03-10-2010, 14:27 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1256246 Status: Offline Thanks Meter: 1 | 3110c security test failed please help.. Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35678902xxxxx Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2008-11-12T09:10:26Z SW Version: 07.21 Variant Version: 013 ProductProfile: RM237_0514950_07.21_013.spr Simlock: 0514950_simlock.bin Imei net: 35678902xxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 when i try selt test it say 93 security failed someone told me to buy rpl.because the rpl is damaged.does mxkey sell rpl or is there another way around this without buying rpl.sorry for asking i'm a newbie with this br |
03-10-2010, 14:52 | #2 (permalink) |
Insane Poster Join Date: Mar 2008 Location: algeria
Member: 729517 Status: Offline Thanks Meter: 12 | write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair |
03-10-2010, 14:55 | #3 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: QQ:2557307931
Member: 1010502 Status: Offline Sonork: whats this?! Thanks Meter: 316 | Quote:
do Super SD Auth then Write this pm file RapidShare: 1-CLICK Web hosting - Easy Filehosting | |
03-10-2010, 15:30 | #5 (permalink) | |
Member: 1256246 Status: Offline Thanks Meter: 1 | Quote:
sir could i ask from you a good rpl and a good pm because as of the moment i don't have a working phone at hand..thanx br | |
03-10-2010, 15:55 | #8 (permalink) |
Member: 1256246 Status: Offline Thanks Meter: 1 | [QUOTE=Y.P.Y;5550826]All U Need do Super SD Auth then Write this pm file RapidShare: 1-CLICK Web hosting - Easy Filehosting[/QUOTE which one sir?it has four pm inside br |
03-11-2010, 06:57 | #14 (permalink) | |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | Quote:
6120c \SD Repair\Security Repair\SimLock Invalid\All Solution By MX-KEY - GSM-Forum | |
03-11-2010, 07:08 | #15 (permalink) | |
No Life Poster Join Date: Oct 2009 Age: 37
Member: 1149013 Status: Offline Thanks Meter: 247 | Quote:
[email protected] [email protected] br Mohammed Imran Hashmi | |
3110c - Security Test Failed. Help! | [Shadab_M] | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-30-2010 09:43 |
5220 security test failed please help... | joebastian | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-08-2010 11:05 |
7210 security test failed please help | cellcarekphb | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-06-2010 12:42 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
my 3110c contact service security test failed.........please help me(with video File) | swechacnu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-12-2009 12:22 |
