12-16-2009, 05:50 | #1 (permalink) |
Temporary banned !! Join Date: Sep 2004
Member: 83645 Status: Offline Thanks Meter: 111 | 5000d No Signal after downgrade but repaired by JAF But gives error during unlocking procedure. After undo job, unlocking procedure finished but phone have no signal. Try again the unlocking procedure but error again...... Logs: Code: PhoneType:RM-362 SwVersion: V 04.89 13-08-08 RM-362 (c) Nokia MCU file: rm362__04.89.mcusw Trying to find patch position ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004B3D6A:3B8ADA60 Area [01000000-0101FFFF] erased in 0.547 s Area [01220000-0123FFFF] erased in 0.594 s Area [01440000-0145FFFF] erased in 0.578 s Area [014C0000-014DFFFF] erased in 0.656 s Area [01BE0000-01BFFFFF] erased in 0.657 s Programming ... Programming completed. Phone not responding ! Phone not responding ! Logs: Code: ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004B3D6A:3B8ADA60 Area [01000000-0101FFFF] erased in 0.594 s Area [01220000-0123FFFF] erased in 0.594 s Area [01440000-0145FFFF] erased in 0.640 s Area [014C0000-014DFFFF] erased in 0.656 s Area [01BE0000-01BFFFFF] erased in 0.562 s Programming ... Programming completed. Retrying ... OK, case id: 4 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004B3D6A:3B8ADA60 Area [01000000-0101FFFF] erased in 0.625 s Area [01080000-0109FFFF] erased in 0.641 s Area [01BD0000-01BEFFFF] erased in 0.656 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x00 But when I unlocked it with JAF, it's done with no hussle. Logs: Code: Powering the phone... Unlocking... IMEI: 355701020219782 ASIC: b SW version: 04.89 Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__04.89.mcusw Decrypting flash...Done Checking ROM call...Done Checking security function...Done Encrypting....Done Patch status: 00 MCU ID: 0x3162 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 317E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11 First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00 Flash ID is 0x7E310100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: a2 Loader is ready... P-key nokia module version 01.02 MSID: 840AE2D9D7E19891E849F72114 MSID decoded: 2C40BAE9004B3D6AA9000000 FAID: CE3FB5200E0E821BEFA7B250 Erasing area: 01000000 - 0101FFFF... Erasing area: 01080000 - 0109FFFF... Perm. Data Restore OK Unlocking... Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 131 What's this error? Is this a Bug? Please check it out... TIA br, |
The Following User Says Thank You to 2lits For This Useful Post: |
12-31-2009, 09:24 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | this is it happen again to me now.. ver. 4.89 same error, and after undo operation phone continue to unlock but no network. but i unlock in jaf. done with signal.. please pay attention on this |
About no signal after repair SD (software) | bireun | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-24-2010 17:29 |
6500 no signal after flash with jaf. | atifnamdar | Nokia Base Band 5 ( BB-5 ) | 2 | 11-03-2009 09:28 |
k790 no signal after wrong flashing by K800 firmware | ::.imeimate.:: | Cruiser Suite | 1 | 11-14-2006 17:48 |
BE1 16F No signal after Mihnea Repair | Hanukkah | Alcatel & TCL Old Models | 4 | 09-06-2001 22:53 |
how to repair no signal after phone falling in water | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-11-2001 19:33 |
