11-21-2009, 05:31 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Age: 39
Member: 81931 Status: Offline Thanks Meter: 92 | 5130 contact service after SX4 same result. SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35322303415133-3 Product Code: 0571584 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2009-07-28T03:56:08Z SW Version: 06.94 Variant Version: 010 ProductProfile: RM495_0571584_06.94_010.spr Simlock: 0571584_simlock.bin Imei: 353223034151333 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF UFS2 SarasSoft disconnected. after SX4 write full pm or pm301+309 result same SECURITY failed .... |
11-21-2009, 05:42 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
11-21-2009, 05:59 | #4 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 470292 Status: Offline Thanks Meter: 147 | Here is solution I soloved 5130 contact service by following steps... 1. Backup of Rpl All Sections... 2. Backup Full Pm. 3. Go to Services\Imei Rebuild\ and Press Reset Npc. 4. Now Go to Flash\Advance\Press Get address\Unmark eprom and Mark Force Whole flash and then press Erase Flash. 5. Go to flash menu select files for flashing. and Mark Erase and Skip if not empty. 6. Go to services\Imei rebuild and write rpl which has been back uped.. 7. Now Go to services\Pm\ and select original pm file by pressing load from file. And press PPm Auth. 8. Now Write pm if ask to rewrite simlock press no. 9. Now go to services\Action\and press Reset all. 10. Now Enjoy your phone is repaired..... |
5130 contact service (ANSWERED) | vishal123123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-10-2011 11:05 |
nokia 3600s contact service after sx4 Pls help | kaino147 | Cyclonebox | 5 | 10-24-2009 11:54 |
Reload this Page strange problem 5130 contact service after check only "read info" | pakmobiles | Cyclonebox | 8 | 10-16-2009 16:06 |
strange problem 5130 contact service after check only "read info" | pakmobiles | Universalbox | 2 | 10-14-2009 13:44 |
