Old 01-15-2010, 20:05   #1 (permalink)
Registered User
Member: 207723
Thanks Meter: 21
5130 don`t boot up
Hi all, I have 5130 which don`t start up.
When switch on it displays "Nokia" after that only white screen then light off and no more actions. I flashed it but no result. MobileEx says that all is OK, SL test passes, SD seems to be valid. Can`t understand what it needs else?
Old 01-16-2010, 00:42   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
for batter reply> post bus chek log br.
Old 01-16-2010, 00:48   #3 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
May be hw problem
post self test
br
Old 01-16-2010, 07:37   #4 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
HI,
I flashed many Phones with such problem and Most of Them Works ..
Only trick Flash to highest version available If all Went OK Selftest OK and Phone security is OK..Mean its HW issue u cant do much with SW atleast.
Old 01-16-2010, 08:30   #5 (permalink)
Registered User
Member: 207723
Thanks Meter: 21
Here is log as you asked:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11472, Date: 27-11-2009
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1530010428FD7C56F706C695F2DC22E75C40025A
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35932902967115
Original Product code: 0578785
Bluetooth ID: 00247C9496D3
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 35932902967115-3
Product Code: 0578785
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 359329029671153
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 01-16-2010, 08:33   #6 (permalink)
Member: 91045
Thanks Meter: 8,696
All is good with your phone
sw does all it can..cant be sw issue
Old 01-16-2010, 09:57   #7 (permalink)
Registered User
Member: 207723
Thanks Meter: 21
Aga!!
I just opened it and what I see - I see thet camera chip and nearest elements damaged...
I moved camera and Oh mirracle!! It switched on but now i have "Contact Service" and current log:
SIMLOCK_TEST passed
SECURITY_TEST failed!
Old 01-16-2010, 10:00   #8 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Aga!!
SIMLOCK_TEST passed
DO SX4 AUTH WITH GOOD PM
WBR
sahil2000ind
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post:
Old 01-16-2010, 10:12   #9 (permalink)
Registered User
Member: 207723
Thanks Meter: 21
Didn`t help, still
SIMLOCK_TEST passed
Old 01-16-2010, 10:43   #10 (permalink)
Member: 91045
Thanks Meter: 8,696
I said Above man
all is seems good with your phone and u did all possible can be done with SW so check in HW only for now
Old 01-16-2010, 11:14   #11 (permalink)
Registered User
Member: 207723
Thanks Meter: 21
VEry-very biggg thank you sir.
worked!!
successfull!!
Old 01-16-2010, 11:25   #12 (permalink)
Member: 91045
Thanks Meter: 8,696
and how is that can u explain here kindly would helpfull for others
Old 01-16-2010, 11:44   #13 (permalink)
Registered User
Member: 207723
Thanks Meter: 21
I`ll try to exlplain:
I killed SL zone myself, so when i tried to repair i did many operations I even don`t remember all but in the end i recieved "Contact Service" as i said.
Now I did the mistake - i did SX4 auth by one ver. of the program and tried to write PM by another as result - PM wasn`t writen fully.
Problem solved by writing PM a same prog. as doing SX4 auth. Result - success. Phone starts up normally.
I used to think that SX4 aut seems like S-key in Siemens and thought that it ones did it remains but i was wrong..
V3 goes to BOOT loader screen.. wont boot up tomandnic Motorola Hardware Repair 2 06-09-2007 21:28
W800i wont pick up - just boots up each time??? adez28 Cruiser Suite 12 01-26-2007 10:58
3310 1st boot up ok; 1st boot err ; harish35200 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-06-2006 16:55
Motorola v980 don`t power up after unlock Gr33n Motorola P2K (USB-Smart) 2 06-22-2006 14:33
s40 don`t powering up Videlec x1x to x45/x50 2 12-16-2002 15:06
Page generated in 0.26426 seconds with 10 queries
