Old 07-24-2010, 17:10   #1 (permalink)
aswadsaad988920's Avatar
Member: 151792
Thanks Meter: 15
5130 flash ok after nokia logo white screen (ANSWERED)
i flashed it with 7.90 flashed ok start up phon after nokia logo it coes white screen here is log
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Processing file: rm495__07.90.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Polling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 285856E
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 28000110A7437F56EDCFA87E9B5B563A59B688F8
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 2A964BA8
[ADL] Verifying communication to device OK.
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.641 s
CMT NOR area [000006C0-0001FFFF] erased in 0.625 s
CMT NOR area [00040000-000BFFFF] erased in 2.453 s
CMT NOR area [000C0000-0013FFFF] erased in 2.578 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 37.609 s
CMT NOR area [01380000-0151FFFF] erased in 9.094 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 1 min 40.907 s
Processing file: rm495__07.90.ppm_mena_b as PPM
[BB5,BB5 ALGORITHM] size: 6.31 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 45.734 s
Programming completed in 30.906 s
Processing file: rm495__07.90.image_mena_a_red as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 8.26 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 21.282 s
CMT NOR area [02160000-03FBFFFF] erased in 3 min 18.297 s
Programming completed in 43.610 s
[ADL] Restarting phone ...
[ADL] Timeout, no usb device found.
[ADL] Phone flashing completed, but failed to verify communication to product!
[ADL] Retrying in finalize phase...
Flashing terminated with error(s) in 12 min 25.422 s
help plzzzz
Old 07-24-2010, 17:11   #2 (permalink)
samadgsm's Avatar
Member: 227670
Thanks Meter: 87
use new version..........................
Old 07-24-2010, 17:33   #3 (permalink)
redrose2009's Avatar
Member: 1084993
Sonork: 100.1617420
Thanks Meter: 641
check display ic and display concter and check water damage
post reply
Old 07-24-2010, 18:25   #4 (permalink)
Member: 1128573
Thanks Meter: 242
br. not use NOKIA USB ROM with usb cable. now flash phone with 7 pin cable. phone alive or dead not care. phone flash complete 100% if not any hardware problem.
The Following User Says Thank You to mahir ashab For This Useful Post:
Old 07-24-2010, 19:03   #5 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
flash with latest ver 7.96,
your problem will solve
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post:
Old 11-16-2011, 06:06   #6 (permalink)
Member: 528610
Thanks Meter: 4
hi friend problem with 5130 after flashing ok but after logo apears white screen is there any solition for this problem? please help sabcom from Mauritius thank in advance
The Following User Says Thank You to sabcom For This Useful Post:
Old 11-16-2011, 06:41   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi sabcom,
it is better if you also include your operation logs; buscheck, scan and self test for better analysis.
Old 11-16-2011, 07:40   #8 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 96
brother.......plz flash with usb with latest version of flash file7.97
Old 11-17-2011, 13:27   #9 (permalink)
Member: 528610
Thanks Meter: 4
thank ,have do all still the same any solition??
Old 11-17-2011, 13:30   #10 (permalink)
Member: 528610
Thanks Meter: 4
dear friend big problem with s8530 after flash ok when press keylock phone off try with many flash files same problem please advise me good flash files ,sabcom from mauritius
Old 11-19-2011, 07:51   #11 (permalink)
Registered User
Member: 1660793
Thanks Meter: 4
i have also same problem what i do
same poblem here what i do
Old 11-19-2011, 07:58   #12 (permalink)
chandan_123's Avatar
Member: 801212
Sonork: 100.1657902
Thanks Meter: 773
bro try to atf box.............
Old 11-19-2011, 08:16   #13 (permalink)
Member: 1686412
Sonork: 100.1664625
Thanks Meter: 212
flashing on usb using 7.97
Old 11-19-2011, 08:21   #14 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 280
try to remove camra and the do flash
Erase size: 8.62 MB
help plzzzz
try this and post result
The Following User Says Thank You to neeraj1st For This Useful Post:
Old 11-19-2011, 08:27   #15 (permalink)
sajidshah50's Avatar
Member: 1016490
Thanks Meter: 290
Only 1 way.......change power ic....now this ic is available in market. 100000% tested.
Page generated in 0.32085 seconds with 9 queries
