5130 contact service how to solve Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 15F00102BEED8C56DFC990B032D1E11A20490EFE ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35933603859570 Original Product code: 0571957 Bluetooth ID: EC9B5BDAE4F7 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.90 23-09-09 RM-495 (c) Nokia Imei plain: 35933603859570-3 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 112.206.136.190 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
after write SD here but same problem Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 07.90 23-09-09 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.859 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-495_359336038595703_SD.RPL" Updating SUPERDONGLE_KEY ...OK Version Info: MCU SW version: V 07.90 23-09-09 RM-495 (c) Nokia RFIC version: 06540601 DSP version: ICPR72_09w33 LCD version: SEIKO PPM version: V 07.90 23-09-09 RM-495 (c) Nokia EG BT MCM version: 2222-302 Retu version: 16 Tahvo version: 22 Content Pack version: Content: eg_red V 07.90 23-09-09 RM-495 (c) Nokia Product Info: Production serial number: 0 Long production SN: 0 Serial Numbers: IMEI plain: 359336038595703 IMEI spare to net: 3A 95 33 06 83 95 75 IMEI SV to net: 33 95 33 06 83 95 75 40 F4 Other Info: Model : Nokia 5130c-2 (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900 BSI: 7.2 KOhm SIMLOCK_DATA corrupted! |
first do this 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model if its in same condition then do this 1-Backup Rpl full 2- reset NPC 3- write full modified pm 4- restore imei 5- Repair SD 6- Super SD auth 7- write pm 1 and 309 field only simply not with sx auth 8- Default all setting best of luck |
5130 is SL3 phone. not supported at moment. br, |
