12-23-2009, 12:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | 3500c problem This is the error BLOCK 1: 1=CORRUPTED Any solution? thanks in advance |
12-25-2009, 04:07 | #6 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 55
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0095B76DA3BDA66 ASIC type: 11 UEM Imei: 35293102475185 Connecting to server ...OK, Login ... ends here nothing more....... rpl sevice not works |
12-25-2009, 05:30 | #7 (permalink) | |
Member: 617692 Status: Offline Thanks Meter: 306 | Quote:
Brother check: Have you selected right model for rpl? Are you using updated version of the software? Is your firewall on? if yes then off it BR farihabest | |
...:::Nokia 6233 and Nokia 3500c problem :::... | sujan1050 | Nokia Hardware & Hardware Repair | 9 | 05-04-2011 08:57 |
after sx4b nokia 3500c problem | drjaved_akhter | HWK | 3 | 10-16-2009 16:04 |
unlock 3500c problem,please help | gzraychang | BB5KING | 0 | 11-19-2008 01:19 |
3500c problem | merdjiosse | Nokia Base Band 5 ( BB-5 ) | 3 | 06-01-2008 18:19 |
