATA_66=A27AA0CE805856BF748803ACFEF45A732 5C364901811D791A3AB0F5EA55FFB129E6CB823AE43D823 CMLA_KEY_DATA_67=4EEAD9687FC8508F525CE2DCD76CA4B64 CE8D39E6D3801024100E6B7CA48BC2D416FFCEC1A7E858D CMLA_KEY_DATA_68=E578BB906BA5ECFDEF5FFDB9E4EB20285 5FF80E60F51A729864ACFA1FD11AA3161F21FA957D04840 CMLA_KEY_DATA_69=F7824AE77ACAD5E0AD41024100B8BB105 CEEAD45FDF892B7EC88DE9A18E0B763BB31600CDF601F44 CMLA_KEY_DATA_70=264AC0D0CEE65DABE3C150192AF081A42 A480E5C2D06BD89133284B73CD10CB53B471C47CD02402E CMLA_KEY_DATA_71=F1E0A8121A0741992E1569FF14D34750A ADF2C80DF5E90A298EB9A680DAD09F3195CAE999BDA6668 CMLA_KEY_DATA_72=7F26762CB225A2D58C6880C9E2E639CDB 1F20B499F90C102401BF917AD3AE73A260F32086FE4F9F0 CMLA_KEY_DATA_73=53BC1389229B8373EF8F5AACB32FB6AAE 7E9B25D890B88D986CB0C9693607DEC2F5549F62BD6068A CMLA_KEY_DATA_74=C8C6CF29D2641E40310241008D0B4AA24 B878DD998E1004194FA35EF279B4805CBA078D54DB48B71 CMLA_KEY_DATA_75=0F3F65A8A017A735FC5F64CC515D652A4 39556144EB1F01EB05E47CCFA9174084183DDD700000000 CMLA_KEY_DATA_76=00000000 WMDRM_PD_DATA_1=261300003C004400450056004300450052 0054002000760065007200730069006F006E003D002200 WMDRM_PD_DATA_2=31002E00300022003E003C004300450052 0054004900460049004300410054004500200074007900 WMDRM_PD_DATA_3=700065003D002200440045005600490043 00450022003E003C0044004100540041003E003C005500 WMDRM_PD_DATA_4=4E00490051005500450049004400200070 007200690076006100740065003D002200310022003E00 WMDRM_PD_DATA_5=4500720041004200460051005900520062 00460062004D006E006A006C006F007600520049007700 WMDRM_PD_DATA_6=37007A0057006A007500520041003D003C 002F0055004E004900510055004500490044003E003C00 WMDRM_PD_DATA_7=5000550042004C00490043004B00450059 00200070007200690076006100740065003D0022003100 WMDRM_PD_DATA_8=22003E0047006700510037003200500064 0079006C00790049007A0051006D004800320057003900 WMDRM_PD_DATA_9=470041006C004F00730030004400510044 00790078004C00700069006C00520065004D0077006B00 WMDRM_PD_DATA_10=520069003600700044004F0054004F003 10049004A007A0071005A00510041003D003D003C002F00 WMDRM_PD_DATA_11=5000550042004C00490043004B0045005 9003E003C004B004500590044004100540041003E003C00 WMDRM_PD_DATA_12=2F004B004500590044004100540041003 E003C002F0044004100540041003E003C004D0053004400 WMDRM_PD_DATA_13=52004D005F005300490047004E0041005 4005500520045005F00560041004C00550045003E007600 WMDRM_PD_DATA_14=71006E004400650056003200550043005 20034006B004A002F0056006A0070003800610045003600 WMDRM_PD_DATA_15=4D00670064002F006D004800520041006 F0052004D00710034004D007A006F0044006D0033007100 WMDRM_PD_DATA_16=65003500320045006B00760055004F007 8004C003800640041003D003D003C002F004D0053004400 WMDRM_PD_DATA_17=52004D005F005300490047004E0041005 4005500520045005F00560041004C00550045003E003C00 WMDRM_PD_DATA_18=530059004D005300490047004E0041005 4005500520045003E003C002F00530059004D0053004900 WMDRM_PD_DATA_19=47004E00410054005500520045003E003 C002F004300450052005400490046004900430041005400 WMDRM_PD_DATA_20=45003E003C00460041004C004C0042004 10043004B003E003C005300450043005500520049005400 WMDRM_PD_DATA_21=5900560045005200530049004F004E003 E0032002E0034002E003100300037002E00390031003C00 WMDRM_PD_DATA_22=2F0053004500430055005200490054005 900560045005200530049004F004E003E003C0043004500 WMDRM_PD_DATA_23=520054004900460049004300410054004 500200070007200690076006100740065003D0022003100 WMDRM_PD_DATA_24=22003E004700670051003700320050006 40079006C00790049007A0051006D004800320057003900 WMDRM_PD_DATA_25=470041006C004F0073003000440051004 400790078004C00700069006C00520065004D0077006B00 WMDRM_PD_DATA_26=520069003600700044004F0054004F003 10049004A007A0071005A00510041004900450061003100 WMDRM_PD_DATA_27=760044005100360076003200380074006 6003900450063004B005100350071005500330039004400 WMDRM_PD_DATA_28=350037005200790044005000530061006 30070007000530046007800630057006300500045003400 WMDRM_PD_DATA_29=480061003900570054005A00580077004 C005A00560053004A0075003C002F004300450052005400 WMDRM_PD_DATA_30=49004600490043004100540045003E003 C002F00460041004C004C004200410043004B003E003C00 WMDRM_PD_DATA_31=430045005200540049004600490043004 10054004500200074007900700065003D00220047005200 WMDRM_PD_DATA_32=4F005500500022003E003C00440041005 40041003E003C004E0041004D0045003E00330031003100 WMDRM_PD_DATA_33=300063003C002F004E0041004D0045003 E0020000D000A0020002000200020003C004D0041004E00 WMDRM_PD_DATA_34=550046004100430054005500520045005 2003E004E006F006B00690061003C002F004D0041004E00 WMDRM_PD_DATA_35=550046004100430054005500520045005 2003E0020000D000A0020002000200020003C004D004100 WMDRM_PD_DATA_36=4B0045003E004E006F006B00690061003 C002F004D0041004B0045003E0020000D000A0020002000 WMDRM_PD_DATA_37=200020003C00440049005300540052004 9004200550054004F0052003E004E006F006B0069006100 WMDRM_PD_DATA_38=3C002F004400490053005400520049004 200550054004F0052003E0020000D000A00200020002000 WMDRM_PD_DATA_39=20003C004D004F00440045004C003E005 2004D002D003200330037003C002F004D004F0044004500 WMDRM_PD_DATA_40=4C003E0020000D000A002000200020002 0003C00530045004300550052004900540059004C004500 WMDRM_PD_DATA_41=560045004C003E0032003000300030003 C002F00530045004300550052004900540059004C004500 WMDRM_PD_DATA_42=560045004C003E0020000D000A0020002 000200020003C0048004100520044005700410052004500 WMDRM_PD_DATA_43=5F005600450052005F004D0041004A004 F0052003E0031003C002F00480041005200440057004100 WMDRM_PD_DATA_44=520045005F005600450052005F004D004 1004A004F0052003E0020000D000A002000200020002000 WMDRM_PD_DATA_45=3C0048004100520044005700410052004 5005F005600450052005F004D0049004E004F0052003E00 WMDRM_PD_DATA_46=30003C002F00480041005200440057004 100520045005F005600450052005F004D0049004E004F00 WMDRM_PD_DATA_47=52003E0020000D000A002000200020002 0003C004600490052004D0057004100520045005F005600 WMDRM_PD_DATA_48=450052005F004D0041004A004F0052003 E0031003C002F004600490052004D005700410052004500 WMDRM_PD_DATA_49=5F005600450052005F004D0041004A004 F0052003E0020000D000A0020002000200020003C004600 WMDRM_PD_DATA_50=490052004D0057004100520045005F005 600450052005F004D0049004E004F0052003E0030003C00 WMDRM_PD_DATA_51=2F004600490052004D005700410052004 5005F005600450052005F004D0049004E004F0052003E00 WMDRM_PD_DATA_52=20000D000A0020002000200020003C004 60045004100540055005200450053003E000D000A002000 WMDRM_PD_DATA_53=20002000200020002000200020003C004 3004C004F0043004B003E0032003C002F0043004C004F00 WMDRM_PD_DATA_54=43004B003E0020000D000A00200020002 00020002000200020002000200020002000200020003C00 WMDRM_PD_DATA_55=53004500430055005200450043004C004 F0043004B003E0020000D000A0020002000200020002000 WMDRM_PD_DATA_56=200020002000200020002000200020002 000200020003C00550052004C003E006800740074007000 WMDRM_PD_DATA_57=3A002F002F0067006F002E006D0069006 30072006F0073006F00660074002E0063006F006D002F00 WMDRM_PD_DATA_58=660077006C0069006E006B002F003F004 C0069006E006B00490064003D0032003500380031003700 WMDRM_PD_DATA_59=3C002F00550052004C003E0020000D000 A0020002000200020002000200020002000200020002000 WMDRM_PD_DATA_60=200020002000200020003C00500055004 2004C00490043004B00450059003E00210043004E006800 WMDRM_PD_DATA_61=760076007A003100570061004E0056003 1004100460055006D006500740078006B0076006D003900 WMDRM_PD_DATA_62=690044003400550072004500390063006 E004700550069002100710063007100640078004D006900 WMDRM_PD_DATA_63=58006D00440031002A0069006B0059004 70041003D003D003C002F005000550042004C0049004300 WMDRM_PD_DATA_64=4B00450059003E0020000D000A0020002 00020002000200020002000200020002000200020003C00 WMDRM_PD_DATA_65=2F0053004500430055005200450043004 C004F0043004B003E0020000D000A002000200020002000 WMDRM_PD_DATA_66=20002000200020003C004D00450054004 500520049004E0047003E0031003C002F004D0045005400 WMDRM_PD_DATA_67=4500520049004E0047003E0020000D000 A00200020002000200020002000200020003C004C004900 WMDRM_PD_DATA_68=430045004E00530045005F00410043005 1003E0030003C002F004C004900430045004E0053004500 WMDRM_PD_DATA_69=5F004100430051003E0020000D000A002 00020002000200020002000200020003C004C0049004300 WMDRM_PD_DATA_70=45004E00530045005F00530059004E004 3003E0031003C002F004C004900430045004E0053004500 WMDRM_PD_DATA_71=5F00530059004E0043003E0020000D000 A00200020002000200020002000200020003C0045004E00 WMDRM_PD_DATA_72=4300520059005000540049004F004E003 E0030003C002F0045004E00430052005900500054004900 WMDRM_PD_DATA_73=4F004E003E0020000D000A00200020002 000200020002000200020003C00530059004D004D004500 WMDRM_PD_DATA_74=54005200490043005F004F00500054003 E0031003C002F00530059004D004D004500540052004900 WMDRM_PD_DATA_75=43005F004F00500054003E0020000D000 A0020002000200020003C002F0046004500410054005500 WMDRM_PD_DATA_76=5200450053003E000D000A00200020002 00020003C004C0049004D004900540053003E000D000A00 WMDRM_PD_DATA_77=200020002000200020002000200020003 C004D004100580043004800410049004E00440045005000 WMDRM_PD_DATA_78=540048003E0032003C002F004D0041005 80043004800410049004E00440045005000540048003E00 WMDRM_PD_DATA_79=20000D000A00200020002000200020002 000200020003C004D00410058004C004900430045004E00 WMDRM_PD_DATA_80=53004500530049005A0045003E0031003 0003200340030003C002F004D00410058004C0049004300 WMDRM_PD_DATA_81=45004E0053004500530049005A0045003 E0020000D000A0020002000200020002000200020002000 WMDRM_PD_DATA_82=3C004D004100580048004500410044004 5005200530049005A0045003E0035003100320030003C00 WMDRM_PD_DATA_83=2F004D004100580048004500410044004 5005200530049005A0045003E0020000D000A0020002000 WMDRM_PD_DATA_84=200020003C002F004C0049004D0049005 40053003E003C005000550042004C00490043004B004500 WMDRM_PD_DATA_85=59003E003900770073003800340057005 10074004C00580051004100350034006100340033004700 WMDRM_PD_DATA_86=550054003600670039007000520042003 3003400360038006C006100580068007500720072004700 WMDRM_PD_DATA_87=51006400710058006C005900730071003 20064004F00770037007400570041003D003D003C002F00 WMDRM_PD_DATA_88=5000550042004C00490043004B0045005 9003E003C002F0044004100540041003E003C004D005300 WMDRM_PD_DATA_89=440052004D005F005300490047004E004 10054005500520045005F00560041004C00550045003E00 WMDRM_PD_DATA_90=66004A00330071002B003700450076003 000560067003900670034002F0054002F0074004F007400 WMDRM_PD_DATA_91=450070004E006B00640030002B0066003 9006100420068002F0061004400690048006D0050004E00 WMDRM_PD_DATA_92=4700780072007100720076006E004C005 20074004F0051004B0067003D003D003C002F004D005300 WMDRM_PD_DATA_93=440052004D005F005300490047004E004 10054005500520045005F00560041004C00550045003E00 WMDRM_PD_DATA_94=3C002F004300450052005400490046004 90043004100540045003E003C0043004500520054004900 WMDRM_PD_DATA_95=460049004300410054004500200074007 900700065003D00220041005500540048004F0052004900 WMDRM_PD_DATA_96=5A004100540049004F004E0022003E003 C0044004100540041003E003C0053004500430055005200 WMDRM_PD_DATA_97=4900540059004C004500560045004C003 E0032003000300030003C002F0053004500430055005200 WMDRM_PD_DATA_98=4900540059004C004500560045004C003 E003C0041005500540048005F00490044003E0031003700 WMDRM_PD_DATA_99=320037003C002F0041005500540048005 F00490044003E003C005000550042004C00490043004B00 WMDRM_PD_DATA_100=450059003E004F006B00700034004C00 61004B00510061005100710062007A005000760059004500 WMDRM_PD_DATA_101=55005900740042003000650052007800 680070002F00500078004E0056005A0047004F0076003500 WMDRM_PD_DATA_102=2F004D004B0053006500680061004C00 67006F0050006E0056005A002F00570067003D003D003C00 WMDRM_PD_DATA_103=2F005000550042004C00490043004B00 450059003E003C002F0044004100540041003E003C004D00 WMDRM_PD_DATA_104=5300440052004D005F00530049004700 4E00410054005500520045005F00560041004C0055004500 WMDRM_PD_DATA_105=3E004D00640075007300450043006C00 6900360056004B007A004E006A002B003500650064004300 WMDRM_PD_DATA_106=6B00700034006A003800360057006D00 4900660050003200520076002F003500510046005A006D00 WMDRM_PD_DATA_107=370032006D0053005900460062006F00 5A003500650033005500570051003D003D003C002F004D00 WMDRM_PD_DATA_108=5300440052004D005F00530049004700 4E00410054005500520045005F00560041004C0055004500 WMDRM_PD_DATA_109=3E003C002F0043004500520054004900 4600490043004100540045003E003C004300450052005400 WMDRM_PD_DATA_110=49004600490043004100540045002000 74007900700065003D00220041005500540048004F005200 WMDRM_PD_DATA_111=49005A004100540049004F004E005F00 52004F004F00540022003E003C0044004100540041003E00 WMDRM_PD_DATA_112=3C0041005500540048005F0049004400 3E0031003C002F0041005500540048005F00490044003E00 WMDRM_PD_DATA_113=3C005000550042004C00490043004B00 450059003E00610031007400330068007800720067002100 WMDRM_PD_DATA_114=710062004F0067006B0074006E006200 590061004500450069003400740065004300730065002100 WMDRM_PD_DATA_115=67007A00360052007600540050007500 430021007A0069007A004B004A006C007000550037007800 WMDRM_PD_DATA_116=6F0064007500530077003D003D003C00 2F005000550042004C00490043004B00450059003E003C00 WMDRM_PD_DATA_117=2F0044004100540041003E003C004D00 5300440052004D005F005300490047004E00410054005500 WMDRM_PD_DATA_118=520045005F00560041004C0055004500 3E00530034004D00490039005000580069006C0065007500 WMDRM_PD_DATA_119=41003500530079005A00780051005900 370068002B005200710057006C0039006F00790076003000 WMDRM_PD_DATA_120=4800560037006F005400660046004800 530048004A004F0049006600560062007500310051006D00 WMDRM_PD_DATA_121=7200580041003D003D003C002F004D00 5300440052004D005F005300490047004E00410054005500 WMDRM_PD_DATA_122=520045005F00560041004C0055004500 3E003C002F00430045005200540049004600490043004100 WMDRM_PD_DATA_123=540045003E003C002F00440045005600 43004500520054003E00 CHECKSUM=-1 [CERT_PROG_DATA_OUT_APE] PRODUCTCODE=0514950 PSN=7F0821634 HWID=2000 CHECKSUM=-1 [MISC_PROG_DATA_OUT] RF_DATA_1=0001000C000000721B3A00000000000000000000 0000000000000000000000000000000000000002 RF_DATA_2=00050015003300040007FFD7FFDCFFE900000000 0000000000000000000000000000000000000000 RF_DATA_3=0000000000000000000000000000000000000000 000000000000000000000000000000000000FFD2 RF_DATA_4=0077000200620000FFB8417D4000000000670000 247A247A247A247A1FFF1C2818F51709147A128F RF_DATA_5=11470FFF0EB80E140CCC0C280B840AE1247A247A 247A2551202C1B36178314A3125B10790EDB0D70 RF_DATA_6=0C3D0B1D0A310958088D07DE00071C4000071C40 00071C400004006E1AF300000000000000000000 RF_DATA_7=0000000000000000000000000000000000000003 000C000E002D000FFFF9FFF2FFF3FFED00000000 RF_DATA_8=0000000000000000000000000000000000000000 0000000000000000000000000000000000000000 RF_DATA_9=0000000000000000000000000000000000000006 006200F30031417D404B0629005B0000247A1EB7 RF_DATA_10=1AE017AD151E128F11470F5B0E140D700C280B8 40AE10A3D0A3D09990999099927541DEC194E15A2 RF_DATA_11=12AE105F0E980D0F0BC60AAF09BE08E2084D07C D075C06F20999099900011F6500011F6500011F65 RF_DATA_12=0008006E1AEA000000000000000000000000000 00000000000000000000000000000000300350046 RF_DATA_13=003800070014FFF7FFDBFFAC000000000000000 00000000000000000000000000000000000000000 RF_DATA_14=000000000000000000000000000000000000000 00000000000000000000000000000000D0062010E RF_DATA_15=0028417D4032050900600000247A1EB71AE0185 115C2133211EB0FFF0EB80E140CCC0C280B840AE1 RF_DATA_16=0AE10A3D0A3D0A3D27CC1E0C198415F5131510C 20F100D900C430B2A0A33095F08C6084107C10755 RF_DATA_17=0A3D0A3D00021CBF00021CBF00021CBF0010005 60000FFB8417D40000000006A00001A3D1A3D1A3D RF_DATA_18=1A3D1A3D1A3D1A3D185115C213D6128F10A30F5 B0EB80D700CCC0C280B841A3D1A3D1A3D1A3D1A3D RF_DATA_19=1A3D19DB174F147612190FFF0E5D0CD90BA90A9 909A608D808110012005600F30031417D404B0629 RF_DATA_20=006000001AE01AE01AE01851166613D611EB10A 30F5B0E140D700C280B840B840AE10A3D0A3D0A3D RF_DATA_21=1AE01AE01B7C180A148711E80FA70E070C950B7 30A66098A08DE084707C607570A3D0A3D00140056 RF_DATA_22=010E0028417D40320509006500001AE01AE01AE 018511666147A128F11470FFF0EB80E140CCC0C28 RF_DATA_23=0C280B840AE10AE10AE11AE01AE01BA3185F14E 3122310050E630CFB0BDD0ADE09FE095D08C7083D RF_DATA_24=07BA0AE10AE100190004018C000B001D0006000 10000000300220050000301E10000000000000000 RF_DATA_25=00000000000000000000050300080019021419E 70503000D001901A90BB20502000D0016020F096B RF_DATA_26=0502000D001601A30EBE0000000000000000000 00000000000000000 WARRANTY_DATA_1=00020001000001B0000000000000000000 07024B024D004E004F00510052005500560059005B00FF WARRANTY_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF WARRANTY_DATA_3=FF00000000000000000000000000000000 01000000000101000000FFFF0000000000000000000000 WARRANTY_DATA_4=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_5=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_6=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_7=22070103CF000000000000000000000000 0000000000000000000000000000000700000003000000 WARRANTY_DATA_8=030000000A000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_9=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_10=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 WARRANTY_DATA_11=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 PROD_DATA_1=000400090000000101000100409F8902040038 49022953B7129E44FC032A25A80021527011030306 PROD_DATA_2=06082420000103050503430800008964B80832 280A00808100002466000400320600000000000300 PROD_DATA_3=0A374630383231363334000004000830353134 393530000005000830353432353233000006000830 PROD_DATA_4=32303332393100000900053230303000001200 503335363937343031323337353833340055555555 PROD_DATA_5=55555555555555555555555555555555555555 555555555555555555555555555555555555555555 PROD_DATA_6=55555555555555555555555555555555555555 5500130004D7070801 BT_DATA_1=00C1000400020008FFFFFFFFFFFFFFFF00030020 FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFF00040020FFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_3=FFFFFFFFFFFFFFFF00090040FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_4=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK_DATA_1=0134000A000000010300012000300000000000 0000130000000000000019F815E800000000000000 LOCK_DATA_2=00000000000000000000000000000000000000 000020010000C00000000800000002000000AB0FBD LOCK_DATA_3=96AF2AC271D26264AFDEAD0600942A97246649 0F79C96144AE13E0F664183A745F8519A7DDC70B48 LOCK_DATA_4=9869E99960F01EC1752801DE8F4D4FF8D0D605 7C79EED885F122C9A17080EC9107B793F0A59CF47E LOCK_DATA_5=1D25224FE6F842C93C2175784AE2E219AFD2BA 4D698DC71C1C23583F297FB3E9AF3BA31140D6EEBE LOCK_DATA_6=078AC263D881BD59AA7425F37A5B37BA503F89 0DC05CF29981AAA10894CBFE6822993DD96AC7CF8E LOCK_DATA_7=B5225F8C5BCBCB8CC4C9E6E991074FEA607592 DEC67DF33B0AC629204F891D8F40BC5FAA3D17BCC8 LOCK_DATA_8=361304672B3AB1403F0085F0C185B5900D2EC9 7584D0010000800000000300000002000000AB0FBD LOCK_DATA_9=96AF2AC271D26264AFDEAD0300BD171369DCAD E870EA77CD42B9417A204BDA8E140148A9BA0743BA LOCK_DATA_10=E16AACFB9780895B25A6538EDCF20833EDF72 EA1B90AC48CF4E082E05463643DC440CE482C015661 LOCK_DATA_11=43F9DB5FAD1C6351FD93E04664018DAC77F0A D2CCB57D6B078F867D8A21BE59944E6A7E6A5B69407 LOCK_DATA_12=9CE194648DB502F2D327C2128CB206585D34E E54F2A260628A11CCBFAC80FE57DC1A6F2776D00D00 LOCK_DATA_13=00D00B00000100000002000000AB0FBD96AF2 AC271D26264AFDEAD0800FC7BBE814FA86FDF6BE367 LOCK_DATA_14=2D3835DB921FC312981DC70C7C9B16D5A18EA 836CF5652BC5556F5344900256256EAFBCABA989613 LOCK_DATA_15=298605D932402A4B420A04CF39B8F90AC5005 D442DAC022498D61B62B38DA99ED4E2014AB835E6CD LOCK_DATA_16=701494428BE8A076240D5FC48E790C755DF77 27772F353DE2BEE8C3F4531C0DF60CCB7F4FC094245 LOCK_DATA_17=B4BF1B779987FCABA42EB6E7144DD4E7BE4CA 2398A01ADF45FE60850DC958F23BA7EBF6BC5795529 LOCK_DATA_18=AD2D6285FBB26E713ADB6192C588EC999063A F1FFF301175DF735019210601657125FE771E757C9C LOCK_DATA_19=2038C7FB85C6648852B39DDF1F28209DE4665 E228B19B37D8B171E753453C56924502C0D66515141 LOCK_DATA_20=5915EFA8FF19058AA15C00D1D67995991D63C 2607EAF4E5B70D375C771CBC10E578F67BB04F2BC67 LOCK_DATA_21=BBDEF3623B7EF8CD1E007043FDD5CB055D3FF 35D3F40F8E892065118B805B4CD408CE07FB847A409 LOCK_DATA_22=DEAA1C7AEE6380B3979FC3B6B4EB482D88CCB 0C20D38FBD0AEA0F72BCA12DCB06050DBC3382C573D LOCK_DATA_23=D18630EE97CBBAB1CCCFB8368D023224D3393 72B219DBD694A0A3A8E37E282DC72F4777CBF9BDFD2 LOCK_DATA_24=1FB937B373161CBA58DFD993A87E8E5CFDBBC AC8AD92F9D8C31313DF65629F7D17C833F0FF2F31C6 LOCK_DATA_25=D2E313903038B45C74B17E997C6BCA3DDEADE 2D2AC91B55060F1DD2A3C77809C00048A2642215A72 LOCK_DATA_26=12355CE05DAB2FF3CC7DAD8BE6751DA4EA237 3D0C25BCCD44A95D0F65DC1BB0D4B4A7E567A830712 LOCK_DATA_27=CDA8636017E47337D6F56DA4ADC37A8ABD806 7A630DA6B3A4442B6060C9ECDE15236CF3EA9A61DF9 LOCK_DATA_28=619B4CFACAB4641C76B6D58CF850BFE9C05B7 690F1D01E3511413504F5A41C87AA7E91D9A03DFE60 LOCK_DATA_29=AF2246529F0204A351492AF04A5F20B79A76F 6439524B5A607BBDF9EB60C15A24C3F2DAEE7C5B3EF LOCK_DATA_30=5D6C12ED8BDD25A0A20C7867D995136E5BB6A AE79EE3A631BE5982FD3818C36896C67B2B89842C89 LOCK_DATA_31=DD7637193C5CC1F711BC5E8DAFC329889CF2E 0C3F7ABB761FC94B655B6BF7AC43DEE4AFBF62C5F77 LOCK_DATA_32=77847957171F50BD054E302D751BF736816D7 FA8E455F90AB395ED072C92D6AFDC37052E47237833 LOCK_DATA_33=D87755A5755E0C835C9D4D093C24720D2F10A DEE87C84368F76C37E29CE5680528AF51E67E83D27E LOCK_DATA_34=82E3018115FB8E332EA17AAAC970CB32CC446 B6D09DD77FCC6B4186EBEE800E2CA5063092B063F1F LOCK_DATA_35=E9F6D5A5E7248D991DE7EA02F9B6199D16C4A D587C5D7DD56425C6F67D08A9DE088C04E233A634B8 LOCK_DATA_36=52AD5069B5514C65B8F99E030C5AA03286AEE 0F6D75A47F6E4380C4628CFBFA61E4127283442CB5E LOCK_DATA_37=577F918F0974785A0F623BBF448725CDA3D80 A72DBF561C4AC6C60996205BCCB99EF146629480374 LOCK_DATA_38=FD56AA8E004B6A547A95BDD8E27716FB17421 6EAF3007FB787895FA0D14B20364A1377446EE805B9 LOCK_DATA_39=6AE82C50A52566D529558419F3958E32A2692 FD1025A649314F2CD7A18BB2B2F5FAF7920655FF106 LOCK_DATA_40=BFE98B29D4572771041F3BDFCC23E5CBCB4F6 6C71EF8135BA8B9FFF2049F9FA09D59C2E535CEC61F LOCK_DATA_41=653350686FF2608F3B222CD07EFE10A656B23 160943A7A023C477E3CE0060662F0429CBE481F080F LOCK_DATA_42=9E2C3A3A3076EC1C3FD4A882EF2143D7DEA02 07C01E6C2EA6FEB7F8B609567E2539A995CD991F7D3 LOCK_DATA_43=B64ABF8889373A13757E7C4894965F8120A75 739C5566C7BE4DF71C48BE23A28490E2B6246610E76 LOCK_DATA_44=A8D5DE212D235FF24C7C5C720F10DEA2422B1 E799FC4834A946DDB38B7642FBE390D3AFDEECAF6D9 LOCK_DATA_45=36EE28ACA0E3CAD398E958BCE1009C7B04DEE 40314960664DABF380C12D4BD0890483CA698596866 LOCK_DATA_46=299E3E60E0496379709B24220BBCE1ED6186E 6D03A8A13D2284F37228C96C7459872708364D7FFE7 LOCK_DATA_47=DAAF1FF956D87B17F3B15DC038FE2FC7AAC57 2052B6CCE205075FEE794F4D99A74B82EF7DF64E865 LOCK_DATA_48=B677104B86473C71E713EF1E3F7305B7F1D85 EFB0BB035A13F031E2FCCB505BBB6CE19FAED6B975C LOCK_DATA_49=9E0CA872452C645276A8E0BEB66A301FC96EC B7E5BDB1B8C586E41E033D827CC2D34BE04391DB43B LOCK_DATA_50=7B9CD5C871B848C255CA7870CD46ACF8A9DC8 C1084DCE0BE81764CC2CB6AA35BBB4C9A3974AD1626 LOCK_DATA_51=841E2C4F8EA8F309FC737F925932063C07767 90A57D7E7C54F0C55E7138DE410DDDC9FF1A40FC6EE LOCK_DATA_52=0F891149D932B253364909ED1F9A306C486BC F6821779CEC38E9D33D9F0D80389EE3CA6F30F0FFD7 LOCK_DATA_53=835931EF3FE9592DD337D109903E8DBF9AD7B FA42AC97737E2940DEB8402DF1239D16684E765F63C LOCK_DATA_54=0298F165DCAD80A194EE4A036C46A6C2FD919 01854BA64CB58FDD8F3FA40046F73812AA88EED7CC2 LOCK_DATA_55=187F756B9BB23C506C852A03E317DC09E3DBE F2B664692D7EF883D9AD06204E1FF4BAA03FFA14780 LOCK_DATA_56=A9BC11823D79DD1D770F1D76580438D86764D 0D9600E34C638A8836406362AA9B6AA25C536235FEE LOCK_DATA_57=D375A511D110E0CDBE75312605D4D96AEE2D2 7EF65B84E7030FBAC0008FDC50639A967D13FB7D546 LOCK_DATA_58=CD121E9185DCE9ABB7908DE25EB72BE91CE7E DDFEE8FB32CE2D336F772188AC2C8FD4D56800E107C LOCK_DATA_59=CBD0EDEA0B796B1006909DEA21D60FD9E24C7 252029BE04DB96E7CE8E9945845F7D5947DC942D167 LOCK_DATA_60=958AE266AC3C70263ABCF59387895FDD313F6 2B1A7153E968EF63CE96E33904416E5AFAB0A86E731 LOCK_DATA_61=EEF048317A299DA0B07C47248F7139D17D342 E0E82CF417537853C3BEB6CDA9E9D0763BEC5B314CF LOCK_DATA_62=80FF79011CE30B8BC4F84864A6FA442FB0D02 2C284E80792F4736DDBEEDCF1C9CE8CD3110A5D7474 LOCK_DATA_63=E4C1CFA414DAF6D4D5CB61128EFEFF9B6A751 6476E564D0F5732DAA323C055667CEEBACC5DF0BCED LOCK_DATA_64=750E35DB5BC867BB9E09D98868D3C50C5E627 06573A12863B58DBDB60E0226142EA70854754A3A6D LOCK_DATA_65=347F7CDE6BB590E4B406BA2011B28BFB739CC BC56B903C4A70DDEC9CCD3E906E733AFEDCFC984EE0 LOCK_DATA_66=3E84C81AE88293131250BB2D5C47F3A6300F4 96B5BD039E9332F550B3BAD242B5514CC1E4155CC92 LOCK_DATA_67=A61AB34DE64FC1A17E3E59C32EE0783A0E473 66365D94197813886028966DC8E786077899E5AD864 LOCK_DATA_68=32FF71EF753DB8F4D7D850F129A04E8E08639 A1D257BF433F8B282351D9C0B071EA52882AB90D402 LOCK_DATA_69=49DE4175DE104CD7DB752ECEAD9D94FEB2E50 E985726039343E8A4D54A8DE5A19CF775BF7BA24FF7 LOCK_DATA_70=554EE6D02F7CAB77E11E1659443F46CCD8569 17495A6BB64D22D46B6D4FE99C29DF78E97FE177792 LOCK_DATA_71=289A0AF6D247B11BA093F6BF484CA5D2C0742 25677D024080CBA823A5337841229382CA773A1D124 LOCK_DATA_72=49875596E96F916B047EEA29FEDE24C031C32 DDAF1FC29ABB6542B6611F475CD00257A742707E136 LOCK_DATA_73=12D3CAAA323F8259323877FE2A4130CA1D00F 4B0A28FF10EC0C6F33AF377A6C2691ECC2992610980 LOCK_DATA_74=4B620A6FB4240C24E2BA58B9E836FF3891AB2 7EAAFA76AFA300CC9B1719DEDD179FCDF9342A8A229 LOCK_DATA_75=726044789487F4FC684683E85FE42A79955F8 BF74877D9BF214BE6111687109A8EB371BBBF1DD563 LOCK_DATA_76=4A97D7A134B7AE48F215502C343FAAF082730 E826D662D9B616D18B7283FA624ECD60A36912A5C45 LOCK_DATA_77=6C434937F0F77D843ECE215F3383E3A5A8028 B2E77B723F6136129FEA2D4D05B2EA73E2F6342402B LOCK_DATA_78=46276381F86F75723CB1EE5D5892F0AF96818 2DC29EF7DF4461780DDE4B3462EBE0DDE582A7F8271 LOCK_DATA_79=B175C6D265468528E7F0973A2FAC60D23C1A7 0FE5C45F518EB1B8F8A51313FCA616B4178B6BF4AB2 LOCK_DATA_80=FFBBFDBA93477AD4D86BEB121B1B151B1B530 C0DE544354E93B916E81263453C47F8B7D4CE2BEF77 LOCK_DATA_81=989B0ADEF16F79C0D858A1940A0806EAA70B7 FC7F2A197D63A5649C9C1DB54F7FFB450E062E7E54F LOCK_DATA_82=3CB92424BD57CB0737BB17E09C035F630031B 727CE8122AC65F13EE8579AD141AEB8B29C709C935A LOCK_DATA_83=FF1A1FC50425D991E83282BDD5EE771FCB23F 86E49009C454F0E49C5D1F9B931F039A27306391FEC LOCK_DATA_84=71EB119C11426C0AABA680C058375AABBE7DC 97E4BFE482A44F048570EDE4D7F381CF9D0466E18F0 LOCK_DATA_85=08475F6EFBEA1B1E1C997145D2E8EE1CFE34B E6A85B728F4A60554381A0F7C7E9FDEF069EE0F1A15 LOCK_DATA_86=1C89843D1DE7D7F8263E8CCABD436240B9740 6166A1E4CCFEDFA59748976E6D9D03B55CDF277558D LOCK_DATA_87=4BD8D58097FAFCBAC192BD98FEA8092F235BC 14706F804B73210F6CC1AC9DB274C49E406E75A253B LOCK_DATA_88=7515EFE16DE7B6EC6B622595FAC130B29FF74 C2F1EC2489842FDD95E91105EE43F9E8D3B2EDDB9FC LOCK_DATA_89=2017E1A64FBF60057D75F5A613628227A925D 0EF958B9E1FC966034B64B00E0000B0000000010000 LOCK_DATA_90=0002000000AB0FBD96AF2AC271D26264AFDEA D0E006B31090BE5C2B2CC26C47B35214995D7B02BCD LOCK_DATA_91=1008248DB33EBF2CEF9EA1E9B84F9CB72028D 2B9104542CF6D8A3BA04FAA4DFDFE6E32930FEA02A9 LOCK_DATA_92=B77131A416F560FBCF0041323A19D46EB0A96 5C464342CCD021E4C12CCD715018B860B42946CE42E LOCK_DATA_93=C976444CF62953783A4D079154D9E43C430CF 30B740C1E214A15A5379FDE4E3063BFB7A0ADBBAECE LOCK_DATA_94=EFDC78945B81E2DCD2D31D5D32438175677B5 40E55191488A5CDEE7B57F08B907A583A2DC45FBB40 LOCK_DATA_95=570F0A5D1E85EBB44BBB3F9EDDE0160000000 800000000000002000000AB0FBC82AF2AC230C22220 LOCK_DATA_96=AFCEAC00000C3B022C823000F0A222EE330F0 A3B08E33E8A32FCA0C8EC0F20000082A80E080AC2B2 LOCK_DATA_97=3C3B33C800AF80C8E8BFAFB3B22C0CA00302C CF000083C230C83C2C8003AE80E3F3800B0808BB08A LOCK_DATA_98=00030C0C0E028CB000E28820A0C22BA808800 0200E202F00B03E8CC2FC322A0FCCE3BC3F8B83E8C0 LOCK_DATA_99=02EB302A2BF8A30032BC808CACB8CF00F3FCC 080008AE023CF0B08A000E2C0080A2A288220EBE0A8 LOCK_DATA_100=E03CCB888C0F3C3C2F8F88C03B0A03C20020 BCCC028A8C0FCCC303E32E80C8A3832082080A0F88EE LOCK_DATA_101=82008C00C0F320303C8C00C3C80BC00B0883 00E03000B82BA0B002002022C32FCF8F08F2B80008F3 LOCK_DATA_102=CC00A230BCA80E8E00B2A03A2E3AB8030C8B 8A8F0C8AF880B000C83C8AA2228CFE2A0822FC0F2382 LOCK_DATA_103=3CCB0C8C0E28C8B00ECFC2C80A8CCBB2303B 83E83C822C00C830A308CF08AC2C03322B8B0F302023 LOCK_DATA_104=E3EC0E02CB8200B3E000800B80C00E0B00EF 0F2B0A022ACB0C3C8083B8800030300B80E08BA2E0CC LOCK_DATA_105=E208B0CA32F02A30EF2200288F8F88CB8F00 CCAC38AB22A3CBF00C8232C2F0ABF0200CC2B28CE30C LOCK_DATA_106=388AC0BC83080C02080A08C0C3EAEFAE20C0 8288B338F3F0A80CAAB880FB82080C8CF3F02CF8C2FC LOCK_DATA_107=0E0B0028CE00AC2323C3B3882C0BC0828BC2 C23A82F3280880038F8C03AF082E0EF380BC20C228A3 LOCK_DATA_108=BB000C8AEF028C3820BE30BE0E28C3C303EE 38F8B30E028382B08F03A20C0EE2303EBC008080C827 LOCK_DATA_109=2A03CBF3A3BE083B33E0F8C2EBF3C0EABFF3 8A0AFF28CC000880ACC02FBE8AECE320E2A008EAE0F0 LOCK_DATA_110=2B0203F308EB3E2EB23FABF8202E8083C03F 23E808C03B208A08C02BBB200802808A0F30C00E020C LOCK_DATA_111=8030FC80AF02030302800BBE8F28F03A3030 FE02C33000280C02838FCB30080C203300EC2CB0F0E0 LOCK_DATA_112=2A808FCEF8F0330A0E3230CFBCACF2AEA002 2CA032CC330828802CA30F00EA131F4E5775AD334F8B LOCK_DATA_113=D076CCCF8C6F4E05AD7243D8BBA7F8BEA7FB 25831BB8403D8DD8E509D73C09D86F66EFAA59B3CABE LOCK_DATA_114=9B9F2D5E4208B3D5D93C0645C5475435E704 691FD27463A9189014E8523820BA0787E1C80A73ACF7 LOCK_DATA_115=F786857B3929377CF8B433F2D4C864916A33 87386439F5F718CC592C3C0F59948B312C7BC6C3970A LOCK_DATA_116=6348CA50FC4008DFF46357C75A51C9C07BA2 CE108899E309534D5210A80A45AE892C26E4FF38738D LOCK_DATA_117=18D848F36FB9C66AE7A3B4303DE6A19192C9 9646A903E224DC28BC665D60D6CDD875DB1D9B80520C LOCK_DATA_118=F906BFC680CB724EAA3B8123CB3AD4F0FA46 1BBFAFEFDF3AE2D83D7C15982CD8F6760AD6A55F5BE5 LOCK_DATA_119=68AAD206FD87DFF63FF188BE7B45ED2D17FD 8D1DEE2AEE5701E45DC36BDD0BA6C8D22879C26070F1 LOCK_DATA_120=3CCDD86FD5569BE7DCE5577EA2331B814FC6 82786AEAEA024BCA117C581C93ED0B42731B172B27F3 LOCK_DATA_121=38B43367B4A4D692A79C8BA801EECAE4F08F 98AB6876F358D6A549DECACA70D9777CE32A293EB7B8 LOCK_DATA_122=35B04429BB9924261DB483DC6D4FD9174A4D D4C8AB2504CF7FC19D36BE41347FB262C5DF199C6A1E LOCK_DATA_123=D21AF32F1565C1321C3D29BA420A035810D3 85F58A277774AD0652E1DACD47DB07703CE5FF24033B LOCK_DATA_124=10D53E0A5CEE2633A77C6E094E4C9A86489A F2817AF3F62945EBE65240059750518776DA527C14F9 LOCK_DATA_125=813A236D11F89C87809BBD55FEF6CA1648B5 45887A3B5ABBC54CCEF6EBF8D3151BE69B30E34E89E9 LOCK_DATA_126=00FB9B5FF2C642EBB018F74C0BEF4739B4DD E07B6CFE1F829572FDFB0F29D682C130E69F11AD9165 LOCK_DATA_127=4605FCCAD44CF1748487CC849661B7B414C3 61B1F6B95472C7B7F1AAB5A6AEBDEF6283D1704AA8B4 LOCK_DATA_128=95987901A6986D8EF7D918DB2B3BDAD307C0 099AF3DA9BF5FF63B3357C6C6020B3F3F68100EA60A9 LOCK_DATA_129=93E0240F846CD9D0667A72E77890D235D390 149E6F97F511DB3CE877B0C0677F5D0A029EA0D2A3E9 LOCK_DATA_130=8979F55D6D922E3A6FDA824ABCB0169D5CD1 38B2F986C9CF9FC21FD76A34F8B5690C36A8D8A6B5B5 LOCK_DATA_131=671EFE9BFE3AA6C64135B7FEEBE5ACD7D1B3 9C8EFC3167CF69D536BE155A7702E31792E91EC4C8AB LOCK_DATA_132=3FE5454D17A9C509890756C48A471FCDF532 A1FBBC2A4D5443EE613D451C1DF1A593727C02F55A0D LOCK_DATA_133=15477EB24C95EFD6B0842C259BE5A0DC6A12 8413072249E953397F3F0783653647E90397DAFAEECF LOCK_DATA_134=74F8F1BC5C35C02FBC23A21E80175EE07E2D 9D77B9E1E38D88EB56C7C8015C0FFEB3F6BE81478F88 LOCK_DATA_135=1FCF63B3271811D994137582E0357D0309A8 7E5A4D834166DE39DCB6F679111DBFEB36B63E18B76C LOCK_DATA_136=20411A4E3E284B6AAF7520A2D1045121FB87 9FDD94A8CB1576C1EAFF495A85FF1CAC3DB65F198D8A LOCK_DATA_137=21D54EF63F3C7539C57A0EE591F004977299 60FCF93DEA0538361A7C2261A6D3F4C93C24AC4B7984 LOCK_DATA_138=02A299E84D59F23D76130E5E70B8C59E59DF 934FEFD4D6252ED9051C7FA68E22093A23D2F57CA10E LOCK_DATA_139=6B81469034B57BD282C9A5ED8E9657CE241B FCC52F1143B93567C7C17E5FFAA01D6457EA8EEDD12C LOCK_DATA_140=D38627134F650B24DD51E86BE458282ACFDE F7F7E865ABA2294D4929717ADDC52945D4432DDECF3F LOCK_DATA_141=14D84070A57FE39E3B266A5E142603F5CCC2 B761E977F9BBB496DFEE35C912C08C88952D7720D8A2 LOCK_DATA_142=A120183F53977A7EAAC4711F00B726E47F51 83495E3720F91C898F423ECDD87FF092B3255F26D97F LOCK_DATA_143=00F3A450BEC7EB72EB2799E4A4778BBB738F F5AA9D3B09AAE9293C83FB7B907FFACD8FA1CAFCBE97 LOCK_DATA_144=0A9DA575FCA6B69E45DC15A4B7C6852AC6D0 2B906A4DE1E3966E82F600F3262CC17E49DD71F18BFF LOCK_DATA_145=5DBE59CB82BC5A2E7C4201AC5391C10B0451 13426DF563A19659BC80BE5A5BEE1F490172A7DC75D9 LOCK_DATA_146=948B02D4B8F4C2F0FB3EF7B91EA797D1D17D 15B71A3B8EFEDBD7A09B460A63F15CB9BA66C74421F4 LOCK_DATA_147=2F65C1EF491E8D052CA99C6550F9A8E6B4DE 7DB9E2B899EC7DFA1F254FFFFFFFFF00080000020000 LOCK_DATA_148=0002000000AB0FBD96AF2AC271D26264AFDE AD0400A6016194CF496D3B35DAC8634AC66ABF3C2504 LOCK_DATA_149=18C5D946198065A83E37DDADB60D1891D09D FD471871A4A27AF3B8046845486381EBA2DD2C978AA4 LOCK_DATA_150=4DE1452D5725431F913CC4EB2F486A4919CD C0B31FB8DE06AC5E791526F016DCE3657C1AC8303118 LOCK_DATA_151=B706C301ABE6E451D56618B17B0FA5D90FF5 5CF518F9487036700997F2A222C44491FC26F9C7ED54 LOCK_DATA_152=4778AF771BF99AD75F1D7E958D16678EA43C 31EF0C68ECAF2C42F42097718ED5A15E383C61E52B2D LOCK_DATA_153=91333C9F76CA57271A4210B8C56164FF3AF3 67E96B6D54CA80F92A266B074C7BC9DD2320327CB7EA LOCK_DATA_154=97A09631E27781C91F382B5A4B6DA95BE034 1E4E696143264D03108AC6A670AF0D9D02EE73D827B2 LOCK_DATA_155=3105DFB18DD38C36035186CCD18C2EC47DBF 30D4E81AE1974FC525FD14A24DD5CE8F104C8B6ACB1F LOCK_DATA_156=5A5A51713D9587ADD9816FC55ACCBE792D4A 71D9E00E24265A38E5E221B655CE3AEC52124DC745B8 LOCK_DATA_157=D94AC28478EEEFDA610EC6230F0111969706 F93DFD1E011586C99853566A9197EC31A3AE6C6A7C26 LOCK_DATA_158=BF36851A8E0F204EA16260C1EBD6AD1EDE17 4F0324667B2785E7FACDBAAC872C92D96DD64704A53A LOCK_DATA_159=86AEEA4953A74F902AC0D23BE8B96BDB37D3 99799880E4B26D072A19C072858A676F58E73B51D984 LOCK_DATA_160=B30B05FCD90530113BF03BE557708A8DBA35 6F776F69E074851A04667FAB5E7F553C7290221FBD53 LOCK_DATA_161=6A58FD4EE2AF3EB46B2D30B1C1389D523F8F 4C48206C5B0843A855DEE19BBF72BAB6E886B1D9D433 LOCK_DATA_162=2B8F6E6676AD6B5C164366435C3C3FA260E2 3840811AD1227C9936AAD281FCD08176915392A39A83 LOCK_DATA_163=FEAF15690AD8F3813FEE7962CB6753986365 43867B649F9302DC69E9B16B68C6DBDBEFA29C223774 LOCK_DATA_164=A66FA82241B58F3DEDCA935B0EB2714EC915 49EE7C12CAAD6911ECEF99A7FF240FB4621C261AF59E LOCK_DATA_165=B1041D6994F6272E1940DA74A7DDC37B078D 12FEF77950D3C441FEB9F36D490CF7F19C525CC6D840 LOCK_DATA_166=2E484C5234EAE64AF3E9E4F31137B9C89E24 C4C47091FF1A9F36AB9027D49EB4FE4CCA6821B2C1FB LOCK_DATA_167=BC0D52CADB86578E29ACBAA7C9269A512DA6 D843BA8832398053FEB85CD18702B55C8570DA48AD75 LOCK_DATA_168=0B06BA0DD61D34A27D8C36FB833408C47AE6 B7B3C352F2A85CBF4C575861D64A5CE705F2B9F2FAF4 LOCK_DATA_169=9A068072DB41D7082E7A8C59DB024047AA2B 9DA7726A20119CFD5B0C2A0665532CF21E4BB913B28C LOCK_DATA_170=CCBC44B2B36BA34ED9B8E65A84FE2210B51E C71A70B133027DE5359E53F62AC14F3294C17FBC916D LOCK_DATA_171=B4202017F3210085F3C08B84652C6521CE8D 0CA85D9EA5451C8913943680E0EB779FBEE49430D9E5 LOCK_DATA_172=7D51AE04F9AB3B645BCB6A8D4C6105D1DE7C 11DD9795CC1048705C6C79C2E1608AFA29A62D2528F0 LOCK_DATA_173=219D83EE7A02F34AE262076D79F1EB0597AB AB15E268CE9E0E4181CFA2193F8B6DB2321307254704 LOCK_DATA_174=272603CF417DDFFA6C020158C15FCF277279 70A12161B459FEBF94350264E942BCF99AFB73CB3906 LOCK_DATA_175=793BD5120123CACA082809011609FC2F42B0 EE38E8D39BA4BAC0D345CE8EC8B3558FD604EBE43A04 LOCK_DATA_176=E158B1DFA4E2BBD4D49EFDE72AF05CA57677 C22458BB45E90A2FFB3D7F1DA12C3C82008B713AE851 LOCK_DATA_177=C9F736468412F13BABF0627C71D14B63954C 0B1F4D15784C49EC78E0626EC9143BEF36C8F0BF66E8 LOCK_DATA_178=634EF8CC814AD55493935BE1104BA8A75394 279E43356A17145C17CB126EC3016D6E3E93B20336F7 LOCK_DATA_179=CCC9A35EFF07E44BEA69DC62059C81E6A553 1E08463FB4525B15FBB9CC6A007DCE4915B76491AC1D LOCK_DATA_180=DFDF4A1FA763156D0EBAD54E1AF41EB1EE9F FCD157B5E77184470F40FC1D2FF69E130CAD90C8CB20 LOCK_DATA_181=F71D322AA943365AEBC720103E16F2CC3E90 ACEE70029BAC18777AC4E4D4C3F834EC5479698111D9 LOCK_DATA_182=514BF7A6F9E1E5A8D4A3CE36E8E0E0616079 4B6CDED9D0EBD244C7D5295E270C3E18F8AA30A4345E LOCK_DATA_183=523892C17EE6773EB8113F9D26DC2E148AA5 B81BEC4093C929A316D7FB2DEDB1BC5FC6C8C8427175 LOCK_DATA_184=721B6C3255536D4E795209B11FBCD3CCDF0A FF588105E27181DF66A056EDCA029E3449148C309E99 LOCK_DATA_185=4F962B23275194D83616D8B55D90A5633B27 95263DA33EB22510026CFFFC2958F3AF07DB8C512A14 LOCK_DATA_186=7ED4C668B07EC1D66DF350761E4DF8AA05F9 262D704A215B027419A208D7CD76B4CA740EAD0353F8 LOCK_DATA_187=395B700A9C7A3D363D213F363D22269423C1 4C0CCE876D05FFE20AE029D1EBD66C906E0BB1A1372E LOCK_DATA_188=436B960A4C6058EEAEEE21286A1091DFAEEE 6203D5B3D1DF54576E6A50D0471E805F5F9CD1780BDD LOCK_DATA_189=6C99756515BC7B0F34BCE78FD28240847A7C B85C7F613F6AB9F4BABBFA310D178DD988A5A7477823 LOCK_DATA_190=1AF779A636D0AF383E7F71C9055374A29D99 1F82C4BABB7A2DC055137E097C2B197D6ABEDAD24291 LOCK_DATA_191=29F46A3443D2C3C68BE4C946625CF7673201 2A1CD993EC6D9F152A03A2063A356A40F32B8A82135A LOCK_DATA_192=657F844EC3EE4E315F862F9460FF3C57E448 6A7A629C015EDD1ADD68B07CAF575054BFBBDC749BC3 LOCK_DATA_193=FCF029D41A69059F9DB7CA4503CADDC9E8A7 4572ED49C812FF816989B407AFC5E7B360505E9F8106 LOCK_DATA_194=5F5017A15BB05814696F6368CB39AB01273B E9F9496E5B3DD4EAD7D0FA32EBB14A05BD0002BF7FC3 LOCK_DATA_195=CA5E92D8D96AC70AE98793806EEB3C77653E BE3CD655175FE95CE6D734B546C4ACB7F21A2641F669 LOCK_DATA_196=014FE7D71F4D4734A28D8C30165420B35ED4 0AAA414A3FC7327B4EA654D3E180388C215627CB3EE9 LOCK_DATA_197=7472294BB3A631022F1785F15C458A82006B A427F77AFC75DDEEB56134C1C845018B3ECC50140FE5 LOCK_DATA_198=5D4C47E83EE726A4C85393B5A14C6DDF7B4A FC5A91D850787BB625E54CBF12CCA36960B050D93133 LOCK_DATA_199=FA490A68843686373A658750C1782CE046AF A522C744C8B07F88CAD1E7E743613FD7D71E25FC6DDB LOCK_DATA_200=4465204F2D00000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_201=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_202=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_203=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_204=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_205=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_206=000000000000020001C00003000103000400 01070005000A31323334350000000000000600010400 LOCK_DATA_207=070001000008000100000900280000000000 00000000000000000000000000000000000000000000 LOCK_DATA_208=00000000000000000000000000 BB_DATA_1=0135000900000004010000000001000201190002 000CFE05010005000000663300000004000C0101 BB_DATA_2=0100DC090000185300000005000C02010100A6FF FFFF08FB01000007000C040202008C0400000000 BB_DATA_3=00000008000C050303004F08A00F2A0100000011 000C0E06010000000000732600000016000C1301 BB_DATA_4=01000000000010270000 |
05-05-2011, 07:49 | #5 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Bro u need this 1- Backup NPC DATA RPL (Just NPC) 2- Full Erase With Erase File (with Hwk) 3-Flash with Any Version 4-after Flas Write this rpl its ur set rpl 353225035145461_BACK.zip 5- after write rpl repair sd 6- then write Full Pm with SX4 Auth ur problem Solve 1000% tested 4 times on 3110c if simlock data block currupted then need to repair simlock data but Security test 100% solve |
05-05-2011, 08:16 | #6 (permalink) | |
Member: 1087883 Status: Offline Sonork: 100.1651719 Thanks Meter: 38 | Quote:
Thank u friend i just write your modified Rpl n write PM with SD Auth Problem Solved ...Here complete log . SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 MXKEY Serial: [FT SCR2000 0] - Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1A20020854DE7E56081112F14017AE571F8520CB] ... Calculating using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 25, size 4 bytes written. - Key: 29, size 6 bytes written. - Key: 34, size 80 bytes written. Section: 2 - Key: 0, size 432 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 64 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 16 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 16 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 2 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 1 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 1 bytes written. - Key: 27, size 1 bytes written. - Key: 28, size 1 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 1 bytes written. - Key: 39, size 1 bytes written. - Key: 40, size 1 bytes written. - Key: 41, size 1 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 1 bytes written. - Key: 51, size 1 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 bytes written. - Key: 69, size 1 bytes written. - Key: 70, size 1 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 bytes written. - Key: 79, size 1 bytes written. - Key: 80, size 1 bytes written. - Key: 81, size 1 bytes written. - Key: 82, size 1 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 1 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 1 bytes written. - Key: 117, size 1 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 bytes written. - Key: 121, size 1 bytes written. - Key: 122, size 1 bytes written. - Key: 123, size 8 bytes written. - Key: 124, size 1 bytes written. - Key: 125, size 1 bytes written. - Key: 126, size 1 bytes written. - Key: 127, size 1 bytes written. - Key: 128, size 1 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 131, size 1 bytes written. - Key: 132, size 1 bytes written. - Key: 133, size 2 bytes written. - Key: 134, size 1 bytes written. - Key: 135, size 2 bytes written. - Key: 136, size 1 bytes written. - Key: 137, size 1 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 140, size 1 bytes written. - Key: 141, size 1 bytes written. - Key: 142, size 1 bytes written. - Key: 143, size 1 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 148, size 1 bytes written. - Key: 149, size 1 bytes written. - Key: 150, size 1 bytes written. - Key: 151, size 1 bytes written. - Key: 152, size 1 bytes written. - Key: 153, size 1 bytes written. - Key: 154, size 1 bytes written. - Key: 155, size 1 bytes written. - Key: 156, size 1 bytes written. - Key: 157, size 1 bytes written. - Key: 158, size 1 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 161, size 1 bytes written. - Key: 162, size 1 bytes written. - Key: 163, size 1 bytes written. - Key: 164, size 1 bytes written. - Key: 165, size 1 bytes written. - Key: 166, size 1 bytes written. - Key: 167, size 8 bytes written. - Key: 168, size 4 bytes written. - Key: 169, size 1 bytes written. - Key: 170, size 1 bytes written. - Key: 171, size 1 bytes written. - Key: 172, size 1 bytes written. - Key: 173, size 1 bytes written. - Key: 174, size 1 bytes written. - Key: 175, size 1 bytes written. Section: 31 - Key: 4, size 12 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 55 - Key: 0, size 80 bytes written. - Key: 1, size 2 bytes written. Section: 56 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. Section: 59 - Key: 0, size 63 bytes written. Section: 65 - Key: 0, size 11 bytes written. - Key: 1, size 11 bytes written. - Key: 2, size 11 bytes written. - Key: 3, size 11 bytes written. - Key: 4, size 11 bytes written. Section: 66 - Key: 0, size 160 bytes written. - Key: 1, size 160 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 160 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 160 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 4 bytes written. - Key: 14, size 4 bytes written. - Key: 16, size 4 bytes written. - Key: 17, size 4 bytes written. - Key: 18, size 4 bytes written. - Key: 19, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 36, size 4 bytes written. - Key: 38, size 4 bytes written. - Key: 40, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 4 bytes written. - Key: 53, size 1 bytes written. - Key: 64, size 8 bytes written. - Key: 65, size 8 bytes written. - Key: 66, size 8 bytes written. - Key: 67, size 8 bytes written. - Key: 68, size 8 bytes written. - Key: 70, size 8 bytes written. - Key: 82, size 8 bytes written. - Key: 83, size 8 bytes written. - Key: 84, size 8 bytes written. - Key: 86, size 20016 bytes written. - Key: 87, size 6144 bytes written. - Key: 88, size 300 bytes written. - Key: 89, size 40 bytes written. - Key: 99 skipped, frame length too long - Key: 104, size 43 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 4 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 4 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 2 bytes written. - Key: 118, size 4 bytes written. - Key: 120, size 4 bytes written. - Key: 121, size 4 bytes written. - Key: 122, size 4 bytes written. Section: 67 - Key: 0, size 2756 bytes written. Section: 76 - Key: 0, size 534 bytes written. Section: 84 - Key: 0, size 3 bytes written. Section: 87 - Key: 0, size 4 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. Section: 110 - Key: 0, size 6 bytes written. Section: 111 - Key: 0, size 200 bytes written. - Key: 1, size 20 bytes written. - Key: 2, size 20 bytes written. - Key: 126, size 20 bytes written. - Key: 127, size 20 bytes written. - Key: 150, size 8 bytes written. - Key: 151, size 4 bytes written. - Key: 152, size 40 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 19, size 40 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 163 - Key: 0, size 8 bytes written. Section: 181 - Key: 0, size 8 bytes written. - Key: 1, size 10 bytes written. - Key: 2, size 1 bytes written. Section: 182 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 183 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 184 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 185 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 186 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 187 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 188 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 190 - Key: 0, size 355 bytes written. Section: 191 - Key: 0, size 5 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 200 - Key: 0, size 5 bytes written. Section: 202 - Key: 4, size 42 bytes written. Section: 213 - Key: 0, size 20 bytes written. Section: 215 - Key: 0, size 84 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 225 - Key: 0, size 1 bytes written. - Key: 1, size 6 bytes written. - Key: 2, size 6 bytes written. Section: 232 - Key: 0, size 20 bytes written. - Key: 1, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 1 bytes written. Section: 238 - Key: 1, size 1 bytes written. Section: 250 - Key: 1, size 1116 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 392 bytes written. - Key: 4, size 36 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Section: 319 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. Section: 321 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4902 bytes written. Completed in 24.765 s Phone authenticated to SUPERDONGLE already. Phone authenticated to SUPERDONGLE already. Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 25, size 4 bytes written. - Key: 29, size 6 bytes written. - Key: 34, size 80 bytes written. Section: 2 - Key: 0, size 432 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 64 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 16 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 16 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 2 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 1 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 1 bytes written. - Key: 27, size 1 bytes written. - Key: 28, size 1 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 1 bytes written. - Key: 39, size 1 bytes written. - Key: 40, size 1 bytes written. - Key: 41, size 1 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 1 bytes written. - Key: 51, size 1 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 bytes written. - Key: 69, size 1 bytes written. - Key: 70, size 1 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 bytes written. - Key: 79, size 1 bytes written. - Key: 80, size 1 bytes written. - Key: 81, size 1 bytes written. - Key: 82, size 1 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 1 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 1 bytes written. - Key: 117, size 1 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 bytes written. - Key: 121, size 1 bytes written. - Key: 122, size 1 bytes written. - Key: 123, size 8 bytes written. - Key: 124, size 1 bytes written. - Key: 125, size 1 bytes written. - Key: 126, size 1 bytes written. - Key: 127, size 1 bytes written. - Key: 128, size 1 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 131, size 1 bytes written. - Key: 132, size 1 bytes written. - Key: 133, size 2 bytes written. - Key: 134, size 1 bytes written. - Key: 135, size 2 bytes written. - Key: 136, size 1 bytes written. - Key: 137, size 1 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 140, size 1 bytes written. - Key: 141, size 1 bytes written. - Key: 142, size 1 bytes written. - Key: 143, size 1 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 148, size 1 bytes written. - Key: 149, size 1 bytes written. - Key: 150, size 1 bytes written. - Key: 151, size 1 bytes written. - Key: 152, size 1 bytes written. - Key: 153, size 1 bytes written. - Key: 154, size 1 bytes written. - Key: 155, size 1 bytes written. - Key: 156, size 1 bytes written. - Key: 157, size 1 bytes written. - Key: 158, size 1 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 161, size 1 bytes written. - Key: 162, size 1 bytes written. - Key: 163, size 1 bytes written. - Key: 164, size 1 bytes written. - Key: 165, size 1 bytes written. - Key: 166, size 1 bytes written. - Key: 167, size 8 bytes written. - Key: 168, size 4 bytes written. - Key: 169, size 1 bytes written. - Key: 170, size 1 bytes written. - Key: 171, size 1 bytes written. - Key: 172, size 1 bytes written. - Key: 173, size 1 bytes written. - Key: 174, size 1 bytes written. - Key: 175, size 1 bytes written. Section: 31 - Key: 4, size 12 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 55 - Key: 0, size 80 bytes written. - Key: 1, size 2 bytes written. Section: 56 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. Section: 59 - Key: 0, size 63 bytes written. Section: 65 - Key: 0, size 11 bytes written. - Key: 1, size 11 bytes written. - Key: 2, size 11 bytes written. - Key: 3, size 11 bytes written. - Key: 4, size 11 bytes written. Section: 66 - Key: 0, size 160 bytes written. - Key: 1, size 160 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 160 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 160 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 4 bytes written. - Key: 14, size 4 bytes written. - Key: 16, size 4 bytes written. - Key: 17, size 4 bytes written. - Key: 18, size 4 bytes written. - Key: 19, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 36, size 4 bytes written. - Key: 38, size 4 bytes written. - Key: 40, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 4 bytes written. - Key: 53, size 1 bytes written. - Key: 64, size 8 bytes written. - Key: 65, size 8 bytes written. - Key: 66, size 8 bytes written. - Key: 67, size 8 bytes written. - Key: 68, size 8 bytes written. - Key: 70, size 8 bytes written. - Key: 82, size 8 bytes written. - Key: 83, size 8 bytes written. - Key: 84, size 8 bytes written. - Key: 86, size 20016 bytes written. - Key: 87, size 6144 bytes written. - Key: 88, size 300 bytes written. - Key: 89, size 40 bytes written. - Key: 99 skipped, frame length too long - Key: 104, size 43 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 4 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 4 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 2 bytes written. - Key: 118, size 4 bytes written. - Key: 120, size 4 bytes written. - Key: 121, size 4 bytes written. - Key: 122, size 4 bytes written. Section: 67 - Key: 0, size 2756 bytes written. Section: 76 - Key: 0, size 534 bytes written. Section: 84 - Key: 0, size 3 bytes written. Section: 87 - Key: 0, size 4 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. Section: 110 - Key: 0, size 6 bytes written. Section: 111 - Key: 0, size 200 bytes written. - Key: 1, size 20 bytes written. - Key: 2, size 20 bytes written. - Key: 126, size 20 bytes written. - Key: 127, size 20 bytes written. - Key: 150, size 8 bytes written. - Key: 151, size 4 bytes written. - Key: 152, size 40 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 19, size 40 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 163 - Key: 0, size 8 bytes written. Section: 181 - Key: 0, size 8 bytes written. - Key: 1, size 10 bytes written. - Key: 2, size 1 bytes written. Section: 182 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 183 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 184 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 185 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 186 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 187 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 188 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 190 - Key: 0, size 355 bytes written. Section: 191 - Key: 0, size 5 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 200 - Key: 0, size 5 bytes written. Section: 202 - Key: 4, size 42 bytes written. Section: 213 - Key: 0, size 20 bytes written. Section: 215 - Key: 0, size 84 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 225 - Key: 0, size 1 bytes written. - Key: 1, size 6 bytes written. - Key: 2, size 6 bytes written. Section: 232 - Key: 0, size 20 bytes written. - Key: 1, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 1 bytes written. Section: 238 - Key: 1, size 1 bytes written. Section: 250 - Key: 1, size 1116 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 392 bytes written. - Key: 4, size 36 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Section: 319 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. Section: 321 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4902 bytes written. Completed in 28.656 s SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed | |
05-05-2011, 08:22 | #7 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bharat
Member: 1087883 Status: Offline Sonork: 100.1651719 Thanks Meter: 38 | Thanks to all ur valuable guidence i m back on track thanks to all i m trying my other 2 handsets n one more help how can i find RPL corrupt or abd n how to edit RPL.... |
05-05-2011, 08:31 | #8 (permalink) |
Member: 1087883 Status: Offline Sonork: 100.1651719 Thanks Meter: 38 | Wait here another problem its show one ok if check other time shows test failed SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! |
05-05-2011, 08:36 | #9 (permalink) | |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
05-05-2011, 08:40 | #10 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | 1 way more to repair security test fail problem if u do all steps with my steps too. u need to backup rpl npc data and after backup just write any other 3110c full rpl with npc when u complete this then u see ur set npc data 123456 just write modify rpl already uploaded in this thead. and repair sd or write full pm with ppm auth problem solve tested |
05-05-2011, 08:40 | #11 (permalink) |
No Life Poster Join Date: Feb 2011
Member: 1517329 Status: Offline Sonork: 100.1647599 Thanks Meter: 263 | hey try this way.. 3110 fbus+hwk+mx key in mx key -- goto service tab -- pm tab-- then tick "LOAD RF/BB FROM SERVER" --- then press "SUPER SD Auth" - -after getting authentication from server -- then press pmm and final press write 100%working try |
05-05-2011, 08:44 | #12 (permalink) | |
it's simple but effective | |
05-05-2011, 09:45 | #13 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan
Member: 277937 Status: Offline Thanks Meter: 48 | Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK problem here only write npc from backup and ccc hwc varient data load from server and relaxe |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
