Old 02-11-2010, 07:32   #1 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
5130 contact service how to solve
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 15F00102BEED8C56DFC990B032D1E11A20490EFE
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 003F - 0000 8A21 [AMD ] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35933603859570
Original Product code: 0571957
Bluetooth ID: EC9B5BDAE4F7
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.90 23-09-09 RM-495 (c) Nokia
Imei plain: 35933603859570-3
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 112.206.136.190
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 02-11-2010, 07:34   #2 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
after write SD here but same problem
Product: V 07.90 23-09-09 RM-495 (c) Nokia
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 4.859 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-495_359336038595703_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
Version Info:
MCU SW version: V 07.90 23-09-09 RM-495 (c) Nokia
RFIC version: 06540601
DSP version: ICPR72_09w33
LCD version: SEIKO
PPM version: V 07.90 23-09-09 RM-495 (c) Nokia EG
BT MCM version: 2222-302
Retu version: 16
Tahvo version: 22
Content Pack version: Content: eg_red V 07.90 23-09-09 RM-495 (c) Nokia
Product Info:
Production serial number: 0
Long production SN: 0
Serial Numbers:
IMEI plain: 359336038595703
IMEI spare to net: 3A 95 33 06 83 95 75
IMEI SV to net: 33 95 33 06 83 95 75 40 F4
Other Info:
Model : Nokia 5130c-2 (Classic Phone)
CS type : GSM850/GSM900/GSM1800/GSM1900
BSI: 7.2 KOhm
Old 02-11-2010, 07:37   #3 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
first do this
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
if its in same condition then do this
1-Backup Rpl full
2- reset NPC
3- write full modified pm
4- restore imei
5- Repair SD
6- Super SD auth
7- write pm 1 and 309 field only simply not with sx auth
8- Default all setting
best of luck
Old 02-11-2010, 07:39   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
5130 is SL3 phone.
not supported at moment.
br,
The Following User Says Thank You to Andra For This Useful Post:
5130 contact servies how to solve lopo_1984 Universalbox 1 10-17-2009 19:44
1200 contact service how to solve prakashmanwar Nokia Digital Core Technology 4 ( DCT-4 ) 3 01-07-2009 09:54
1650 contact service how to solve shaheb_anl Nokia Hardware & Hardware Repair 12 08-11-2008 09:04
1110i contact service how to solve this ????? texas-gsm Multi-Box 5 07-22-2008 17:53
Page generated in 0.17934 seconds with 10 queries
