Old 02-11-2010, 02:52   #1 (permalink)
richiricherd's Avatar
Member: 594580
Thanks Meter: 157
2630 SIMLOCK_DATA corrupted!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Processing file: rm298__05.62.mcusw as MCU
[DCT4,DCT4 ALGORITHM] size: 10.67 MB
Supported Ids: 3160, 3161, 3162, 3164, 3166
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
Performing Flash Authentication ...OK
UEM ID: 000EFF14:3B8ADA60
Area [01000000-02FFFFFF] erased in 2 min 21.781 s
Flash programming ...
Programming completed in 7 min 18.422 s
File Processed in 9 min 49.266 s
Processing file: rm298__05.62.image_ub_movve_blk_v1 as CNT
[DCT4,DCT4 ALGORITHM] page size: 128 K size: 4.00 MB
FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH - COMBO FLASH
UEM ID: 000EFF14:C5A4DA78
Area [02000000-02DBFFFF] erased in 1 min 1.781 s
Area [02DC0000-02F9FFFF] erased in 8.610 s
Converting UCP blocks to 128 K.
Programming completed in 2 min 45.734 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.078 s
File Processed in 4 min 17.656 s
Processing file: rm298__05.62.ppm_ub as PPM
[DCT4,DCT4 ALGORITHM] size: 2.67 MB
UEM ID: 000EFF14:2984DA60
Area [01C40000-01FFFFFF] erased in 17.578 s
Programming completed in 1 min 49.734 s
File Processed in 2 min 14.610 s
Flashing completed in 16 min 21.656 s
After Flash Processing ...
Updating Product Code OK.
Phone Type: RM-298 (Nokia 2630)
SW Version: V 05.62 02-07-08 RM-298 (c) Nokia
Imei plain: 01140000458110-3
Imei OTP: 01140000458110
Product Code: 0556067
Cellular System: GSM
ASIC ID: 0x3162, type: 11
Ppm Id: UB
Language Pack:
- not available.
Imei net: 01140000458110
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 5555555555555555
PROFILE_BITS: 5555555555015555
Total time to process is 16 min 40.906 s
How to fix please..
Old 02-11-2010, 02:54   #2 (permalink)
Member: 571241
Thanks Meter: 13
Ppm Id: UB
Language Pack:
- not available.
Counter: 0/3, 0/10
How to fix please..
just do unlock brother.
Old 02-11-2010, 05:36   #3 (permalink)
Member: 594580
Thanks Meter: 157
If i do unlock config turn into ok but no network after that..
Old 02-11-2010, 05:43   #4 (permalink)
GsmVeer's Avatar
Member: 1140401
Sonork: 100.1586294
Thanks Meter: 374
just unlock it will be solve
Old 02-11-2010, 05:45   #5 (permalink)
talib007's Avatar
Member: 458868
Sonork: 100.1597325
Thanks Meter: 27
write pm file after unlock
Old 02-11-2010, 05:49   #6 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
Ppm Id: UB
Language Pack:
- not available.
Counter: 0/3, 0/10
How to fix please..
first step full erase > write mcu ppm cnt >then write good pm > then unlock it > ui setting > then all is well
remeber flash the handset with the supportive unlock ver
wbr vicky
nazar2008
Old 02-11-2010, 05:53   #7 (permalink)
Member: 594580
Thanks Meter: 157
wbr vicky
nazar2008
Ok ill try then post results
Old 02-11-2010, 06:47   #8 (permalink)
Member: 594580
Thanks Meter: 157
Sorry but what means UI setting??
Old 02-11-2010, 07:12   #9 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
UI setting means full factory.user data.leave factory. service center.software upgrade.production tuning.reset user code. select these all and press reset all.
The Following User Says Thank You to Ramzan khan For This Useful Post:
how repair SIMLOCK_DATA corrupted! kumar_pvj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 17 05-17-2010 17:41
SIMLOCK_DATA corrupted! R@ZIB-BD MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 07-30-2009 21:43
N85 SIMLOCK_DATA corrupted godlfc MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 07-26-2009 09:45
6681 SIMLOCK_DATA corrupted!?? mdmosheur MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 07-05-2009 07:25
n95 SIMLOCK_DATA corrupted!?? SAN INFOTECH MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 07-03-2009 05:51
Page generated in 0.24253 seconds with 9 queries
