Old 07-16-2010, 12:39   #1 (permalink)
Member: 1053356
Sonork: 12345
Thanks Meter: 18
5030c Invalid UEM Data, No RPL backup will be made for this phone.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 00246CFA:DA3BDA66
ASIC type: 11
UEM Imei: 35935803110194
Phone Type: RM-524
SW Version: V 03.75 21-04-09 RM-524 (c) Nokia
Imei plain: 35935803110194-1
Product Code: 0578482
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: EL
Language Pack:
- not available.
Imei net: 35935803110194
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK 1:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
phone stuck with light only in display
thanks in advance
Old 07-16-2010, 14:35   #2 (permalink)
Member: 372482
Thanks Meter: 93
Give full self test log here
Old 07-16-2010, 14:43   #3 (permalink)
Member: 1053356
Sonork: 12345
Thanks Meter: 18
Phone Type: RM-524
SW version: V 03.75 21-04-09 RM-524 (c) Nokia
ID Test name Startup Result
46 UEM_CBUS_IF Y PASSED(00)
15 SLEEP_X_LOOP Y PASSED(00)
3 EAR_DATA_LOOP Y PASSED(00)
12 SIM_CLK_LOOP Y PASSED(00)
13 SIM_IO_CTRL_LOOP Y PASSED(00)
39 WARRANTY Y PASSED(00)
33 SIM_LOCK Y PASSED(00)
10 PPM_VALIDITY Y PASSED(00)
43 LCD Y !FAILED(01)
41 FLASH_CHECKSUM N PASSED(00)
30 RF_CHIP_ID N !FAILED(01)
52 KASUMI N PASSED(00)
Old 07-16-2010, 16:42   #4 (permalink)
Member: 372482
Thanks Meter: 93
Try to make full flash and unlock them
Old 07-17-2010, 09:02   #5 (permalink)
Member: 1053356
Sonork: 12345
Thanks Meter: 18
I flashed with
Phone Type: RM-524
SW Version: V 05.01 23-09-09 RM-524 (c) Nokia
still same problem
Old 07-17-2010, 14:01   #6 (permalink)
Member: 1053356
Sonork: 12345
Thanks Meter: 18
hello supporters any solution please?..............
Old 07-20-2010, 07:46   #7 (permalink)
Member: 1053356
Sonork: 12345
Thanks Meter: 18
I think this complaint is not repearable, if anyone have any solution please inform,,,
thanks
Old 07-20-2010, 08:13   #8 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
Originally Posted by cellsafemobile View Post
Phone Type: RM-524
cant you see in self test ( 43 lcd y !failed(01)
just change lcd then let me know
br
Old 08-06-2010, 15:28   #9 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
same problem with 2 fone
1208 and 1661
Old 08-09-2010, 14:45   #10 (permalink)
Crazy Poster
Member: 484608
Thanks Meter: 9
kutteke bache kya solution hai reeeee
Old 08-09-2010, 15:17   #11 (permalink)
Member: 1144271
Sonork: kuldeep_sharma2k7
Thanks Meter: 62
bro u have just one way becose this time ume ic is damage just change this and write latest flash file after flashing write pm all will b done
Old 08-09-2010, 15:20   #12 (permalink)
Crazy Poster
Member: 484608
Thanks Meter: 9
write full pm your set will be ok dears
Old 08-09-2010, 15:33   #13 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
ASIC type: 11
Phone Type: RM-524
Ppm Id: EL
Language Pack:
- not available.
Counter: 0/3, 0/10
thanks in advance
first clair what u do ? if u just backup rpl ? then try manual mode & try.
Page generated in 0.20254 seconds with 9 queries
