09-11-2010, 07:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | 5130 contact service possible to repair Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1FD000028A2D6850CD411BE22AF86A985E3467A6 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Original Imei: 35826803680827 Original Product code: 0572170 Bluetooth ID: 347E390B7064 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35826803680827-8 Product Code: 0572170 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! TimeStamp: 2008-12-26T09:58:45Z SW Version: 05.80 Variant Version: 004 ProductProfile: RM495_0572170_05.80_004.spr Simlock: 0572170_simlock.bin SIMLOCK_DATA corrupted! THIS IS POSSIBLE TO REPAIR IN MX KEY |
The Following User Says Thank You to lilong_lee For This Useful Post: |
09-11-2010, 07:59 | #2 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Philippines
Member: 557796 Status: Offline Thanks Meter: 187 | 5130Xpress Music is an SL3 phone.... not possible to fix on Mxkey.... wait for the update........ |
The Following User Says Thank You to =Deftones= For This Useful Post: |
09-11-2010, 08:05 | #3 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (12 bytes) Warning: failed to write 1 - 1 (70 bytes) Warning: failed to write 1 - 2 (70 bytes) Warning: failed to write 1 - 3 (70 bytes) Warning: failed to write 1 - 4 (70 bytes) Warning: failed to write 1 - 5 (276 bytes) Warning: failed to write 1 - 6 (276 bytes) Warning: failed to write 1 - 7 (276 bytes) Warning: failed to write 1 - 8 (276 bytes) Warning: failed to write 1 - 9 (384 bytes) Warning: failed to write 1 - 10 (384 bytes) Warning: failed to write 1 - 11 (384 bytes) Warning: failed to write 1 - 12 (384 bytes) Warning: failed to write 1 - 13 (384 bytes) Warning: failed to write 1 - 14 (384 bytes) Warning: failed to write 1 - 15 (384 bytes) Warning: failed to write 1 - 16 (384 bytes) Warning: failed to write 1 - 17 (32 bytes) Warning: failed to write 1 - 19 (16 bytes) Warning: failed to write 1 - 20 (32 bytes) - 2 skipped - 4 skipped - 8 skipped - 11 skipped - 12 skipped - 13 skipped - 31 skipped - 42 skipped - 44 skipped - 50 skipped - 54 skipped - 58 skipped - 59 skipped - 60 skipped - 61 skipped - 66 skipped - 88 skipped - 96 skipped - 107 skipped - 116 skipped - 117 skipped - 153 skipped - 163 skipped - 193 skipped - 202 skipped - 217 skipped - 218 skipped - 232 skipped - 238 skipped - 239 skipped - 250 skipped - 297 skipped - 298 skipped - 301 skipped - 302 skipped Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) - 319 skipped - 320 skipped - 322 skipped - 325 skipped - 334 skipped - 339 skipped - 341 skipped - 345 skipped - 354 skipped - 355 skipped - 356 skipped - 362 skipped - 364 skipped - 365 skipped Completed in 3.641 s |
09-11-2010, 08:10 | #4 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | SIMLOCK_DATA corrupted! Backup saved to "BB5_35826803680827_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 06.94 21-07-09 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1FD000028A2D6850CD411BE22AF86A985E3467A6 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0x0 bytes). Reading RAP CCC (0x160 bytes). Reading RAP HWC (0xD4 bytes). Flash Imei: 35826803680827 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SUPERDONGLE_KEY_DATA saved OK RF_DATA is empty. WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA is empty. RPL saved to "C:\mobileEx\3.4\data\backup\5130\BB5_358268036808 27_BACK.rpl" |
09-11-2010, 08:29 | #5 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | RPL: "C:\mobileEx\3.4\data\backup\BB5_35826803680827_BA CK.rpl" Imei: 35826803680827 Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1FD000028A2D6850CD411BE22AF86A985E3467A6 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0572170)... OK Updating LOCK ...error 0x0 Updating SUPERDONGLE_KEY ...OK Certificate programmed successfully ! Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35826803680827-8 Product Code: 0572170 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! |
09-11-2010, 08:50 | #9 (permalink) | |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Quote:
are you sure not exactly solution try to post here i will see .this solution is only unlocking .can you show here | |
09-11-2010, 15:19 | #12 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | corrupted simlock on SL3, only original rpl / backup can help you. don't waste your time on click this click that.. BR |
The Following 2 Users Say Thank You to gbluez For This Useful Post: |
09-11-2010, 15:27 | #13 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: mozila firefox/ gsmhosting.com
Member: 426107 Status: Offline Thanks Meter: 64 | Quote:
09-11-2010, 15:36 | #15 (permalink) |
Junior Member Join Date: Apr 2005 Location: Russia, Udomlya Age: 50
Member: 141920 Status: Offline Thanks Meter: 4 | Maybe you should take instructions http://newgsmforum.com/viewtopic.php?f=281&t=1087 |
The Following User Says Thank You to rvoronkov For This Useful Post: |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
