Old 05-07-2010, 12:27   #1 (permalink)
babloojaved's Avatar
Member: 890104
Sonork: 100.1597567
Thanks Meter: 138
3110c usb flashing sucess (after hwk blk error)
DEAD PHONE RECOVERED FROM MX KEY ALL THANKS TO ALIM & MANOLE
With hwk
1ST BOOT : C0,07 [Rm-237] [2.1.0.1]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 0EB00009DD0D7F5683E6B3B783D82E46B904C6A9
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898981-00006A21, Int NU48F256
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm237__07.21.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 00:36
DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable !
DATA_BLK_ERROR at: 0x00604400, 03
ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x004000, Time: 01:14
Process Failed, Repowering Mobile
THEN FLASHED WITH MXKEY USB FLASHING
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Processing file: rm237__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3
RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
RAP EM0 ID: 00000232
RAP EM1 ID: 00000353
RAP PUBLIC ID: 0EB00009DD0D7F5683E6B3B783D82E46B904C6A9
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
RAP ROM ID: 191EC665DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 1762B225
[ADL] Verifying communication to device OK.
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.890 s
CMT NOR area [000006C0-0001FFFF] erased in 0.906 s
CMT NOR area [00020000-0007FFFF] erased in 2.688 s
CMT NOR area [00080000-000DFFFF] erased in 2.219 s
CMT NOR area [00100000-001FFFFF] erased in 6.313 s
CMT NOR area [00200000-0031FFFF] erased in 8.296 s
CMT NOR area [00320000-0105FFFF] erased in 1 min 32.547 s
CMT NOR area [01060000-01067FFF] erased in 0.859 s
CMT NOR area [01068000-0107FFFF] erased in 0.813 s
Flash programming ...
CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
Programming completed in 50.609 s
Processing file: rm237__07.21.ppm_mr as PPM
[BB5,BB5 ALGORITHM] size: 3.55 MB
Erase size: 4.62 MB
CMT NOR area [01080000-0151FFFF] erased in 31.734 s
Programming completed in 12.266 s
file rm237__07.21_sd_allmost_empty_512.fpsimage is empty, skipped.
Processing file: rm237__07.21.image_mr as CNT
[BB5,BB5 ALGORITHM] page size: 64 K size: 4.00 MB
Erase size: 10.75 MB
CMT NOR area [01520000-01FDFFFF] erased in 1 min 36.062 s
Programming completed in 14.062 s
[ADL] Device found: nmwcdc\Nokia 3110 classic USB Generic, ID: 192618D5
Flashing completed in 6 min 28.313 s
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 3531830399XXXX-X
Product Code: 0581437
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3531830399XXXXX
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 6 min 29.922 s
The Following 4 Users Say Thank You to babloojaved For This Useful Post:
Old 06-04-2010, 13:28   #2 (permalink)
moinuddin111's Avatar
Member: 864102
Sonork: 100.1617637
Thanks Meter: 146
success usb flashing with this trick
Originally Posted by stelecom.2009 View Post
usb ko kasi select kara flaesh karnai ka trika kay hai
1st you select nokia usb rom and connect, then choose nokia service tool and choose model for hand set then select mcu file, ppm file, cnt file then click flash buttone and power on for handset imagitly....
Old 06-04-2010, 13:31   #3 (permalink)
Member: 864102
Sonork: 100.1617637
Thanks Meter: 146
With hwk
what i do when boot file is erased on handset? it not flashed on usb plz help
Old 09-21-2010, 05:59   #4 (permalink)
Member: 383053
thank you my dear friend
Old 09-21-2010, 06:45   #5 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
any one tell me i can flash my 3110c dead phone....with usb?
Old 10-19-2010, 07:38   #6 (permalink)
Member: 855863
1ST BOOT : C0,07 [Rm-237] [2.1.0.0]
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 2FD0000F13A47C561B2C77E53A5762D1B7622EA3
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
CMT FLASH ERASE OK, Time: 00:05
CERT_BLK_ERROR at: 0xFFFFFFFF, 00
ERR: CMT FLASH WRITE C_BLK 000000000000000910000000B172, LN: 0x000600, Time: 00:05
Old 10-19-2010, 07:39   #7 (permalink)
Member: 855863
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
how can i solve this......
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 22:24
Page generated in 0.20938 seconds with 9 queries
