09-01-2010, 06:39 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: FENI,BANGLADESH Age: 38
Member: 537829 Status: Offline Thanks Meter: 96 | 5130 contact service. HERE IS LOG:- Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35932902215945-3 Product Code: 0571584 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! WHAT CAN I DO? |
09-01-2010, 06:41 | #2 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: siliguri,india Age: 31
Member: 1183572 Status: Offline Thanks Meter: 203 | Quote:
bcz til now no any working solution. for this problem | |
09-01-2010, 06:42 | #3 (permalink) |
Freak Poster Join Date: May 2009 Location: philippines Age: 36
Member: 1024596 Status: Offline Thanks Meter: 53 | just follow this procedure: First method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Repair SIMlock with MXKey 6 - Repair Superdongle with MXKey 7 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) The second method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Lock the by phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 6 - Repair SIMlock with MXKey 7 - Repair Superdongle with MXKey 8 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) Third method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Erase Eeprom Section: Flashing-> Advance-> GetAddress, Disable Safe Erase. Enable Eeprom Part only, Click Erase. 3 - Locke the phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 4 - Repair SIMlock with MXKey 5 - Repair Superdongle with MXKey 6 - Super SD Auth, and finally write Full PM(without Field 308-120) [B](If required Recover Cert) |
The Following User Says Thank You to ericz_2909 For This Useful Post: |
09-01-2010, 06:46 | #4 (permalink) | |
do u have a any idea what u r saying to do.... don't confuse user"s. | |
The Following User Says Thank You to adityajha For This Useful Post: |
09-03-2010, 22:29 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2010 Location: gsm hospital
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | 5130 hav 4types contact service 1.security test failed(this problem can make by modified pm auth) 2.sl data corrupted(no solutions now wth third party boxes,but it can make by nokia care) 3.imei corrupted(only make by nokia care now,not by third party boxes now) 4.hardware problem(its power related,change avilma ic,may solved) note.switching on phone directly shows contact service means hardware problem.switching on phone,asking for 'accept without simcard'and if press yes going to contact service means sl data or imei corrupted gsmdocter |
The Following User Says Thank You to gsmdocter For This Useful Post: |
09-04-2010, 06:50 | #11 (permalink) | |
Major Poster Join Date: Oct 2007
Member: 607782 Status: Offline Thanks Meter: 10 | Quote:
or u can bring it to nokia *******r care maybe they can help u if the phone still have guarantee card | |
09-04-2010, 06:58 | #12 (permalink) |
Junior Member Join Date: Jan 2008 Location: bhuj(gujarat)
Member: 687825 Status: Offline Thanks Meter: 4 | do this for sl3 unlock and cs SOLUTION OF SL3 ANY MOBILE CS & SP LOCK NOTE: ANY SL3 MOBILE U WANT TO UNLOCK, 1st MAKE BACK UP OF THAT MOBILE RPL AND DON’T MODIFY RPL FILE STEP: 1). MAKE BACK UP OF UR MOBILE RPL 2). MAKE BACK UP OF OTHER OK (NON CONTACT SERVICE) MOBILES RPL AND P.M OF THAT MOBILE U WANT TO UNLOCK. 3). THEN OPEN BOTH RPLS IN NOTEPAD, >>>>> DON’T MODIFY UR CONTACT SERVICE RPL; COPY (PRODUCT CODE, PSN, HWID) FROM CS RPL TO NEW OK RPL. <<<<<<<< 4). THEN WRITE MODIFEID OK RPL TO UR MOBILE 5). UR MOBILE GOES TO IMEI 1234560654321 DON’T WORRY. 6). WRITE OK FULL PM TO UR MOBILE, >>>>>SKIP SOMLOCK DATA<<<< FIRST SUPERSD AUTH MUST BE RECUIRED 7). THEN REWRITE UR OLD MAIN ORIGINAL BACKUP RPL TO UR MOBILE. THEN CHECK AND SCAN UR MOBILE UR PROBLEM WAS SOLVE >>>>>>>>>>>>>>>>>>>>>REPLY ME AFTER THIS PROCESS<<<<<<<<< I TRY THIS PROCESS ON MX KEY AND UFS BOX AND I WILL UNLOCK NOKIA5800 CS<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< TECHNICIAN:::-- KHATRI AJAY ([email protected]) From bhuj(gujarat) |
The Following User Says Thank You to khatriaju_007 For This Useful Post: |
09-06-2010, 12:40 | #15 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 666540 Status: Offline Thanks Meter: 354 | Quote:
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
how to unlock 5130 | accelr8 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-24-2010 17:52 |
5130 5190 6190 | MGG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-03-2000 20:36 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
