Old 05-21-2010, 12:04   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
5030 restart on RADIO
I have fully flashed write pm and unlock but same. here is info. when play radio it restart.
The Following 2 Users Say Thank You to alamgarh For This Useful Post:
Old 05-21-2010, 12:10   #2 (permalink)
Member: 1181399
Thanks Meter: 40
bro flash with latest firmware
The Following User Says Thank You to ayash khanna For This Useful Post:
Old 05-21-2010, 13:11   #3 (permalink)
shakeel145's Avatar
Member: 510445
Sonork: 100.1638301
Thanks Meter: 353
changed radio ic hardware problem
The Following User Says Thank You to shakeel145 For This Useful Post:
Old 05-21-2010, 15:33   #4 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
after this all ok..
JAF version 1.98.64
Detected PKEY:
Card life counter: 52.25%
P-key nokia module version 01.02
Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-524\
Searching for default location of ini...
Checking path: \Products\RM-524\
Searching for JAF saved location of ini...
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-524\rm524_005.010
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-524\rm524_005.01ic
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-524\rm5240_nai05.01ic
Languages in ppm: English,Arabic,French,Swahili
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-524\rm524_005.01ia
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-524\rm5240_nai05.01ia
Languages in ppm: English,Arabic,Farsi,French,Urdu
MCU: C:\Program Files\Nokia\Phoenix\Products\RM-524\rm524_005.010
Booting phone...
MCU ID: 0x2293
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
FLASH ID0: 225400EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Flash ID is 0x5422EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: 1c
Loader is ready...
MSID: 848A4EBE789FFFB0CBFD1F96CE
MSID decoded: 3E4EBAE900C53016A8000000
FAID: C63E65B475F2181C138B5E6C
Operation took 0 minutes 16 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 0179FFFF...
Erasing area: 017A0000 - 017EFFFF...
Erasing area: 01F00000 - 01FDFFFF...
Operation took 0 minutes 54 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 20 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-524\rm524_005.01ia
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 8488D52F14CB3FC392E7B563C2
MSID decoded: 3E4EBAE900C53016A9000000
FAID: 05B3A408F586BFA98A554777
Operation took 0 minutes 17 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01250000 - 0125FFFF...
Erasing area: 01260000 - 0174FFFF...
Operation took 0 minutes 34 seconds...
Writing...
Operation took 0 minutes 23 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-524\rm5240_nai05.01ia
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84143B3FFD431BFFDCB57E7B12
MSID decoded: 3E4EBAE900C53016AA000000
FAID: 3896189E97B34C883943700D
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01750000 - 0178FFFF...
Operation took 0 minutes 2 seconds...
Writing...
Operation took 0 minutes 1 seconds...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 3 minutes 10 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-524, Software version: 05.01
IMEI: 351527045157366
Product Code: 0576088
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 8 seconds...
Done!
Done!
Done!
Old 09-19-2010, 21:23   #5 (permalink)
Member: 701004
Sonork: 1626436:danish
Thanks Meter: 116
Nobody have100% solution ???????????????????????????????????????
Old 10-04-2010, 06:42   #6 (permalink)
Member: 1318530
Thanks Meter: 9
yes
First erase all then flash with latest virsion and then write the ok pm
the problem will be solve other wise change the radio ic 100% solution
The Following User Says Thank You to bilal_naeem786 For This Useful Post:
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.15748 seconds with 10 queries
