Old 02-05-2010, 20:12   #1 (permalink)
Member: 1059036
Thanks Meter: 57
3120 security failed
help nokia 3120c security failed after repair sd done
i tested pm auth and super sd auth and full erase all solution not work
i nead help for reappoint rpl backup
http://www.4shared.com/file/215770426/17f8246c/rpl.html
Old 02-05-2010, 20:48   #2 (permalink)
Member: 923150
Thanks Meter: 6
Same problem with 5220 contact service,,,security test failed,,using notepad,seems pm 120 & 308 seems still coruppted,,
Old 02-05-2010, 21:00   #3 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 105
same problem for me after init simlock. Solved restoring backup and unlocking with codes
Old 02-05-2010, 21:15   #4 (permalink)
Member: 194420
Thanks Meter: 15
http://forum.gsmhosting.com/vbb/show...53#post5377053
Old 02-06-2010, 18:09   #5 (permalink)
h_mobiles's Avatar
Member: 908729
Sonork: 100.1589748
Thanks Meter: 152
there is no other trick to solve the problem dont make games with your mobile first read the forums then do any thing new
some function are under test need time to solve request Zulea and menole
Old 02-17-2010, 09:15   #6 (permalink)
Member: 505554
Thanks Meter: 3
all 3120 hard wear solution
Old 02-17-2010, 09:17   #7 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,971
have u tried all this ??
Info regarding superdongle + security test failed
__________________________________________________ _______________________________________
BB5 ( SL1 SL2 and SL3 ) Imei 123456754321? repair available contact me for details
Old 02-17-2010, 09:23   #8 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,971
just come on team viewer
will solve for u
3120 c Failed! Aborting!...IMEI mohsintariq17 Nokia Hardware & Hardware Repair 9 02-04-2010 15:54
lg new security failed to unlock melgsm Easy-Unlocker 4 12-07-2008 22:20
3110c After SX4 Still Security Failed torpedo_seluler Nokia Base Band 5 ( BB-5 ) 4 06-18-2008 08:56
Page generated in 0.28422 seconds with 8 queries
