10-07-2009, 07:19 | #1 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 470292 Status: Offline Thanks Meter: 147 | 5130 Contact Service 100% Ok.. I soloved my phone's Contact service.... By following steps... 1. Backup of Rpl All Sections... 2. Backup Full Pm. 3. Go to Services\Imei Rebuild\ and Press Reset Npc. 4. Now Go to Flash\Advance\Press Get address\Unmark eprom and Mark Force Whole flash and then press Erase Flash. 5. Go to flash menu select files for flashing. and Mark Erase and Skip if not empty. 6. Go to services\Imei rebuild and write rpl which has been back uped.. 7. Now Go to services\Pm\ and select original pm file by pressing load from file. And press PPm Auth. 8. Now Write pm if ask to rewrite simlock press no. 9. Now go to services\Action\and press Reset all. 10. Now Enjoy your phone is repaired..... |
The Following 23 Users Say Thank You to adnanskyland For This Useful Post: |
10-07-2009, 07:23 | #2 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Quote:
how about 7210c you just give me a steps guide if the sl data is corrupted but the serial no. Is steel.... | |
The Following User Says Thank You to lilong_lee For This Useful Post: |
10-07-2009, 16:57 | #8 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nepal(Mobilezone)
Member: 1016132 Status: Offline Sonork: 100.1592677 Thanks Meter: 188 | ersion Info: MCU SW version: V 06.51 23-03-09 RM-436 (c) Nokia HW version: 1001 RFIC version: 06540601 DSP version: ICPR72_08w48 LCD version: SHARP PPM version: V 06.51 23-03-09 RM-436 (c) Nokia MR BT MCM version: 2222-143C Retu version: 15 Tahvo version: 22 Product Info: Production serial number: DTD025044 Product code: 0566933 Module code: 0203868 Basic production code: 0563951 Long production SN: 0 Serial Numbers: IMEI plain: 3531800317101xxxx IMEI spare to net: 3A 35 81 00 13 17 10 02 IMEI SV to net: 33 35 81 00 13 17 10 32 F1 Other Info: Model : Nokia 7210 Supernova (Live) BSI: 6.6 KOhm SIMLOCK_DATA corrupted! not solve from this way 7210c i think need rpl thank roshan |
10-07-2009, 17:15 | #10 (permalink) |
No Life Poster Join Date: Apr 2006 Location: .:Islam:.:Peace:.Pakistan:. Age: 48
Member: 266874 Status: Offline Sonork: 100.1581444 Thanks Meter: 97 | if supper dongle key is invalid then impposible to pm autherntication. |
The Following User Says Thank You to Imran Bhatti For This Useful Post: |
03-25-2010, 13:59 | #12 (permalink) |
Registered User Join Date: Mar 2009 Location: india Age: 41
Member: 998932 Status: Offline Sonork: DJ-23 Thanks Meter: 18 | 5130 contact service 100% ok.. Just follow these steps.. I soloved my phone's contact service.... By following steps... 1. Backup of rpl all sections... 2. Backup full pm. 3. Go to services\imei rebuild\ and press reset npc. 4. Now go to flash\advance\press get address\unmark eprom and mark force whole flash and then press erase flash. 5. Go to flash menu select files for flashing. And mark erase and skip if not empty. 6. Go to services\imei rebuild and write rpl which has been back uped.. 7. Now go to services\pm\ and select original pm file by pressing load from file. And press ppm auth. 8. Now write pm if ask to rewrite simlock press no. 9. Now go to services\action\and press reset all. 10. Now enjoy your phone is repaired.. thenks dear but this is not work |
The Following User Says Thank You to mobile killer For This Useful Post: |
03-25-2010, 14:02 | #14 (permalink) |
Freak Poster Join Date: Oct 2009 Location: madrid spain
Member: 1145599 Status: Offline Thanks Meter: 41 | n 70 phone startup failed contact retailer .is there any help? Searching for JAF box ... JAF box detected Box firmware version: 1B1 Try synchronization with phone Phone detected Read phone informations Type: RM-84 Version: V 05wk07v48.6 19-01-10 RM-84 (c) Nokia. IMEI: 352753013463391 SP LOCK status: Config Key: 0000000000000000 Provider Key: 2440700000000000 Block 1: OPEN Type 5 Data: FFFFFF Block 2: OPEN Type 5 Data: FFFFFF Block 3: OPEN Type 5 Data: FFFFFF Block 4: OPEN Type 5 Data: FFFFFF Block 5: OPEN Type 5 Data: FFFFFF Block 6: OPEN Type 5 Data: FFFFFF Block 7: OPEN Type 5 Data: FFFFFF Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Try Boot phone in flash mode ERROR: Function name: JAFBOX_BB5_FLASH_bb5challenge Error number: 03 ERROR: Function name: JOBS_CheckPhone Error number: 11 |
The Following User Says Thank You to ELKALAA For This Useful Post: |
03-25-2010, 16:36 | #15 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | http://forum.gsmhosting.com/vbb/f550...1/#post5624220 Hello guys must see this link u have get some more idea about this |
The Following User Says Thank You to ..::MOBILES::.. For This Useful Post: |
nokia 5130 sl3 contact service 100% ok in mx key | ashok_kumar459 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 39 | 02-23-2010 15:54 |
5130 contact service all ok | chand_gee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-14-2010 19:54 |
1200 - 1208 - 1650 Contact Service 100% Ok | sunnyarora | Nokia Hardware & Hardware Repair | 31 | 11-19-2008 08:33 |
