05-31-2010, 09:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | 3500c -SIMLOCK invalid! Phone Type: RM-272 (Nokia 3500c) SW Version: V 05.51 06-09-07 RM-272 (c) Nokia. Imei plain: 35768701526556-7 Product Code: 0549248 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! Imei net: 357687015265567 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED |
05-31-2010, 09:24 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PAKISTAN
Member: 833620 Status: Offline Sonork: 100.1586892 Thanks Meter: 259 | 1 write full pm 2 simlock repair 3 sd repair 4 sd auth 5 write pm 1 or 309 |
The Following User Says Thank You to AYAZ42 For This Useful Post: |
05-31-2010, 09:57 | #3 (permalink) |
Member: 694535 Status: Offline Thanks Meter: 70 | when i make repair i receive this error: "'simlock update failed or something went wrong,would you like to restore simlock data from backup ? " Product: V 05.51 06-09-07 RM-272 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.4\data\backup\357687015265567_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 26.500 s Restarting phone ... Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
05-31-2010, 10:03 | #4 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | backup npc data erase phone EEprom full erase phone Flash with LATEST version write backup npc data repair SD repair SIMLOCK make SD AUTH write PM w/o field 1,309 post result. |
05-31-2010, 10:09 | #5 (permalink) |
Freak Poster Join Date: Mar 2006 Location: RP
Member: 241650 Status: Offline Thanks Meter: 71 | 1) Repair simlock first by this procedure http://forum.gsmhosting.com/vbb/5413846-post8.html 2) SD Repair 3) SD Auth 4) Write pm 1 & 309 only |
05-31-2010, 10:24 | #6 (permalink) | |
Member: 694535 Status: Offline Thanks Meter: 70 | Quote:
doesn't work ....... | |
05-31-2010, 10:24 | #7 (permalink) | ||
how do i erase eeprom and full erase with mxkey? | ||
06-01-2010, 17:04 | #9 (permalink) |
Member: 694535 Status: Offline Thanks Meter: 70 | Product: V 05.51 06-09-07 RM-272 (c) Nokia. Using cached productData[29B0011104A66E56AE215B37584A8040E0C3343E] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Completed in 2.031 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-272_357687015265567_SD.RPL" Updating SUPERDONGLE_KEY ...OK Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 29 (6 bytes) Warning: failed to write 1 - 34 (80 bytes) Section: 2 - Key: 0, size 432 bytes written. Section: 3 - Key: 0, size 6 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 64 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 16 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 16 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 2 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 1 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 1 bytes written. - Key: 27, size 1 bytes written. - Key: 28, size 1 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 1 bytes written. - Key: 39, size 1 bytes written. - Key: 40, size 1 bytes written. - Key: 41, size 1 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 1 bytes written. - Key: 51, size 1 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 bytes written. - Key: 69, size 1 bytes written. - Key: 70, size 1 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 bytes written. - Key: 79, size 1 bytes written. - Key: 80, size 1 bytes written. - Key: 81, size 1 bytes written. - Key: 82, size 1 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 1 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 1 bytes written. - Key: 117, size 1 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 bytes written. - Key: 121, size 1 bytes written. - Key: 122, size 1 bytes written. - Key: 123, size 8 bytes written. - Key: 124, size 1 bytes written. - Key: 125, size 1 bytes written. - Key: 126, size 1 bytes written. - Key: 127, size 1 bytes written. - Key: 128, size 1 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 131, size 1 bytes written. - Key: 132, size 1 bytes written. - Key: 133, size 2 bytes written. - Key: 134, size 1 bytes written. - Key: 135, size 2 bytes written. - Key: 136, size 1 bytes written. - Key: 137, size 1 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 140, size 1 bytes written. - Key: 141, size 1 bytes written. - Key: 142, size 1 bytes written. - Key: 143, size 1 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 148, size 1 bytes written. - Key: 149, size 1 bytes written. - Key: 150, size 1 bytes written. - Key: 151, size 1 bytes written. - Key: 152, size 1 bytes written. - Key: 153, size 1 bytes written. - Key: 154, size 1 bytes written. - Key: 155, size 1 bytes written. - Key: 156, size 1 bytes written. - Key: 157, size 1 bytes written. - Key: 158, size 1 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 161, size 1 bytes written. - Key: 162, size 1 bytes written. - Key: 163, size 1 bytes written. - Key: 164, size 1 bytes written. - Key: 165, size 1 bytes written. - Key: 166, size 1 bytes written. - Key: 167, size 8 bytes written. - Key: 168, size 4 bytes written. - Key: 169, size 1 bytes written. - Key: 170, size 1 bytes written. - Key: 171, size 1 bytes written. - Key: 172, size 1 bytes written. - Key: 173, size 1 bytes written. - Key: 174, size 1 bytes written. - Key: 175, size 1 bytes written. Section: 31 - Key: 4, size 16 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. Section: 44 - Key: 3, size 1 bytes written. Section: 49 - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 55 - Key: 0, size 80 bytes written. - Key: 1, size 2 bytes written. Section: 56 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. Section: 59 - Key: 0, size 31 bytes written. - Key: 1, size 135 bytes written. - Key: 2, size 55 bytes written. - Key: 3, size 113 bytes written. - Key: 4, size 59 bytes written. - Key: 5, size 84 bytes written. - Key: 6, size 69 bytes written. - Key: 7, size 61 bytes written. - Key: 8, size 35 bytes written. - Key: 9, size 34 bytes written. - Key: 10, size 61 bytes written. - Key: 11, size 35 bytes written. Section: 60 - Key: 0, size 25 bytes written. Section: 61 - Key: 0, size 135 bytes written. - Key: 1, size 69 bytes written. - Key: 2, size 82 bytes written. Section: 65 - Key: 0, size 11 bytes written. - Key: 1, size 11 bytes written. - Key: 2, size 11 bytes written. - Key: 3, size 11 bytes written. - Key: 4, size 11 bytes written. Section: 66 - Key: 0, size 160 bytes written. - Key: 1, size 160 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 160 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 160 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 4 bytes written. - Key: 14, size 4 bytes written. - Key: 16, size 4 bytes written. - Key: 19, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 36, size 4 bytes written. - Key: 38, size 4 bytes written. - Key: 40, size 4 bytes written. - Key: 53, size 1 bytes written. - Key: 64, size 8 bytes written. - Key: 65, size 8 bytes written. - Key: 66, size 8 bytes written. - Key: 67, size 8 bytes written. - Key: 68, size 8 bytes written. - Key: 70, size 8 bytes written. - Key: 82, size 8 bytes written. - Key: 83, size 8 bytes written. - Key: 84, size 8 bytes written. - Key: 87, size 6144 bytes written. - Key: 88, size 300 bytes written. - Key: 89, size 40 bytes written. - Key: 104, size 41 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 4 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 4 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 2 bytes written. - Key: 118, size 4 bytes written. - Key: 120, size 4 bytes written. Section: 67 - Key: 0, size 2756 bytes written. Section: 76 - Key: 0, size 534 bytes written. Section: 84 - Key: 0, size 3 bytes written. Section: 87 - Key: 0, size 4 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 91 - Key: 0, size 2048 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. Section: 111 - Key: 0, size 200 bytes written. - Key: 1, size 20 bytes written. - Key: 2, size 20 bytes written. - Key: 126, size 20 bytes written. - Key: 127, size 20 bytes written. - Key: 150, size 8 bytes written. - Key: 151, size 4 bytes written. - Key: 152, size 40 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 19, size 40 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 163 - Key: 0, size 8 bytes written. Section: 181 - Key: 0, size 8 bytes written. - Key: 1, size 10 bytes written. - Key: 2, size 1 bytes written. Section: 182 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 183 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 184 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 185 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 186 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 187 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 188 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 190 - Key: 0, size 355 bytes written. Section: 191 - Key: 0, size 5 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 200 - Key: 0, size 5 bytes written. Section: 202 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 42 bytes written. Section: 213 - Key: 0, size 20 bytes written. Section: 215 - Key: 0, size 84 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 225 - Key: 0, size 1 bytes written. - Key: 1, size 6 bytes written. - Key: 2, size 6 bytes written. Section: 231 - Key: 0, size 16 bytes written. Section: 232 - Key: 0, size 20 bytes written. - Key: 1, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 1 bytes written. Section: 238 - Key: 1, size 1 bytes written. Section: 250 - Key: 1, size 1076 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 390 bytes written. - Key: 4, size 36 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 304 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. Section: 306 - Key: 0, size 2 bytes written. Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Section: 319 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. - Key: 19, size 148 bytes written. - Key: 20, size 148 bytes written. - Key: 21, size 148 bytes written. - Key: 22, size 148 bytes written. - Key: 23, size 148 bytes written. - Key: 24, size 148 bytes written. - Key: 25, size 148 bytes written. - Key: 26, size 148 bytes written. - Key: 27, size 148 bytes written. - Key: 28, size 148 bytes written. - Key: 29, size 148 bytes written. - Key: 30, size 148 bytes written. - Key: 31, size 148 bytes written. - Key: 32, size 148 bytes written. - Key: 33, size 148 bytes written. - Key: 34, size 148 bytes written. - Key: 35, size 148 bytes written. - Key: 36, size 148 bytes written. - Key: 37, size 148 bytes written. - Key: 38, size 148 bytes written. - Key: 39, size 148 bytes written. - Key: 40, size 148 bytes written. - Key: 41, size 148 bytes written. - Key: 42, size 148 bytes written. - Key: 43, size 148 bytes written. - Key: 44, size 148 bytes written. - Key: 45, size 148 bytes written. - Key: 46, size 148 bytes written. - Key: 47, size 148 bytes written. - Key: 48, size 148 bytes written. - Key: 49, size 148 bytes written. - Key: 50, size 148 bytes written. - Key: 51, size 148 bytes written. - Key: 52, size 148 bytes written. - Key: 53, size 148 bytes written. - Key: 54, size 148 bytes written. - Key: 55, size 148 bytes written. - Key: 56, size 148 bytes written. - Key: 57, size 148 bytes written. - Key: 58, size 148 bytes written. - Key: 59, size 148 bytes written. - Key: 60, size 148 bytes written. - Key: 61, size 148 bytes written. - Key: 62, size 148 bytes written. - Key: 63, size 148 bytes written. - Key: 64, size 148 bytes written. - Key: 65, size 148 bytes written. - Key: 66, size 148 bytes written. - Key: 67, size 148 bytes written. - Key: 68, size 148 bytes written. - Key: 69, size 148 bytes written. - Key: 70, size 148 bytes written. - Key: 71, size 148 bytes written. - Key: 72, size 148 bytes written. - Key: 73, size 148 bytes written. - Key: 74, size 148 bytes written. - Key: 75, size 148 bytes written. - Key: 76, size 148 bytes written. - Key: 77, size 148 bytes written. - Key: 78, size 148 bytes written. - Key: 79, size 148 bytes written. - Key: 80, size 148 bytes written. - Key: 81, size 148 bytes written. - Key: 82, size 148 bytes written. Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. Section: 321 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 325 - Key: 0, size 116 bytes written. Section: 331 - Key: 0, size 20 bytes written. - Key: 1, size 40 bytes written. - Key: 2, size 40 bytes written. - Key: 3, size 40 bytes written. - Key: 4, size 40 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4902 bytes written. Section: 362 - Key: 0, size 1 bytes written. - Key: 1, size 120 bytes written. Completed in 18.719 s what can i do ? |
Invalid sim on Nokia 6210 | dario | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-23-2001 02:19 |
Nokia 3210 Mastercode +simlock | kraaiguy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-26-2000 14:13 |
SIMLOCK NOKIA 3210 V 4,43 | zibiss | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-23-1999 23:18 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
N6150 simlock open??? | Tommy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-21-1999 09:31 |
