05-16-2010, 09:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | 5130 contect serves help me Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1C400210F3137E56709B3628222DDC3E5EB94F0B ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 3552120xxxxxxx Original Product code: 0572174 Bluetooth ID: 0025CF963F88 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 3552120370xxxxxxxx Product Code: 0572174 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35521203xxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... when itry sx4 server No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 119.152.246.218 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
05-16-2010, 10:58 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | - upload pm from file. - check Load RFBB from server. - SUPER SD auth. - write pm. - full factory reset. *post result. |
The Following User Says Thank You to MOURAD™ For This Useful Post: |
05-16-2010, 11:17 | #5 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | write pm 1 and pm 309 then fresh SD and authenticate and full factory your problem solve first write pm 1 and pm309 second fresh SD THIRD write full modified pm 4rth fresh full factory default your problem solve |
05-16-2010, 11:35 | #6 (permalink) |
No Life Poster Join Date: Sep 2006 Location: islamabad
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 25500106D5EB5850410F02D2FADBC35FA8E54886 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35932902664331 Original Product code: 0580583 Bluetooth ID: 00247C492C3F Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35932902664331-2 Product Code: 0580583 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359329026643312 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF still in contact service i changed avilma ic but no responce plz any one help me |
05-16-2010, 12:09 | #7 (permalink) | |
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | Quote:
05-17-2010, 12:30 | #8 (permalink) |
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | when i try to recover sertifcate hear is log RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1C400210F3137E56709B3628222DDC3E5EB94F0B ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Begin Certificate Request ... [InternalErrorFault] CERT [0572174] data not found in database (case id=0xCE02) and when i try fo pmm auth load from rfbb from server and super sd auth hear is massage Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.91 29-10-09 RM-495 (c) Nokia Using cached productData[1C400210F3137E56709B3628222DDC3E5EB94F0B] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request and hear is scane Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 3552120370xxxxxxx Product Code: 0572174 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35521203xxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
