Old 02-11-2010, 06:44   #1 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
Question 3120c SECURITY_TEST failed! NOT solved by MX KEY[SOLVED]
BUS CHECK
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1A70000C2A835750B98BEDEAC78AE837897E618C
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 003F - 0000 8A21 [AMD ] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79
Original Imei: 35484902243243
Original Product code: 0561596
Bluetooth ID: 0023B417222B
Phone Type: RM-364 (Nokia 3120 classic)
SW Version: V 10.00 06-03-09 RM-364 (c) Nokia
Imei plain: 3548490*******
Product Code: 0559085
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
TimeStamp: 2009-03-18T10:41:28Z
SW Version: 10.00
Variant Version: 010
ProductProfile: RM364_0559085_10.00_010.spr
Simlock: 0559085_simlock.bin
Imei net: 3548490*******
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
after editing rpl AS LIKE THIS
Imei: 3548490*******
Restoring RF/BB DATA from backup ...
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0561596)... OK
Updating PSN (KKR902871)... OK
Updating HWID (2001)... OK
Updating SIMLOCK...Trying to update SUPERDONGLE_KEY ...OK
Updating WMDRM_PD...OK
Certificate programmed successfully !
Product Code: 0561596
Language Pack:
- not available.
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Counter: 0/3, 0/10
AFter SD REPAIR
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Original Imei: 3548490*******
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
PM WIT filed 1 n 3 09 PM
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (98 bytes)
Warning: failed to write 1 - 18 (98 bytes)
Warning: failed to write 1 - 20 (98 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (10 bytes)
Warning: failed to write 1 - 31 (98 bytes)
Warning: failed to write 1 - 33 (36 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Warning: failed to write 1 - 40 (16 bytes)
Warning: failed to write 1 - 41 (182 bytes)
Warning: failed to write 1 - 42 (4 bytes)
Warning: failed to write 1 - 43 (36 bytes)
Warning: failed to write 1 - 44 (182 bytes)
Warning: failed to write 1 - 46 (64 bytes)
- 120 skipped
- 308 skipped
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Completed in 8.250 s
PM auth
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 202.164.209.2
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 02-11-2010, 06:56   #2 (permalink)
Member: 1086393
Thanks Meter: 771
I can see pm 1 & 309 can,t be programmed successfully on the phone--
try this-
Full erase
write rpl
sx4--then write pm.
& post result here
Old 02-11-2010, 06:59   #3 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
Wink repair
try this-
Full erase
write rpl
sx4--then write pm.
& post result here
sure ill try post results
Old 02-11-2010, 07:03   #4 (permalink)
R@ZIB-BD's Avatar
Member: 718425
Thanks Meter: 5,873
Edit you RPL.................
Old 02-11-2010, 07:11   #5 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
repair
heloo bro see the log already edited rpl.... after editing it came sd invalid.... again if repair sd then it comes to same condition SECURITY_TEST failed!
Old 02-11-2010, 07:11   #6 (permalink)
Member: 1028136
Thanks Meter: 18
Can you tell, step editing with imei RPL 123456789.
please guidance
thanks.
Old 02-11-2010, 07:33   #7 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
repair
please guidance
thanks.
see this u will come to knw thnx for MX TEAM SOLVED SECURITY_TEST failed!
After erase n flash
Processing file: rm364__10.00.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 20.62 MB
Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
RAP PAPUBKEYS is blank/erased.
Total erase size: 21.87 MB
CMT NOR area [00000000-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [01480000-015FFFFF]
CMT NOR area [00140000-0147FFFF]
erased in 21.938 s
Flash programming ...
CMT PAPUBKEYS: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79 (RAP Certificate 114 v1) written.
Programming completed in 1 min 44.703 s
Processing file: rm364__10.00.ppm_m10 as PPM
[BB5,BB5 ALGORITHM] size: 4.87 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 6.75 MB
CMT NOR area [01600000-01CBFFFF]
erased in 17.234 s
Programming completed in 25.906 s
Processing file: rm364__10.00_ISM_010.image_m10_deep_red as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 8.75 MB
NOR page size in the phone is 128 K.
Formating FS: FILE2 ...
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 34.87 MB
CMT NOR area [01FC0000-03F9FFFF]
CMT NOR area [01CC0000-01FBFFFF]
erased in 1 min 24.625 s
Converting UCP blocks to 128 K.
Programming completed in 44.219 s
Flashing completed in 6 min 15.797 s
Imei plain: 12345610654321-?
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Total time to process is 6 min 44.015 s
Rpl wrting
Imei: 3548490******
Updating RF ...OK
Updating BB ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC verified Ok.
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
sd repair
Product: V 10.00 06-03-09 RM-364 (c) Nokia
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 6.078 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-364_3548490******_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
pm auth
Scanning local SX4 Card ...
No SX4 Card found.
super sd auth
Restarting phone ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
writing pm 1 & 309
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 40, size 16 bytes written.
- Key: 41, size 182 bytes written.
- Key: 42, size 4 bytes written.
- Key: 43, size 36 bytes written.
- Key: 44, size 182 bytes written.
- Key: 46, size 64 bytes written.
- 120 skipped
- 308 skipped
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
Completed in 46.687 s
Again Bus check
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
The Following 3 Users Say Thank You to akashub For This Useful Post:
6300 contact service solve by MX-KEY dessertcell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 09-02-2010 16:35
How can i solve Security Test Fail, after unlock by Mx-key powerplay83 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 03-25-2010 14:39
3120c SECURITY_TEST failed! solved by MX KEY akashub Nokia Base Band 5 ( BB-5 ) 3 02-11-2010 10:31
SECURITY_TEST failed! solved by MX KEY akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 24 02-05-2010 12:56
e71 after flash blank screen solved by mx key adaki_vishal MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 11-10-2009 17:09
Page generated in 0.27005 seconds with 9 queries
