Old 11-22-2010, 10:18   #1 (permalink)
Member: 585878
Thanks Meter: 2
311c failed in flashing (answered)
any idea in this log,?
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
Processing MCU file: rm237__07.21.mcusw
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported Ids: 0103192101001101, 010C192101001101
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 0960010A28A07E565DFE310595FE19625EFB9E53
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.718 s
CMT NOR area [000006C0-0001FFFF] erased in 0.188 s
CMT NOR area [00020000-0007FFFF] erased in 2.031 s
CMT NOR area [00080000-000DFFFF] erased in 0.203 s
CMT NOR area [00100000-001FFFFF] erased in 0.344 s
CMT NOR area [00200000-0031FFFF] erased in 6.812 s
CMT NOR area [00320000-0105FFFF] erased in 57.422 s
CMT NOR area [01060000-01067FFF] erased in 0.172 s
CMT NOR area [01068000-0107FFFF] erased in 0.141 s
Flash programming ...
CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00CE0400, Result: 0010
Flashing terminated with error(s) in 3 min 11.062 s
RX Buffer: C7012D0103CD000010000000F172
Old 11-22-2010, 10:34   #2 (permalink)
Baba Khanikar's Avatar
Member: 1126485
Sonork: 100.1605067
Thanks Meter: 32
Change Cable......this is cable problem....
WBR......
Baba
Old 11-22-2010, 11:03   #3 (permalink)
Haider Ali's Avatar
Member: 756333
Thanks Meter: 152
Unhappy
WBR......
Baba
Yes i think so.............
Old 11-22-2010, 11:08   #4 (permalink)
Member: 521025
Sonork: 100.1605431
Thanks Meter: 154
repair sd
repair sim lock
write pm 1 309
Old 11-22-2010, 11:28   #5 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Originally Posted by gsm_salman View Post
repair sd
repair sim lock
write pm 1 309
salman shb,
set is dead how can repair sd,simlock & write pm?
Read full log with open eyes..
w/s
Old 11-22-2010, 11:40   #6 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Flash the phone with usb.
Br.
Vijendra Saini.
Old 11-22-2010, 13:03   #7 (permalink)
Member: 585878
Thanks Meter: 2
USB flashing log...
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3
CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
CMT EM0 ID: 00000232
CMT EM1 ID: 00000353
CMT PUBLIC ID: 0960010A28A07E565DFE310595FE19625EFB9E53
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID: 191EC665DFAAF68F
Old 11-22-2010, 13:08   #8 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
if ur cable is good than
wash ur phone well,and dry it well
now flash ppm 1st,than image,than mcu ,and also tick mark on skip erese
ur prob will be solve.
Old 11-22-2010, 13:11   #9 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
Br.
Vijendra Saini.
bro,u can not flash via usb if any part of mcu erased.
if i m wrong than give me process also.
Old 11-22-2010, 13:28   #10 (permalink)
..::GMSR::..'s Avatar
Member: 1444462
Thanks Meter: 1,337
do you have ufs3 please try with you.......................
Old 11-22-2010, 13:33   #11 (permalink)
Rhyan777's Avatar
Member: 893209
Thanks Meter: 274
Used LATEST VERSION Bro,,,,
Br,.
Rhyan777
Old 11-22-2010, 19:31   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
what is the phone condition?
- check cable, if you're said cable is good and tested, please update your mxkey.
current version is 3.4 rev 1.6.
- and if this phone is a dead set, check phone hw.
Old 12-03-2010, 11:25   #13 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,107
Your Opinion is not Correct this way many set Permanent De-story 100% kill ............
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 12-03-2010, 17:26   #14 (permalink)
Cheater -Don't Deal with him-
Member: 1179761
Sonork: 100.1602000
Thanks Meter: 1,834
Try with usb
post result
use always update ver
The Following User Says Thank You to nerobdms™ For This Useful Post:
Old 12-08-2010, 14:12   #15 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
no sir i already tested this solution many times
it works 10000%
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-31-1999 04:35
Page generated in 0.25509 seconds with 9 queries
