03-10-2012, 14:51 | #1 (permalink) |
Registered User Join Date: Dec 2006 Location: punjab india
Member: 419331 Status: Offline Thanks Meter: 101 | 3120 rm-19 imei write problam (ANSWERED) ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00DF9228:2984DA60 ASIC type: 2 UEM Imei: 35664D006D1550 Invalid uem checksum, UEM might be damaged ! RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35664D006D1550.RP L" ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00DF9228:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone type: RH-19 (Nokia 3100) SW version: V 06.31 25-11-05 RH-19 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 35664D006D1550 Product code: 0516553 Cellular system: GSM ASIC ID: 0x2142, type: 2 Ppm Id: W Language Pack: English,Chinese S,Chinese T,Hindi Security code: 12345 Imei plain is invalid !!! SIMLOCK_DATA corrupted! |
03-10-2012, 15:08 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. may be your UEM is damaged, see this in your logs: UEM Imei: 35664D006D1550 Invalid uem checksum, UEM might be damaged ! there must be no alphabets in UEM imei, if is there means UEM is gone from my knowledge. |
03-10-2012, 15:37 | #4 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. will you change UEM with new or from other old handset. if you using old then you have to change both UEM & FLASH ic's, there after needs flashing program to make it ok. |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
